The flashlight was sent to me from Banggood for review.
Here's the product's page for more info: Astrolux FT02S
Coupon Code: BGFT02S (27% OFF)
The flashlight comes in a normal cardboard box.
The flashlight is seated into laser cut foam for shipping protection.
Other than the flashlight, one finds the following included in the box
- User manual
- Wrist lanyard
- 2 x replacement o-rings
The FT02S comes in the following colors: Black, Green, Sand.
I chose to get the Sand color, as it seems very appealing to my eyes.
As you can see, the FT02S comes with spotless anodization and some pretty knurling along its body.
It's operated by a side-mounted e-switch.
The e-switch comes with an indicator LED used to inform the user about the battery's charge level as well as act an stand-by locator light.
Opposite to the e-switch we can find the charging port.
Of course, the port is water-proofed via a rubber flap that creates a tight seal.
The FT02S can be recharged via a regular USB Type-C cable.
Once plugged into a charger, the indicator LED will turn Red / Green to indicate the charge's state.
While charging a fairly depleted battery, I recorded up to 1.8A of input current.
The head makes sure of some thick heat-sinking grooves which helps the thermal performance of the flashlight.
A polished, smooth metal bezel is used to guard the flashlight's AR-coated glass lens.
The FT02S comes with smooth quad reflector and either 4 x SST-40 or 4 x XHP50.2 emitters.
I've chosen to receive the 4 x XHP50.2 option.
As can be seen, the centering of the diodes is excellent.
The tail of light is flat, which allows it to tail stand.
The driver is set in place via a metal ring.
A brass tab is used as the positive terminal in order to decrease the overall resistance.
The tail houses the rear spring and its PCB.
As can be see, the FT02S make use of dual thick springs.
The rear threads are very cleanly cut and arrived anodized.
The anodization allows the flashlight to be mechanically locked out.
The front threads are also nicely cut but without being anodized.
Thank to the two included adapter tubes, the FT02S can accept both 18650, 21700 and 26650 cells.
Notice that 26650 to 21700 adapter(left) has an o-ring in its upper part, which creates a very tight fit with the flashlight's body and prevents any rattling.
Here's a few photos demonstrating the use of battery adapters.
No adapter (26650) - 21700 - 18650
User Interface
The flashlight is using the Anduril firmware.
Here's a diagram demonstrating the majority of the available functions.
Performance
I got my measurements using a high-drain 21700 battery.
The flashlight uses the Anduril firmware, which means that the user is eligible to select any brightness between the Min and Max using the infinitely brightness feature.
| Level | Output | Current Draw |
Min |
<1 lumen | 1.40 mA |
Max |
12.450 | 36.1 A |
As you can see, the FT02S w/ 4 x XHP50.2 is able to push more than 12K lumen at turn-on.
Additionally, I went ahead and measured the stand-by current draw.
| State | Current Draw |
| Off | No Indicator LED | 25.8 μΑ |
| Off | Low Indicator LED | 47.1 μΑ |
| Off | High Indicator LED | 86.6 μΑ |
As expected, the Astrolux FT02S displays excellent stand-by drain, even when the indicator LED is set to full brightness.
Beamshots
Here's a few outdoor beamshots demonstrating the performance of the Astrolux FT02S.
