Enlan EL-04 MCT
Reviewer's Overall Rating: ★★★★☆
Summary:
| Blade Metal: | 8Cr13Mov Stainless |
| Lock: | Axis |
| Handle Material: | Micarta |
| Length (open): | 203 mm |
| Length (closed): | 117 mm |
| Weight (g): | 141g |
| Price Paid: | $16.31 shipped |
| Date Ordered: | 01 Jan 2012 |
Pros:
- Big
- Fits hand well
- Sturdy
- Looks cool
Cons:
- Axis lock is stiff
- Movement is a little rough
Features / Value: ★★★★☆
I'm not a knife expert by any means, so I'm just going to write up a few things about this knife that I bought recently from ExDuct. It arrived inside a plastic wrapper in an Enlan box in about 4 weeks from ExDuct. I had previously bought the SanRenMu 763 and like it a lot, but it is kind of small. I had heard good things about the larger Enlan EL series of knives and my brother wound up buying a couple of them (EL-03 and L05). The EL-03 was quite heavy, but the rosewood L05 was about right. I saw the EL-04 MCT and was intrigued by the neat looking design.
It is basically an oversized 763 with the clip (unlike the 763, not reversible) and the axis lock. While the 763 has GRB leaves on the sides, this has Micarta, which seems to be basically the same thing. There are layers of black and grayish-green layers of fiberglass or whatever this stuff is. Then they machine it down a little with finger ridges and give it this natural looking grain look.
The blade is stainless steel 8Cr13Mov which is the same as the SRM. It seems pretty sharp to me and has some ridges on the back of the blade for a good grip. It fits my hand quite well, even though I am left-handed and the clip is kind of in the way.
Design / Build Quality: ★★★★☆
The light seems quite sturdy. The blade is well centered when closed and came very sharp. There is no play side-to-side. While some people have said the micarta handle is too slick, it is pretty well textured with diagonal ridges and shaped for fingers, so I think it offers a very good grip. The clip is quite stiff. There is a nice weight to this knife and a good form factor, though it is kind of big for EDC in a pocket.
The downside for me is the axis lock is very stiff and and the blade movement is a little gritty opening or closing the knife and bearing against the axis. The SRM is really smooth and the axis has a light enough touch to be moved with one finger. The Enlan really needs the axis pulled on from both sides. I don't know if this is just the price you pay for a bigger knife, but it seems a little much. The axis itself seems a little crooked looking down into the spine of the knife. I wonder if that is part of the problem.
In comparison with the smaller and lighter 763:
| SRM 763 | Enlan EL-04 MCT | |
| Length, open | 157 mm | 203 mm |
| Length, closed | 93 mm | 117 mm |
| Weight | 59 g | 141 g |
I showed this knife to a friend who hunts and likes knives. When I showed him the SRM last year, he asked me to order two of them for him. But with this knife he did not. He thought it was still a good value, but not something he had to have. He pointed out the indent at the base of the blade isn't big enough to get your finger into, but I think your finger is supposed to be back on the handle, not close to the sharp edge. He pointed out that while the blade is sharp, the angle makes the edge quite fine and subject to quickly dulling. I think this is true of most Chinese knives though.
Summary: ★★★★☆
Seems like a good knife to me. I like the snake skin sort of design to the micarta handle. It is comfortable and secure to hold. The axis lock is a little hard to pull back and the movement is a little gritty, but otherwise this seems like a first class knife if the SRM 763 seems too small.
