20W Slim Floodlight (Brand: Risen)
Reviewer's Overall Rating: ★★★☆☆
Summary:
Power: |
AC 85-265 V |
Switch: |
None, plug/unplug |
Modes: |
1 (On) |
LED Type: |
CW 45x45 mm LED (10S/2P) |
Lens: |
Glass - uncoated |
Tailstands: |
Side stands or can be mounted |
Price Paid: |
Review Sample (Was 33 USD) |
MyLED.com (http://www.myled.com/p7697-ip66-led-flood-light-20w-1800-2000lm-1-pcs-integrated-cool-white-black-ac85-265v.html) |
Date Ordered: |
7 July 2014 |
This floodlight was provided by MyLED for review.
Pros:
- Slim form factor (about 2 inches deep)
- Properly attached ground wire
- Appropriate build quality – good gasket material, proper screws, thermal compound
Cons:
- No plug installed
- No power switch
- Poor cord location makes it difficult to stand up
Features / Value: ★★★☆☆
From the MyLED site:
Brand: Risen
LED Power: 20W
Lumen Flux: 1800-2000LM
Voltage: AC85-265V
LED Type: 1 pcs Intergrated
Color: Cool White
Light Temperature: 6000-6500K
Light Angel: 120 Degree
Material: Aluminum Alloy & Glass
Body Color: Black
Waterproof Rating: IP66
Products Size: 180*185*45mm
Life Span: 35000 hrs
Warranty: 2 Years
Design / Build Quality: ★★★★☆
This is similar to most generic budget LED floodlights. Aluminum box with a square-ish metal reflector and big LED. It has a handle for standing or mounting. The one perk of this one is that it is a bit slimmer than some of the other models out there.
Unlike some other budget ones, this floodlight had a ground wire properly installed to the case.
Power: N/A
I didn’t do any readings since my equipment is subpar for this application.
Light Output: ★★★☆☆
This puts out a nice, even flood. It lights up a room well. I did a couple quick shots for comparison. Outside, the toy house is about 25 feet away, the basketball hoop pole is about 40, and the top of the yellow slide on the playground is about 60. For the indoor shot, the far wall and window is about 20 feet away.
Sorry for the grainy shots. Control on left and floodlight on on right, in case it isn't obvious. I’ve read that these are over advertised, and a real bridgelux array at 20 W is way better. That being said, this still is a handy light to have around. I think this power level would be ideal for garage lighting while working on a project or specific smaller area lighting outdoors like a patio or porch.
Summary: ★★★☆☆
I am not sure how to rate this since I don’t have much to compare it too. I will give it 3/5. It is well made, but I would have preferred a more polished unit that was more plug-in-and-go friendly for consumers.
