Hi
This is a light i just purchased from Princess Auto for $29.99Cdn. It is a 1x18650 light, 3 mode, rated 8 watts, and comes with a battery and charger. The 18650 (1200mah) has no name but says it is protected. The charger is Model # SW-042060 rated output 4.2v 650ma. It takes about 2 1/2 hours to fully charge a depleted battery
It is brighter then any other light i have, though i dont have a lot. The package says it is made by H.B. Smith Tools, but i could not find it on their web site. It looks similar to a Palight C8 reviewed here on BLF, but with a different Cree LED.... i think it is an RE but i could be wrong. It has a smooth alluminum reflector. The ends have O-rings, and it generally seems to be of good quality, but as the pictures show, there is some left over debris in the pill.
Here is the driver board (marked CX 152) and schematic i drew.
The Mode chip, is a CX 280 and the regulator (or perhaps just a MOSFET) is marked A1sHB (the "s" has a dash over it). i could not find any info on the driver or chips . The chips are 3pin. Beside the main output to the LED, there is also an "opitional" +output through 4 paralled 1ohm resistors ..... possibily for use if a less powerfull LED were used with the driver. Perhaps someone more knowledgeable knows who makes the driver and chips. Oh, the driver is about the size of a dime... i did not have a ruller handy.
With a full charge, it starts out on high at 1.22 amps, is very bright, and will opperate for about an hour without to much loss of brightness, until it just dies.
Low power draws 192ma, and is still fairly bright compared to other small lights i have.
Strobe, is a fast strobe at full power... i measured 65ma, but because of the strobing, i would guess that reading is not accurate.
Other shots ..... i would appreciate it if someone could tell me what Cree LED they think this is. My GUESS is an RE
Lead soldering to the driver and Cree seems to be quite very poor quality.
