The Nitecore HA23 UHE in the three available colors were sent to me directly by Nitecore for review.
For the description, technical data and purchase:
https://nitecorestore.com/collections/n … a-headlamp
Nitecore has recently introduced the HA23 UHE headlamp, which takes its name from the previous model but with new technology and performance. The HA23 UHE is released in three different colors: Black Rock, Fog Blue and Myrtle Green.
The Nitecore HA23 UHE headlamp is a lightweight product that offers good performance ideal for indoor or outdoor applications such as camping, trekking and small excursions.
The HA23 UHE offers a self-developed lighting system with multiple color temperatures in all primary lights with optimal illumination in any situation thanks to the MCT (Multiple Color Temperatures) technology that offers both multiple color temperatures and, together with a high luminous efficiency of the UHE system, meets the different needs of outdoor lighting.
The new headlamp can operate powered by a 1500mAh Li-ion battery (HLB1500) (optional) or by three AAA batteries with a maximum autonomy of up to 125 hours.
HA23 UHE uses a unibody optical system with a wide field of view with a maximum power of 600 lumens for an intensity of 4,364cd and covers a maximum distance of 132 meters. It has 2 buttons for complete management of the torch, 4 levels of primary white light + 3 special modes (SOS, Beacon and Red Slow Flashing) and 2 levels of auxiliary red light.
On the body we find, under the LEDs, 4 LEDs remaining charge indicators. Nitecore HA23 UHE has a protection rating of IP68, 2m (waterproof and submersible) with an impact resistance of 1 meter.
Key Features:
• Max output of 600 lumens
• Utilizes dual-core UHE MCT (Multiple Color Temperatures) LEDs
• Equipped with primary lights with 3 color temperatures (3000K warm light / 4500K neutral white light / 6500K cool white light)
and auxiliary red lights
• Utilizes a multi-faceted unibody optical lens system
• Max throw of 132 meters
• Max runtime of 125 hours
• Compatible with NITECORE HLB1500 lithium-ion battery pack and various AAA batteries such as alkaline, Ni-MH and lithium iron batteries
• 3 AAA alkaline batteries included
• Designed with two different shape and touch buttons, which provide easy one-handed operation
• 4 brightness levels, 3 special modes and 2 brightness options for red light
• All new power indicators for intuitive power indication
• Made of special PC plastic with shock and low temperature resistance
• Shockproof up to 1 meter
• Waterproof and dustproof rating compliant with IP68 (submersible up to 2 meters)
Note: Maximum runtime is measured using a NITECORE HLB1500 lithium-ion battery pack.
Specifications:
Dimensions: 60.2 mm x 46.7 mm x 34.2 mm (2.37″ x 1.84” x 1.35”)
Weight: 90g (3.17oz) (3xAlkaline AAA and strap included), 56g (1.98oz) (Battery Pack and strap included)
Warranty:
Any DOA/defective product can be replaced through a local distributor/reseller within 15 days of purchase. After that, all defective/malfunctioning NITECORE® products can be repaired free of charge within 60 months from the date of purchase. Beyond 60 months, a limited warranty applies that covers the cost of labor and maintenance, but not the cost of accessories or replacement parts.
Note: The declared data is measured using 3 x 1.5V alkaline AAA and Li-ion battery HLB1500 (1500 mAh) according to ANSI/PLATO FL 1-2019 standard. The data may vary in real use due to different environmental conditions.
PACKAGE and ACCESSORIES:
Nitecore HA23 UHE arrives in a brown cardboard box. The main features of the new headlamp are specified on it.
In the small box we find: Nitecore HA23 UHE with headband, 3 x AAA Alkaline Batteries, Diffusion Bag, Clip and manual (multilingual).
The sales package contains two useful accessories: The Multipurpose Clip in plastic to be inserted after removing the elastic band, and the bag for storing objects/diffusers.
The 4-way Clip can be positioned in multiple directions, attached to the shoulder strap of a backpack or to a hat.
