No, cutting the bend off wont increase the grip of the clip.
I agree the clip does not have strong retention. Maybe in the future there will be a better option. The clip location does not ride on any knurling, the grip is only against smooth surfaces. The clip is also not deep carry enough, for my liking.
you could try bending the clip to increase pressure, but it wont solve the lack of deep carry, and it will still be riding only on smooth surfaces of the light. So I dont think bending will produce meaningful change, but here is a visual for you to consider:
Meanwhile, Ive been entertained experimenting flipping the body (right pic), which I like. I also experimented flipping the clip (middle pic), which I also like, but the light wont turn on that way.
Thank you for a detailed reply
I have already preloaded the bend as much as I feel safe to (without bending excessively) and I feel like if I bend it any further I won’t be able to tighten the tail cap down without cross threading it
I LOVE the flashlight
I HATE the clip and am afraid or it popping out of my pocket and losing it
I’ll keep looking for an alternative solution
Thanks for all your help
I agree, and hope some accessories come along, including a better clip with deeper carry, and a glow gasket
suggestion to test
if you move the clip between the head and body (and if the light still turns on)
it will make the clip slightly more deep carry, but still not tight grip.
I would use the clip under the head, if it made contact, but no luck.
I stayed up late learning to set ceilings and floors.
1. My simple mode now has a ceiling of 200 lumens (72 steps down from 150), and 24 steps, just like an HDS. That max output is sustainable, does not trigger thermal step downs. I like this sustainable output option.
2. My advanced mode now has a ceiling of 550 lumens (50 clicks down from 150). also 24 steps. That max output is NOT sustainable, it triggers the 45C default thermal step down, and goes down to 90 lumens, sustained… Not ideal.
3. I set manual memory to 10 lumens using my light meter (it is step 10 of 24)
4. Calibrated the thermosensor, am still using default 45C thermal step down.
5. Battery check is great, it reads 0.1v low, which I like. Im leaving voltage calibration stock.
6. To determing when Im in simple mode, I do a battery check, 3C from off. IF the battery check turns off after the first readout, the light is in Simple… IF the batt check repeats in a loop, Im in advanced.
At this point, the practical difference between advanced and simple (besides ceiling), is that when I want to use a strobe to alert traffic, while crossing the street, I must be in advanced. I have strobe set to bike flasher, there is no strobe in simple.
I have zero interest in any of the candle and lighting modes… random flickers and flashes really bother me.
FWAA Anduril2 non standard commands trivia:
1. the temperature config position in the menu, it comes 3rd, after battery check and beacon
2. in advanced, 2C gives ceiling, but a second 2C does not work to go to Turbo. I dont mind… 1000+ lumens of Turbo for 3 seconds is not necessary for my application. Momentary Turbo is still available from Off with 2H
Here is an edited Lux Perpetua FWAA Anduril 2 UI flow chart:
I made 3 changes, in blue…
moved FWAA temp config to 3rd position
blocked out 2C to turbo in advanced, with a blue box
I put the number 3 instead of a 2, in the ceiling and floor config menu, for the step count
Im enjoying the FWAA very much, presently running in Simple Stepped mode with the body tube reversed (gives a better grip imo):
I painted some glow paint around the inside of the head (onto the plastic ring). It works, but a properly fitted glow gasket would be better.
Sorry, I guess I explained myself wrongly. When I meant under the bezel it was really under the bezel, not between the head and tube.
I am not sure if it can be done in the Cu version…
As for running it with the tube inverted, I tried to do it on mine but it doesn’t turn on. I guess it may be related to the internal tube, eventually.
I am glad you are liking it and that you “found” your optimal confirgurations for it
thanks for the photo,
that option is a bezel up carry… will think about it…
under the head would allow bezel down carry…
Have not decided what LED mod to use yet, the SST-20 is pretty nice as is.
before I decide…
Im waiting for azhu to restock 219b 3500k, which is slightly more pink than the SST:
hard to capture in a photo, the difference that I see with my eyes. The SST is slightly greener and cooler than the 3500k 219b.
The SST is not obviously green, like I feared. Its quite nice.
Cool, glad it helped It was an experience but I am actually fond of it too!
Yup, this option I’ve shown is not suitable for bezel down carry, it would need to be a longer clip for that.
I do like, though, that it won’t burn pockets since it is bezel/light up. It can activate accidentally, of course, given the switch can be pressed by things inside the pockets. There is no perfect solution with this clip :zipper_mouth_face:
Hum, I only have 2 lights with SST20, but I guess all of them will always have some green that the Nichias don’t have.
A 3500K Nichia will look great on that Cu version, so if you go for it, please show it to us then
yes
the internal tube has a lot of resistance to sliding towards either end
by tightening the tailcap onto the “head” (the flared end) of the body tube, with the clip installed, I was able to push the inner tube towards the “tail” (not flared). Now it works with the head on the flipped body. As pictured: (light is ON to show it works)
Hey jon_slider, congrats on getting your first Anduril UI flashlight! And thanks so much for the comparative beam shot photos. I’ve got one of these on the way as well. Very encouraged by the emitter tint. I was worried there might be a greenish tinge but it’s obvious that it’s more golden in color. A nice pale golden that’s closer to neutral than it is to full-on warm. That’s pretty much what I’ve been looking for in an AA sized EDC. There’s also something nice about sleek copper like this, as opposed to chunky, busy designs.
I’ve purchased multiple lights/items from Jared and never had issues. He’s awesome to deal with. He got burned once from paypal, that’s why he doesn’t accept it anymore.
That being said I already have two on the way lol.
