ANENG V05B Digital 6000 Counts Multimeter True RMS with Bluetooth and data logging function
Hi, I came across a new digital multimeter model on Aliexpress and thought I’d provide a brief review on here. ANENG has NOT provided the device for review, I bought this with my own money and all views are my own.
First of all, this is not going to be a HKJ style professional review, I have a lot of respect for the high quality reviews our members create and I am not able to create such content, yet! My technical equipment wouldn’t allow me to measure the details, but at least I can give you some experiences from using it within the last 48 hours - this multimeter seems great for our various hobbies.
Observations/features about this device:
- affordable (I paid only 13$ after coupons including tracked shipping via DHL however YMMV)
- decent quality craftsmanship, device is rubberized around the edges - won’t scratch easily
- comes with bluetooth functionality
- the free app is perfectly usable and has multiple ways of viewing the measurement
- it has data logging which provides a in-app chart & CSV file
- small/compact design and lightweight
This battery powered, auto-ranging multimeter should be ideal for a variety of hobbies like electronics, flashlight, driver development, raspberry pi, arduino, PCB development, R/C, and more.
Buttons
ON/BT - long press for on/off of the multimeter, short press for enabling/disabling of bluetooth
SEL/NCV - short press for mode selection, keep button pressed for NCV measurement
H/ZERO/light - short press for Hold/zero, long press for display light and flashlight functionality
Please note that the display and flashlight remains illuminated until you switch it off
There is a RED LED which indicates NCV measurement and continuity. Continuity measurements also have a sound.
Multimeter functions, display flow
These are the OEM listed technical specifications:
View of the back side
Bluetooth disconnects when weaker AAA batteries are used, but the eneloops I have in them work great.
Charting feature within the app
(on tested Android devices a standard CVS file is stored locally that can be exported to Excel or Numbers)
I selected the minimal version at checkout which comes with probes and a temperature sensor
Probes are 12cm long and the cables are approximately 64cm long, the temperature sensor works as expected
Bluetooth connectivity, app, and data logging
- Device connects easily with a mobile phone that has the app installed
- App appears crude, but has all the functionality (especially compared to other DMM apps out there)
- Mobile app has multiple views you can select during measurement (double tap)
- Standard .cvs file will be stored with user-defined filename and can be exported
- Remote measurement to other devices if account is registered through app (feature not tested)
- You can finally chart charging/discharging curves, store measurements, and share across forums and social media
Advantages:
- App, bluetooth and data logging works at a very affordable price point.
- Data logging feature provides CSV file for each measurement (tested on Android phones), which can then be imported to Excel or Numbers.
- Compact, modern design of the multimeter.
- App even allows remote management if you sign up for an account (I have not tested this feature).
- Very fast shipping through DHL, only took 9 days to my place.
Other comments
- According to other forums, this multimeter uses mini fuses. These are smaller fuses and not the “normal” size. I haven’t opened the multimeter yet but I have seen mini fuses on ANENGs before.
Disadvantages:
- 2xAAA batteries mean you may run out of battery power.
- Bluetooth feature keeps disconnecting when weak AAA batteries are used, make sure to use eneloops or similar.
- Flashlight is not really useful, but I am sure our members have another light source.
- Logging is only for one measurement at a time, i.e. you can’t log temperature and voltage at the same time.
- Auto-ranging feature can be a bit slow. On one occasion it took several seconds when I checked the voltage on Li-Ion cells and AA cells.
Conclusion
I honestly love this multimeter for what it is. It may not have the feature set of more expensive devices, but if you want a compact digital multimeter that comes with bluetooth, app support, data logging and includes a nice design - this ANENG multimeter is a great choice.
Just in case I forgot to mention something, these are the marketing images from ANENG:
