Received the TS10 today. What a great little light. Prefect for what my needs are.
And thanks to @jon_slider. The first thing I did was turn the aux leds to low. It is just enough to easily find the light in the dark.
Bob
Bob
Glad you like it. Wurkkos definitely hit it out of the park with the light. I also really like that they are continuing to develop it and adding options for materials in response to what the community likes.
I ordered a couple of the flat top Vapcell F12 cells that @jon_slider recommended to go with it. A new flashlight deserves new cells.
In the meantime I am running some older efest 650ma cells I used in my Klarus. They are 50.4mm so they fit fine.
Bob
Yes, I use the F12s flat top cells for most of my 14500 lights. I may be the one that wrote the recommendation (??)
Not that it matters, but I was scratching my head thinking that I thought I had mentioned them … I just needed to make sure…
A few, where I look for Max output (not usually a great idea with lights this size, but impressive to dazzle the friends at times) I use the H10. Anyway, I really like the F12 cells.
I agree it is all your fault that HorizontalHunter bought F12 flat tops for his TS10… lol
Dont blame me, I only mentioned the F12 in a different thread
IMHO, the TS10 is the absolute best value in a 14500 light. Lowest price I have seen is $9. Its not the best 14500 light though. My vote for best 14500 is the Acebeam TAC AA.
Why?
Much better build quality.
Much more usable shape, I find the TS10 to be too small.
Non Andruil. My preference.
Mechanical tail switch. My preference.
Zero parasitic drain.
Works with lithium and AA batteries which makes it 1000% more versitile and useful.
Conclusion: TS10 best value really in any light period however IMHO not the best 14500 light for reasons mentioned above.
Please note these are my opinions.
I’m more interested in battery capacity and run time than max output so I went with the F12’s.
Bob
totally respect your clearly stated personal preferences, even though mine are different
the AA Tac has a lowest mode of 5 lumens. That does not work for me, I am a big fan of sublumen options, and the TS10 can reach some of the lowest lows of any light (similar to Zebra and HDS)
AA Tac is a 4 mode light, Im spoiled by Anduril and place a high value on its ability to reach outputs inbetween the typical 4 mode clicky lights
AA batteries, for me, are a waste of time… the max output is very limited, and if Im going to use Eneloop, which require recharging, I may as well use rechargeable LiIon
otoh, a convenient feature of the AA Tac is they provide a USB rechargeable 14500… that battery also works in a TS10 btw… and converts it into a light that does not require a separate charger, making it more convenient to gift, or travel light…
and I agree a mechanical switch has no parasitic drain… although… I dont mind the eSwitch in the TS10, it works fine for me, and I like that it is silent, unlike a mechanical clicky. The parasitic drain is low enough for it not to bother me, plus the light has a battery voltage meter that I find very useful
One thing I dont appreciate about either the AA Tac or the TS10 is that they use PWM…
Size: I prefer the small size of the TS10… if I wanted a 4 mode light the size of the AA Tac, I would strongly consider an 18650 Zebra, which is actually shorter than the AA TAC (except I cant stand the Zebra UI either)
choices are good… there is no perfect light for every scenario… I think that is why I keep buying more lights… lol
Yes, for me the AA Tac, though a really nice light, is too big for an AA light. But then I find the Pokelit to be bigger than I like.
The TS10 is just a great EDC pocket light. It Isn’t bright enough for some things, but fine for the vast majority of tasks that I use it for daily. Plus I have lots of choices for larger lights where sheer brightness or throw is required.
I must say that I would welcome the ability to use 1.5/1.2 volt cells. It is always nice to have options.
that was why I went w the Skilhunt H150… it is smaller in every dimension than the AA Tac, plus the H150 has fully regulated output and NoPWM
and if you want a standard reflector, instead of Tir in a headlamp, the Skilhunt M150 has all the same advantages (size, driver) as the H150, over the AA Tac
I agree. I have a horde of AA/14500 lights, but the M150 is my favourite by a wide margin. It does absolutely everything well.