The Bag included in the sales package transforms the headlamp into a camping lantern or an ambient light.
The removable, lightweight and easily adjustable elastic headband ensures good breathability and comfort. The band is reflective with a silicone strip inside that improves grip and deflects sweat to the sides of the head away from the eyes.
The Nitecore headlamp can be tilted 90° with one hand through 5 clicks. The mechanism works well even when stressed for example by running.
Nitecore HA23 UHE is made of special PC plastic (polycarbonate) with high mechanical resistance to impact and low temperatures and is equipped with IP68 protection rating. The weight, including the elastic band, is 90 grams (with three AAA Alkaline batteries) and 56 grams with the Battery Pack. Once adjusted on the head, the Nitecore headlamp is light and does not tire.
The optical assembly of the Nitecore HA23 UHE, which uses a TrueVision+ optical matrix lens system (minimal light loss and improved reflectivity) and dual-core UHE MCT LEDs (multiple color temperatures), is equipped with primary lights with 3 color temperatures (3,000K warm light, 4,500K neutral white light and 6,500K cool white light) as well as auxiliary red lights.
This solution is an added value for this product since it covers almost all preferences in terms of beam color.
HA23 UHE ha una potenza massima di 600 lumen con una gitata del fascio massima di 132 metri.
Under the optical group there are 4 power indicator LEDs, which can be called up via the MODE button, which indicate the remaining charge of the battery or batteries.
On the upper part there are two plastic switches; on the left the “MODE” button and on the right the ON/OFF button, for the complete management of the user interface. To activate the switches you need to use quite a bit of force as they are not very raised, almost flush with the body. Under the two buttons we find the writing that reminds us how to insert or remove the electronic lock.
Nitecore HA23 UHE can be powered by 1500mAh rechargeable lithium battery (HLB1500) (optional), 3 x AAA alkaline batteries (included) or AAA rechargeable Ni-MH batteries.
Along the edge of the battery compartment we find two gaskets for protection from water and dust.
Nitecore HA23 UHE is certified IP68 (2 meters submersible).
Nitecore HA23 UHE next to other headlamps
Starting from left: Nitecore NU32, Zebralight H604c, Nitecore HA23 UHE and Nitecore HC68.
USER INTERFACE (UI):
Nitecore HA23 UHE has 2 buttons to manage the front light with 4 levels of primary white light + 3 special modes (SOS, Beacon and Red Slow Flashing) and 2 levels of auxiliary red light. All these functions lead to a learning of the user interface
not immediate even if a little practice is enough to remember everything. I sometimes found the two switches a little hard to operate that I would have preferred rubber and raised. Good spacing of the levels with the Ultralow light output that I would have preferred from 1 lumens. Nitecore HA23 UHE does not have a memory function.
Power button / MODE button
• The power button is used to turn the light on/off and adjust the brightness levels.
• The MODE button is designed to change the color temperatures.
On/Off
• When the light is off, long press the power button for 1 second to access Neutral White LOW.
• When the light is on, long press the power button or MODE button for 1 second to turn it off.
Primary Light
• When the light is off, long press the power button for 1 second to enter Neutral White LOW.
• When the light is off, double press the power button to enter Neutral White ULTRALOW.
• When the main light is on, short press the MODE button to cycle through “Neutral White - Warm White - Cool White”.
• When any color temperature of the main light is on, short press the power button to cycle through the following brightness levels: LOW - MEDIUM - HIGH.
Auxiliary Red Light
• When the light is off, long press the MODE button for 1 second to enter Red LOW.
• When the red light is on, short press the power button to switch between red LOW and red HIGH.
Special Modes (SOS / BEACON / SLOW FLASH)
• When the headlamp is in any state, double press the MODE button to enter SOS.
• When one of the special modes is active, short press the power button to cycle through the following sequence: SOS - BEACON - SLOW FLASH. Double press the MODE button again to return to the previous state.
