I want to introduce UltraFire tactical flashlight models available on the GearBest
Specifications:
Brand: Ultrafire
Lamp Beads: Cree XM-L2 U2
Beads Number: 1
Lumens Range: 500-1000 Lumens
Luminous Flux: 950 LM
Color Temperature: 6500-7500K
Switch Type: Clicky
Switch Location: Tail Cap
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Battery Type: 18650
Battery Quantity: 1 x 18650 battery (not included)
Mode: 5(High-Middle-Low-Strobe-SOS)
Waterproof Standard: IPX-6 Standard Waterproof
The flashlight look tactical. Slightly smaller than the size of the convoy C8.
Battery uses a piece of 18650.
It’s got beautiful (zombie) green tail switch is GITD.
The body is connected to the pill screwed. Protected against rolling.
Pill is equipped with original CREE XM-L U2 LED. Better cooling than P60 dropin.
The bezel pushes down the OP aluminum reflector.
Everywhere there are rubber seals, protected against water.
The lamp heats up during use, so probably a good heat conductivity.
Light slightly bluish, no distractions like latticebright cheap fakes.
Unfortunately, there is no mode memory. Always start the next mode.
Measurement results:
High: 2,15A
Medium: 1,05A
Low: 0,47A
Weight without battery: 127g
Body lenght: 135mm
Maximum diameter: 43mm
Use uncoated glass plate on the head.
Pros:
tactical look
good cooling
good quality
cheap
looks waterproof
usable without modification
Cons:
No mode memory
Mid and low mode pwm
First generation CREE XM-L LED
Convoy C8, UltraFire 950LM, UltraFire WF-502B, Convoy S2+
Conclusion:
I liked this model during use. It is not as much power as Convoy C8, yet surprisingly high brightness. Hotspot no contrast due to the OP reflector. There is scattered light, but the hotspots good throws. Cheaply is a good thrower torch!
Comparative images in mid mode:
Comparative images in high mode:
Thank you for reading this, I apologize for my bad english.
A full review can be found on my blog. The site has a built-in google translator in the lower left corner of the page.
