Just wanted to get this out quick. I received the BTU PK26 light today for review from RIC. I already provided him some initial impressions and feedback via pm. Though it originally was supposed to arrive a few weeks earlier, there were all sorts of delays: normal production delays, the LED I requested did not become available as soon as expected, then the last issue was stuck in customs for a few days .
So, without further delay, here’s some pictures.
Shipping box:
Product box, with instructions:
Champagne colored Pk26 surrounded by similar sized lights, 40-41 mm head diameter. Notice the 7 trit slots? Ok, I'm gonna fill them. To tell you the truth, I held off ordering them in case the light wound up being a dud, but overall I'm liking it!
Yes, it's a Pocket Rocket. Why? Because it says so:
Some more views:
This gives you an idea of relative length, compare to a Convoy/Roche F6 and Convoy S2+:
Here's a view of the driver. Yes, those two R100's on the left are the suspects to be mounted for more possible amps (speculating...):
Inside the pill, that's epoxy, not grease, and you can barely make out the bottom of the copper MCPCB, plus the rubber switch cover on the right:
Close-up of the driver mounted switch:
The stock LED: NW XHP-35 HI and MCPCB:
I removed the stock 3M isolator and used kapton tape to protect from shorts instead, hoping to get the LED in a little tighter to the reflector:
Here's the two piece battery tube - yes, there's a threaded connection in the middle so the tail end can be removed for a single 26350 cell:
Square threads on both ends:
More Photos
With the NiteCore 40 mm diffuser installed:
Wall shot (couch shot?) w/diffuser. I've always been impressed with this NiteCore diffuser, plus it adds nice rubber protection of the head, securely attaches, easy to get OFF and ON. Notice the nice, smooth white tone you get with a NW. The hot spot is essentially gone:
Same mode (hi) without diffuser:
The mysterious blue button - only viewable in dark places:
The short setup with a 26350 installed. The S2+ shorty is not so short here:
Here's some #'s. Now since this is NW HI version, lumens should be down somewhat, and throw up (what did I just say?). The OP reflector though is gonna knock down throw #'s a little.
Measurements
Ouput Measurements done on a LiitoKala 26650 5000 cell charge to 4.20v. Lumens measured using my PVC based light box with my original LX1330B meter:
- lo-lo: 9 lumens
- lo: 170 lumens
- med: 534 lumens
- hi: 993 lumens, throw: 21 kcd (290 meters), measured at 5m
- turbo: 1,600 @start, 1,470 @30 secs (lumens), throw: 32 kcd (358 meters), measured at 5m
- parasitic drain: measured 0.182 mA on both the LK 26650 and 26350 cells
- confirmed the light does drop down from turbo to hi at 2 minutes
- lumens and throw match up very close to the #'s above using a 26350 cell charged to 4.21v (no difference between a high drain 26650 and a 26350 cell)
- tail amps (clamp meter) using a LK 26650 @4.22v: 6.0A on turbo
- tail amps (clamp meter) using a 26350 @4.22v: 6.6A on turbo
- tail amps rises as the cell depletes, while it tries to maintain the hi and turbo level output
Initial Impressions
There are some issues, like the pre-flash, apparently in all production units so far reported, but I'm overall impressed by this little guy. We've seen a ton of lights in the ~40mm head size, all sorts, from the classic 4 AA lights like the NiteCore EA41 to the latest Crelant V4A, then there's the F13 and it's clones, and the X6 and D80. I like the Lumintop SD10 BLF Edition as well with a 32650 cell. But this light is shorter than them all, thinner tube than the head, and still packs a 26650, and with the new LiitoKala class 5000 mAh cells out, this light seems tailor made for them.
Pros:
- I like the finish and feel. Maybe it's the color, dunno, but feels like quality anodizing
- form factor is outstanding, fits my hand well
- The NW HI is a great looking tint - very white, smooth beam pattern. Maybe the OP reflector helps it out.
- decent performance (hoped for better though) - need to check amps to get a rough idea of how much power the boost driver is taking. The NW HI I have though would theoretically be the lowest lumens LED option
- the UI is decent, nothing too fancy, easy to learn though
- solid tailstander
- love the SS bezel
Cons:
- pre-flashes when turning on in lo-lo mode - very annoying. From OFF if you double-click, it goes straight to turbo, then 1 click OFF (no pre-flash)
- not a fan of the right angle driver mounted switch - they tend to bend back with use
- The digital lockout works, but not as described - RIC cleared that up -- Update: to enter lockout, hold the switch for 3 secs, then hold for 3 secs releases it. Double-click from OFF though is not locket out, though lockout remains in effect.
- not sure if the copper MCPCB is DTP - suspect it's not because of lack of a name brand
- no springs for the battery -- this means very limited on cell size, unless you are ok with not screwing the tail completely on. Actually if a spring adds a lot to the length, I might be against the spring and for leaving as-is. The LiitoKala cells seems to fit pretty good - fully threads the tailcap on -- I'm good with that
- though the threads are square, I did notice some metal shaving on edges, so the machining seems a bit rough, and some particles in the threads, probably metal fragments. I removed what I could and used Nyogel - they feel better now.
- threads are bare, not anodized - I think anodized threads are much cleaner. In fact I'm not sure if I ever saw square un-anodized threads in a quality light like this
- Added: The battery level indicator LED's are barely visible - the button cover is not translucent enough. Haven't tested low battery levels yet, but the blue LED is only displayed with the light ON, making it even more difficult to see
- Added: a 26350 cell has limited ability with this light. When fully charged, it can do the full two minutes on Turbo, but at some point (I tried at 3.76v), the cell can't function in turbo mode -- the amps draw spikes at 12 amps, then turbo drops to lo-lo mode quickly, and the RED indicator is lit, indicating low voltage. The normal 4 modes continue to work fine though after turning OFF/ON the light - blue indicator returns.
Accessories/Notes
- The NiteCore 40 mm size filters and white diffuser fits this light perfectly, listed here: https://www.fasttech.com/products/0/10018542/3838001-authentic-nitecore-nfd40-40mm-white-filter or here: http://www.batteryjunction.com/nitecore-nf40mm-opt.html
