ok, so i was looking for a backup to my standard use headlamps… skilhunt h03 and nightcore hc50. i occasionally misplace them or forget them at camp, and need something to get me by till they turn up. i picked the Boruit D10 for the h03 and the BORUiT RJ - 020 for the hc50. this review is for the d10… ill get to the 020 after i use it more.
https://www.gearbest.com/headlights/pp_009648630372.html?wid=1433363
here is another review i saw that is, what i believe to be the same light, although it doesnt mention D10 anywhere.
this isnt a technical review. 100% amateur here. just some things i thought people should know… cause in general, im dissapointed. even for the money i spent.
PRICE: the d10 was $15.89. considerably less than the h03, and it shows. if i could do it again, i would have spent the extra money, but i also wanted something different.
PHYSICAL QUALITY: the first thing i noticed was the threads on the cap… idk the technical term, but they arent real threads. they are molded into the cap and the body. very wide, very shallow threads. in the 5x ive opened it, id say ive cross threaded it 3x. i fully expect them to fail.
STRAP: this is the second thing i noticed… its paper thin. about 1/3 the thickness as the h03 strap they really cheaped out here. i dont expect it to last long either. furthermore, the cams that are meant to keep it adjusted to your head… they slide on the strap so easily. if you have it on your head, it will stay put. but the instant you take it off, the adjustments flop around all over the place.
BATTERY: ive never seen a light that had so much horizontal play in the battery compartment. using my thickest protected 18650, i could take a business card and wrap the battery fully, even overlap the business card by 1/4”, and it would still slide in no problem. with just the battery in there, i can shake the light and feel the battery tap back and forth on each side of the compartment.
BEAM PATTERN: I wasnt to concerned about the beam pattern… as long as it put out light that is all that mattered. i do however, think the beam pattern is awful for headlamps. Its a reasonably narrow beam. a pretty solid hot spot in the middle, outside of that it is dim but usable light. that tapers off to the edge of the beam, and then right at the edge it actually gets brighter. lots of wasted light. id consider it a usable pattern for hiking around the woods, but for up close stuff, youre going to be turning your head a lot to keep it pointed where your eyes are looking, if that makes sense.
bottom line… IMO, it wasnt worth it. it might be worth 7 bucks. and im not picky… for a backup, i dont care about beam patterns, or max output, or internals(as long as they hold up). all i care about is durability for this light.
so what sums it up best is that i dont even trust this thing as a backup, and ill be getting another headlamp, possibly another d03 since i have such little faith in this thing.
