[nb: waiting for pix to be “published” on Amazon so I can link to them]
I’ve always been a fan of the Sofirn SC31 family right from the original SC31, through the B version, then the Pro version, and now there’s the T (tactical, I presume) Special Edition. The deviation from the previous models is that instead of a single sideswitch to control the light, now there’s a set of sideswitch and tailswitch. The tailswitch controls on/off, including momentary-on (woohoo!), and the sideswitch selects the modes.
The name Csteboke might be a tongue-twister, but it’s essentially a Sofirn light, which to me is a good sign, as (full disclosure :laughing: ) I’ve been a fan of the Sofirn lineup for a long time. And true to form, this model didn’t disappoint. Why the name-change, I don’t know. ![]()
The T came in a sturdy cardboard box, lined with foam on the bottom. The light was suitably protected in a bubblewrap sleeve. With it was an envelope with extra O-rings and lanyard. A charging cable was also included. The 18650 cell was inside the light with a protective insulator (to keep the light from being inadvertently turned on in transit). Also, a printed manual was included, which gave a good outline of the light’s functions. So as usual, everything you need to get up and running is included in the kit.
First impressions of the light are excellent. It’s a beefy little light, quite solid. Fit and finish is excellent, ano is a perfect semigloss black, and with the exception of the deep-cut fins in the head for heat-dissipation, there are no sharp edges or points anywhere. Even the lanyard holes seem to be chamfered.
Knurling on the light is a fine diamond-cut. Grippy without “biting”. Along with the brand and model, etchings on the light are the CE, etc., markings opposite that, a little battery-symbol at the back showing which way the cell goes in, and the usual bacon-in-a-triangle on the head warning that it can get hot. I could personally do without all that graffiti on the light, but it’s probably some legal thing that requires it.
Yes, there’s usb charging! The rubber cover is really nice and thick, takes some effort to pull it out and even more to put it in (that’s what she said…), but it looks like it’ll stay in just fine and keep out dirt, dust, water, etc., from the charging port. When charging, the sideswitch light turns red, and when charging is finished, it turns green. The indicator also doubles as a battery-status indicator, which stays on a few seconds after the light is turned on. Green for good, red for low, blinking-red for critical.
The included 3000mAH cell clocked in at just over that (3010mAH, if I recall right), even on my pessimistic Opus. Nice!
The main attraction is the venerable LH351D LED, high-CRI (color rendition index) so it’ll show up colors quite nicely and accurately. Color temp is about 4500K by my estimates, a nice soft color that’s not too yellow, and nowhere near as harsh as those retina-scorching 6500K-7000K lights. Better still is that it’s behind an orange-peel reflector, so practically no artifacts that can happen with smooth reflectors. The beam is nice and floody, perfect for grubbling through cabinets, going for a walk, etc. I always found floody lights to be way more useful except for when I need a thrower, in which case I’d use one.
The UI (user interface) is pretty simple. The tailswitch does on/off. Period. The sideswitch handles all mode changes. When on, clicking changes modes/levels accordingly. There are 4 brightness levels in stepped-mode, and a continuously-variable level in ramping-mode. Doubleclicking gets you to turbo instantly, and a single click brings you back to your previous brightness level. Triple-clicking gets you epilepsy-mode with strobe, SOS, and beacon. I hate blinkies in general, but beacon mode is pretty amazing. It’s an incredibly-bright flash every 2sec or so, definitely an attention-getter. Quad-clicking toggles between ramping and stepped modes.
There’s also a shortcut to moonlight, namely by holding the sideswitch when turning on the light. This guarantees the lowest level of lighting, as to not ruin your night-vision. From there, you can brighten the light, vs starting from what could be an unexpected blindingly-bright memorised brightness level.
Negatives? I hate strobe and SOS modes, and they’re the first two options in blinky-mode. I’d prefer a way (similar to my Skilhunt M200) to be able to “lock in” a particular blinky (eg, beacon) so that it “sticks” until changed.
Also, in ramping mode, it seems to blow through lower brightnesses pretty quickly but lingers in the top end. I’d tweak the ramping algorithm to slow it down when dim and speed it up on bright, to make it visually linear. As a result, with most lights, I typically prefer stepped mode over ramping.
All in all, I’m pretty happy with the dual-switch interface. It’s pretty logical, and after using it a while, pretty intuitive as well. Plus, as far as the light itself, color is excellent, has high color-rendition, is hella bright, and has an excellent smooth floody beam. I’m impressed. ![]()