Lock / Unlock
• When the headlamp is off, long press both buttons for 2 seconds until the headlamp flashes 3 times to indicate entering the lock mode. In the lock mode, all brightness levels or special modes are unavailable and the headlamp will flash once to indicate this state when either button is pressed.
• When in the lock mode, long press both buttons for 2 seconds again until Neutral White ULTRALOW is activated to indicate the unlock state.
Power Indication
When the light is off, short press the MODE button and the corresponding power indicators will light up in turn and turn off after 2 seconds.
Indicator Status Power Level
4 LEDs On 75% - 100%
3 LEDs On 50% - 75%
2 LEDs On 25% - 50%
1 LED On 0% - 25%
BEAM and RUNTIME
Nitecore HA23 UHE is an innovative headlamp in the management of the light beam thanks to the recent MCT (Multi Color Temperatures) system it has. Now it is possible, in the three main levels, to choose the preferred color temperature between neutral, warm and cold light.
The light emitted has a good uniformity and the beam with a wide illumination range of 100° offers a wide vision both from far away and near.
HA23 UHE also features 2 auxiliary red light LEDs that effectively preserve night vision without attracting mosquitoes and insects and when flashing are useful for emergency warning or response.
With the OPPLE Light Master Pro, a fairly precise device even if not calibrated, I measured the value of the CCT color temperature, of the Ra color rendering. The Flicker is in the green band not at risk.
These are the values found for the Nitecore HA23 UHE with primary white light:
Cool White Light: Color temperature (K): 6216 - Color rendering index (Ra or CRI): 71.9 - Duv = -0.0031
Neutral White Light: Color temperature (K): 4468 - Color rendering index (Ra or CRI): 70.4 - Duv = -0.0034
Warm Light: Color temperature (K): 3312 - Color rendering index (Ra or CRI): 69 - Duv =0.0060
The table below shows some peak candela (cd) values taken with my Luxmeter in reference to the 4 levels High, Medium, Low and Ultralow for the three color temperatures, Warm, Neutral and Cool.
Runtime tests were done indoors using 3 Duracell AAA Alkaline batteries in the High (600lm) and Medium (280lm) light levels. The values were taken with the LX1330B Luxmeter with Lux/1m (cd) measurement.
I would like to point out that the values expressed in the graphs must be taken, above all, as a reference because they were made with means and environmental conditions different from those used in the laboratory. The measurement made with the Luxmeter reports the values in Candela (cd) and not the expressed brightness.
The runtime times declared by Nitecore seem to be effective. Soon, as soon as it is sent to me, I will do another test with the 1500mAh battery pack (HLB1500) which I will then add to the review.
VIDEO
CONCLUSIONS:
Nitecore HA23 UHE is the latest headlamp released by Nitecore, innovative in the management of the light beam thanks to the recent MCT system (Multi Color Temperatures) that allows, in the three main levels, to choose the preferred color temperature between neutral, warm and cold light.
Nitecore HA23 UHE has a maximum light output of 600 lumens and is powered by a proprietary 1500mAh lithium battery (HLB1500), optional, or by easily available AAA batteries. The beam has good brightness with a wide illumination angle.
Nitecore HA23 UHE is offered in a complete package that includes 3 AAA alkaline batteries, to use the headlamp immediately, and two practical accessories; the clip that allows you to attach it to the shoulder strap of a backpack or the visor of a hat and a lamp bag that can also be used as a diffuser, transforming the headlamp into an ambient light camping lantern.
The auxiliary red LEDs are also useful and are appreciated in particular situations where the white light is disturbing or too visible. The user interface (UI) is a bit complicated at the beginning due to the numerous possibilities of use and the lack of a memory function.
In conclusion, the Nitecore HA23 UHE is quite bright and is an excellent choice for those who do outdoor activities such as trekking and trail running thanks also to its light weight and good autonomy, allowing you to switch between three different color temperatures, thus improving visibility in various environmental conditions.
------ My YOUTUBE CHANNEL ------------------------------------------------
