Well, I received my KD C8 5 mode with LOP reflector (http://www.kaidomain.com/product/details.S009844) and tested it last night. This is only my second Chinese budget flashlight, and my first one over 150 lumens. I got a black tailcap and my driver looks exactly like the one shown in post #514 above. My lens was rattling so I did the "loosen the pill" trick to make it tighter. Since this is my first "high-powered" LED light I can't compare it to another to estimate output (lumens).
For tailcap currents I used a cheap Harbor Freight DMM (one that sounds like many of you have) as well as an "Elenco" branded DMM that I built myself from an electronics kit back in 1994 in high school electronics vo-tech. Here are the meters:
At first I thought that I got an under-driven one like many of you which also seemed to agree with the specs of the driver - a max of 2A on high. Then I started testing with the second meter and swapping test leads and found some very interesting results. Lastly I used an 18" piece of scrap 14/2 AWG Romex as makeshift test leads. Battery is a brand new Trustfire flame 2400mAh 18650 which was freshly charged a few hours earlier. At the time of the readings the battery read 4.13v. Here are the readings:
H. F. Meter
Hi: 1.96A
Med: 0.96A
Low: 0.09A
Elenco Meter
Hi: 2.62A
Med: 1.29A
Low: 0.12A
H.F. Meter w/14 AWG wire leads
Hi: 2.66A
Med: 1.26A
Low: 0.12A
Elenco w/14 AWG wire leads
Hi: 3.04A
Med: 1.44A
Low: 0.14A
H. F. Meter w/ Elenco's test leads
Hi: 2.31A
Med: 1.10A
Low: 0.10A
It appears to me that the cheap Harbor Freight meter is nearly worthless for current measurements. I think I also need to make my own test leads out of some good wire. (I'll also order the DX test leads recommended by many.) Am I safe to assume that the highest current measurements I am getting are likely the most accurate? Why would the driver be listed as "2A" if it's really putting out 3A? (If I don't get much response here than I'll post this as a separate thread.)
Garry
