FandyFire S1-1 (1xAAA, XP-E R2)
Reviewer's Overall Rating: ★★★☆☆
Reviewer's Mod Host Rating: ★★★☆☆
Summary:
| Battery: | 1xAAA (0.8V - 1.5V) |
| Switch: | Tail Twisty |
| Modes: | H 100% |
| LED Type: | Cree XP-E R2 flux bin, est. 1B or 1C tint bin |
| Lens: | Standard Glass |
| Tailstands: | Yes |
| Price Paid: | Review sample from DX, reg. price was $10.30 |
| Date Ordered: | N/A |
Pros:
- Excellent finish, no scratches or blemishes
- Very good machining, good threads on tailcap and bezel
- Very good reflector, aluminum SMO
- Great tailstander
Cons:
- Driver/Emitter board is fixed in place, not easily modded
- Beam is not centered in spill, offset to one side
- Deep bezel blocks some spill
- Virtually impossible to operate with one hand
Features / Value: ★★★☆☆
Design / Build Quality: ★★★★☆
Battery Life: ★★★★☆
Light Output: ★★★☆☆
Overview
DX accidentally sent me the wrong review light (198768 is not equal to 198786) which they promptly addressed by sending the actual item. I decided to review this one anyway.
I was a bit surprised when I opened this up. It is a rather strange looking AAA light. The machining and finish on the entire light is very good . In short, the only slightly sharp edge is found on the body ridges. The anodize is nice and even over the entire light, including the threads. What is the strange (ish) part? It has a tiny 'foot' where a lanyard could go.
Compared to an AAA cell.
From the front you can see the nicely finished SMO reflector and XP-E emitter. What you cannot see is the alignment issue, that appears in the beam profile as an off-center beam. It's not a major functional issue, but definitely noticeable on a white wall.
The tail is nice and flat, good for tailstanding. Unfortunately, if a lanyard is in place, tailstanding will become a problem.
As with many 1xAAA lights, handling is a mixed bag. A big issue is one-handed operation; not gonna happen. The body is too smooth to allow a good enough grip. Also, the O-ring is very firm, making it even more difficult.
[In-hand shot to come soon...]
The light comes apart at the tailcap. No wrist strap was provided.
The threads on the tailcap end are nicely cut, smooth, dry, and anodized (a necessity for this light).
The tailcap contains a simple PCB with a spring on it.
The light can be torn down to get the lens and reflector out. The reflector seats directly onto the star around the emitter. There is an O-ring between the reflector and lens. The bezel is tiny and made of brass, adding a bit of shine to the front end.
The driver PCB is fixed in place somehow. I could not get it out without risk of breaking the light. The driver is a one mode boost that does not appear to support 14500 cells.
On the other end we can see the emitter is mounted right on the same PCB. No easy access to do an emitter upgrade or driver swap.
Beamshots
The beam is not bad, other than being slightly off-center. Of the three 1xAAA lights I have, this one has the smoothest hotspot.
High:
Measurements
Dimensions:
- Overall Length: 67.0mm
- Bezel Diameter: 14.3mm
- Body Diameter: 13.3mm
- Tail Diameter: 16.0mm, 19.9mm
- Reflector Inner Diameter: 10.2mm
- Reflector Outer Diameter: 11.9mm
- Reflector Depth: 7.7mm
- Reflector Emitter hole Diameter: 2.7mm
- Lens Diameter: 12.0mm
- Lens Thickness: 1.2mm
- Emitter star diameter: N/A
- Driver diameter: N/A
Weights (without battery):
- Overall: 12.1g
- Head/body tube: 9.4g
- Tailcap: 2.7g
Performance (stock, fully charged 1.2V AAA NiMH supply, uncalibrated measurement equipment):
- Light Output: ~54 lumens at start, ~50 after 30s
- Beam Intensity: ~400cd
Power Source Options: 1xxAAA, 0.9V - 1.8V.
Switch type: Twisty
Modes: High (0.9A)
Mode Memory: N/A
Conclusions
The FandyFire S1-1 is an OK keychain light, but not much as an EDC. A low mode and one-hand operation are important to me for EDC. It has a great finish and decent looks (if they grow on you). The output is as expected for a 1xAAA light. The price is reasonable if all you need is a keychain light.
As shipped, this light gets a 'middle-of-the-road' rating.
As a 1xAAA mod host, not recommended. The integrated driver/star, which is glued in place, makes this virtually unmoddable.
Thanks for reading! searchID8934
