I’m looking for a retro looking Flashlight that hopefully can be modified to a single low brightness setting. My son loves flashlights and this will be a gift for him, which is the reason for needing a lower lumens setting. I really like the look of the Sofirn if22a but I couldn’t find any way to modify the UI settings. Any suggestions would be greatly appreciated!
He currently has a few similar lights and the latest one is a cheap Olight. I was hoping to get something with a push button instead of tighten to turn on.
Depending on how retro you want, antique brass D4V2 and you can limit the output of simple mode.
Or a convoy C8+ maybe, can limit output to 50%, or modify the driver to reduce it further if you only want on/off.
I think i’m just going to buy an old working Eveready Captain off eBay. I can replace the bulb with one of the drop in ones and switch out the D batteries for an 18650 with 3D printed adapter or those 3x AA adapters.
Can you post a specific link to any of these lights?
I’m not seeing any “retro looking Flashlights” on either of those sites, and no where on either site did I find anything referred to as “antique brass or copper”
Off topic, but I am curious about the reflashing kit, any idea if that would work easily to put anduril on a Martac Pro Tri-Flood 21700? (same as FW21 Pro 3x XHP 50.2) “easily” because I know zero about flashing drivers/software.
Edit: There’s no pads on the Maratac driver, unless they might be on the topside of the driver?
I like the look of the 2 x C versions of the captain or the Rayovac two C version of the old school lights. I have a bunch of them in my " collection" but doing a real mod on them never seems worth it to me . up close they aren't very well built and the switch and tail seem like real problems . Visualizing using a whole light C-8 drop -in and lots and lots of JB Weld .
I was only planning on adding a Nite-Ize or Dorcy led bulbs. Low lumens is what I am aiming for. I’ll probably even use some AA batteries with spacer since I have about 30 rechargeables I’ve collected over the years from Ikea.
I really wanted to get the Sofirn IF22A with the raw aluminum body but it didn’t look like there was a way to flash the Anduril firmware for the muggle mode.
