Welcome everyone to my first review!
Sorry for my english, I never learned.
I want to introduce UltraFire tactical flashlight models available on the GearBest
Specifications:
Brand: UltraFire
Emitter: Cree XM-L2 U2
Lumens Range: 500-1000Lumens
Luminous Flux: 885LM
Color Temperature: 6500-7500K
Switch Type: Clicky
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Battery Type: 18650
Battery Quantity: 1 x 18650 battery (not included)
Mode: 5(High-Middle-Low-Strobe-SOS)
Waterproof Standard: IPX-6 Standard Waterproof
This light like a tactical prototype. Size slightly larger than s2 +. Battery uses a piece of 18650. It’s got beautiful (zombie) green tail switch is GITD.
Water resistance promises ipx6, rubber sealing ring found everywhere.
The flashlight uses P60 dropin. This is good because it is possible to swap.
Light slightly bluish.
High mode no pwm, middle and low PWM can be seen in the camera.
Unfortunately, there is no mode memory. Always start the next mode.
Measurement results:
High - 1,97A
Mid - 0,96A
Low - 0,43A
Weight without battery: 106g
Body lenght: 136mm
Maximum diameter: 35mm
Use uncoated glass on the head.
The flashlight heats up during use, so probably a good heat conductivity.
OP reflector is integrated, so there is no strong hotspot.
Anodizing seems good quality.
Pros:
Tactical look
P60 dropin
Good quality
Cheap
Looks waterproof
Usable without modification
Cons:
No mode memory
Mid and low mode pwm
Conclusion:
It is a good tactical lights! It also looks great, it seems quite good quality. Driver swapped it can be useful for edc flashlight.
A full review can be found on my blog. The site has a built-in google translator in the lower left corner of the page.
