[Review] 77 Outdoors D25 Headlamp (18650)
I have the same UI as Funtastic. It’s not really a bother but it does have memory mode so it would be nice to go down when in the medium modes rather than cycle through high. I also can’t seem to go down in modes immediately after turning it on. Just seems like a weird behavior. Though at it’s price I can’t really complain much. I knew I should have gotten more than one Quadrupel driver :person_facepalming:
You need to be aware that there is a feature in the UI that gives you the ability to jump to high if you click within 3 seconds of turn on.
Oh ok I think I get it now. Thanks. Though mine is just within a second. The timing seems to leave little room for error on mine. I guess I’ll just use L-H cycle to avoid frustrations.
Today I modded all my 3 Headlamps.
with 2 Anduril Drivers from Quadrupel and one Attiny 412 from gchart. The second Attiny got a broken leg after some problems with a short causing the LED was always on.
But finaly all 3 Headlamps has ramping with Ramping iOS or Anduril.
I had two Drivers with Ver03 and one with Ver01, so the Ver03 got the Attiny 412.
Thanks to you both.
I changed the LEDs too:
2x LH351d 2700K + 5000K 90CRI
2x XM-L2 NW (3B or similar)
1x SST40 5000K
Drivers and Flashlights from recent posts for reference:
Glad you got them up and going! :+1:
:+1:
@ gchart. No pics at the moment, but 2 of mine are ver:05. Any idea if your mcu swap will work on those?
Side note. Where in central Illinois? I thought I was the only non-Sh#*cago Illinois resident here.
Are there any TIR optics that are simple drop-ins for either the D25/D10? Browsed quickly through this thread and it looks like the ones that people recommend still need some shaving down to fit.
Sorry for the late reply. I’m in a town on the outskirts of Peoria. I feel the same way about that other city.
I don’t know for sure about version 5. Mine were 3. But the MCUs are inexpensive enough that it wouldn’t cost much to try if you’re interested.
More LEDs - more Adidas
https://www.aliexpress.com/item/1005003317553406.html?spm=a2g0o.productlist.0.0.48976e88D8OQuY&algo_pvid=535867f4-458a-4942-91f6-f6c4a40bcd55&algo_exp_id=535867f4-458a-4942-91f6-f6c4a40bcd55-1&pdp_ext_f={"sku_id"%3A"12000025207147146"}
“The manufacturer is ”Aheitong” “:https://detail.1688.com/offer/646068512239.html?spm=a261y.7663282.hotsale.5.5c3855e6XDjFmg All other like Sofirn or Boruit or… are resellers only.
Thank you for informations Quadrupel.
Can you tell me, if it is possible to open front part with reflectors and change LEDs? I dont see any screws?
Dont know, but probably glued.
Depends, they probably changed the process over time. Most people were successful with opening D25-family lights, but some reported that they couldn’t open theirs.
Yeah, I think so too.
D25 have user friendly design.
I have early version of D25 from start of production, where MCPCB with LEDs is pressed to the hole in body headlamp and there is no mass under it.
Second version of D25 from 12/2020- BORUIT have flat surface under MCPCB with good thermal path.
I was curious, what type of design have this headlamp and if it is possible to swap LEDs and make some “Nichia flooder” from it.
Just get D10 and few various angle 20mm TIR optics.
Thanks. Pretty decent upgrade to my d25s. But I wonder how much brighter this 5 led version is. It’s says 3000 lumens. Not sure about that.
hi, someone tried to insert the driver from the lumintop fw3a?
Tried to open a D25LR, same host. But geez it’s impossible, even almost broke my tool. Turned CCW and it maybe moved a little judging by the few creaking noises, but nothing else. Completely stuck :person_facepalming:
To open you have to turn clockwise.
