Intro
Lumintop is pretty well known around here for producing the FW series of lights (FW3A, FWAA, etc) and also an interesting lineup of throwers that all started with the BLF GT (or “Giggles” if you’re so inclined). Today’s review unit comes from the former lineup - a newcomer to the FW series, the FW1AA. If you wanted to put some meaning behind that, “FW” is for Fritz Works (the original designer of the FW3A body), “1” is for being a single LED (not a triple), and while the “A” in FW3A was for Aluminum, you could venture to say that the “AA” in FW1AA is for this being an AA-sized light, even thought it only accepts 14500 batteries, not alkaline or NiMH.
FlashlightBrand approached me about reviewing the Lumintop FW1AA, of course I had to say yes - I can’t deny exploring a new installment of the FW series. A big shout out to FlashlightBrand for providing the light for the review. Note: aside from providing the light, no other compensation has been provided, nor have they put any other stipulations on the review (eg, giving it so many “stars” or saying particular things about it… nothing of the sort).
Packaging
Like many other Lumintop FW-series lights, the FW1AA arrived in a 2-piece brown cardboard box with a foam insert. The foam is cut out to hold an array of goodies: flashlight, manual, clip, spare o-rings, and a battery.
Build Quality & Usage
The FW lights have a very recognizable design language. This is instantly picked up as being a member of the family, its the little fireball brother of the original. The anodizing and machining are very clean and well done. The captive 2-way clip provides good assurance that it’s not going anywhere. There’s a lone e-switch in the tail, whose signal is carried to the driver via the dual-tube design. The metal switch button features that cute little bunny that we all know and love.
LED & Beam
The Lumintop FW1AA comes in your choice of three emitters:
- Osram KW CSLNM1.TG 6500K
- Nichia 219CT 4000K
- Luminus SST20 4000K
Mine arrived with the Osram CSLNM1.TG. This is the go-to LED for throw as long as you don’t mind the cool-white, average-CRI beam. If you prefer warmer, high-CRI you might want to check out one of the other LEDs. The Osram model is spec’ed at 27kcd for 329 meters of throw. I measured mine at 27,475cd at turn-on and 24,150cd at 30 seconds… so very close to spec. My Opple Light Master provided the following info:
User Interface
The UI is Anduril 2. That means you have access to all sorts of modes, configurations, etc. Too complicated for you? Check out the Simple UI. Not sure what all the fuss is about Anduril 2 or how to use it? Refer to this post for more information.
Batteries & Charging
The Lumintop FW1AA came with a Lumintop-branded USB-C rechargeable 14500 battery. It performed really nicely and its really convenient having the integrated USB-C port. Not worrying about having a Li-ion charger around is great, especially when you’re traveling. I observed a 2.1 watt charging speed, completing the charge cycle in 2 hours and 44 minutes. Note that alkaline AA batteries and NiMH are NOT compatible.
Performance
Lumintop rated this light at 700 lumens, which seems accurate as long as we’re talking about turn-on values or you have the thermal limit cranked up. In the (thermally calibrated) default config with the 45C limit, the FW1AA (like many Anduril lights) starts ramping down pretty quickly. Overall, performance was good and it acted just like you would expect of an Anduril-based FET+1 flashlight.
Verdict
Lumintop has really cranked out a lot of new FW-series models over the past few years. At this point, there has got to be a size and feature combination to suit most use cases. For me, I’m glad to finally see a AA-sized single-emitter version because that’s my go-to config for EDC pocket carry. I personally find that to be the optimal size for being unobtrusive in my pocket, and the single-emitter version (especially with the Osram KW CSLNM1.TG) can throw a bit when you need it to. The USB-C charging 14500 battery means that I never have to worry about getting stuck with a dead battery and no charger. All in all, I think this is a pretty sweet little package. I would be amiss if I didn’t give a final shout-out to FlashlightBrand for providing the flashlight for this review!
Links (non-aff)
