Brass 18650 XP-G2
Pros: Small, bright, well driven
Well spaced modes with no blinkies
NW tint (my first)
Smooth beam with no artifacts
Good knurling
PWM at 4.6kHz
Cons: Temperamental tail cap threads
Mode switching seems to need a double tap
Does not fit protected cells
Uses PWM
Price paid: $42.00 (now priced at $29.00)
Specs from vendor:
Emitter: CREE XP-G2 3B NW (14mmx1mm PCB)
Material: Brass
Battery: 1x Unprotection 18650 ( not included)
Current Regulation
Current Setting: 1.4A 100%>25%>2%
Modes: Lo>Mid>Hi; With mode memory
Tail Cap Click Switch; Made of brass;
Toughtened Glass lens
Tail Stand Available
Net Weight: 75 G
Size: 97mm x 21mm
I have a weakness for shiny flashlights and have several in Brass, Ti, CU and SS, so I knew I had to have this one as soon as I saw it. It arrived very well wrapped in several layers of bubble wrap inside a sturdy brown cardboard box that was not crushed or mangled the way we have come to expect.
Out of the box it came with good o-rings and was lightly lubed. I popped in a fresh cell and measured (H)1.4A (M).350A (L).030A. High and Medium are fine outdoors and I use Low most of the time indoors. It stays cool to the touch on low and only mildly warm on Medium. It was still comfortable to hold after tailstanding on high for five minutes.
Knurling on the bezel and head area provides a good grip, but most of the body is without it and so can be a little slippery. But the light is small enough that I grip it with thumb and forefinger at the head so it isn't really a problem.
Very slight machining marks are visible but to my eye are in no way unattractive. I've handled it a lot since
these photos were taken and the mostly smooth body has developed a nice patina.
Tail cap has plenty of grip.
The star has a white TIM paste that is still quite fluid. It seems to be doing its job because the light heats up quickly when used on high but never becomes too hot to hold.
My main nit to pick with it is the very finicky tail cap threads. They are much coarser than those on the bezel/head,
but while the bezel screws on easily, the tailcap does not. I have to turn the cap counter-clockwise until I hear/feel the threads align, but even that is not reliable. I've found that fresh lube on the threads helps make aligning the threads a bit easier, and even so care must be taken to avoid damaging the threads. Both head and tail threads are butter smooth, it is just that the tail threads are difficult to get started.
Even the switch cover is brass, but is nicely sealed - see second photo below.
The copper springs are stiff enough to do the job but are short and have little travel, so this light doesn't like protected cells. However the mostly brass and copper tailcap construction helps give it the lowest tailcap resistance of any light in my collection - a miniscule .006 Ohms.
At the price I paid I'm very happy with it and with the reduced price I think its a steal! I'm very tempted to get another.
From the above left, lights 1, 3 and 5 are from Peak LED Solutions and, of course #2 is the well known Maratac AAA in cu.
The money shot. I was expecting a floody light along the lines of a P60. But the XP-G2 lets this small reflector throw a surprising amount of light
Its not very deep but the LOP gives it a nice smooth beam and the 3B tint is very nice. This is my first LED without a CW tint and I am liking it a lot.
I've only had the light for 17 days but the patina is developing nicely. I usually keep my brass and copper lights shiny but I want to see how it looks after a month or two of handling without being polished. The next two photos were taken this afternoon.
