It’s been a long time since I have tested a Lumintop Light. Today I have the Lumintop ODF30 to take a look at. It’s a palm sized flood light that runs off of a 26650 battery using a Cree XHP 70.2 LED for an impressive 3500 lumens in Turbo. Thanks to Banggood for sending this to me, let’s take a closer look.
Full Image Gallery: https://imgur.com/a/jcyMafN
YouTube Version of this Review: (How do you like my new background?)
Packaging
The Lumintop packaging is very nice. The ODF30 comes in a nicely refind brown box with some details on the rear, the accessories including extra orings, orange lanyard, and holster are in a small separate box. The light itself is in a custom fit foam insert with a piece of clear plastic covering the lense. A 26650 battery is not included.
Construction
This light is made from aluminum and is finished with a dry flat black anodizing. Starting at the tail cap, It is flat and non magnetic. The light does tail stand well. Grip on the tail cap and body is blocky. It’s large milled squares in what I would call medium grip. It’s a unique look that I have not seen many other lights. The light doesn’t have any anitroll features built in.The light does come into two pieces, as it’s glued to the head.
The button is a positive click, covered by a rubber button. The head itself has quite a bit of groves for heat dissipation around it. On top the light has a polished steel bezel that’s smooth. The lens is a clear fairly thick mineral glass that’s not anti reflective coated. There is the signature Lumintop Red Oring that’s visible too.The reflector itself is pretty deep and has a nice orange peel on it. The LED below is nicely centered with a large dome on it.
Threads are square cut and anodized. My orings were greased but the threads were not. There is only one spring in the light connected to the driver board. The tail cap has a proud brass contact. Batteries are installed with the positive side facing the front of the light. I was using a KeepPower Protected 26650 and it’s a bit too long and dented the positive end slightly.
Length, Width, Weights, IPX
Maximum Length lenght is 119.5mm, maximum diameter at the head is 42mm, minimum diameter is 29.32mm on the body. Weight with the KeepPower 4500mAh battery I was running is 236 Grams or 133 Grames without battery. The light is rated for IPX8.
LED + Temps + Runtime
This light uses a Cree XHP 70.2 LED in cool white. It has a large dome on the LED. The LED didn’t have a Cree Rainbow as other XHP 70’s I have had have. Edges on the beam shots were fairly well controlled and it’s mostly a flood beam.
Runtimes were impressive for the ODF30. Turbo is timed to 3 minutes during which time it heats up. High lasted quite a while at about 20 minutes. Output did sag a little (still above 90% relative output) but before it stepped down to middle output. Middle output was about 140 minutes at about 65% output. At the end instead of stepping down and running on low the light seems to do a flashing a few times and shutting off. When it shut off it was still pretty warm to the touch, borderline uncomfortable. I used a KeepPower 26650 battery with this light that was rated for 4500mah.
(Forget the slight dip upfront I had a problem with my sphere)
I ran another test 30 minutes from Turbo and generated an output curve for that shows that 3 minutes more in depth. You get a drop off pretty quickly but then it slows down the output drops taking slow steps. After about 8 minutes the light is pretty stedy for the remaining 35 minutes. At the end here the light was hot. I measured it at 124F uncooled which is uncomfortable to hold onto. If I was holding this I would have turned it down well before it got this hot. Parasitic Drain was measured at 3.2uA
UI
Ui is overly simple on this light. Low, medium, high in that order. When in high, double click to go to turbo. Eco mode (Still too high for my taste) is accessed when the light is off by long pressing the button till the light comes on. To shut it off while on requires a long press (2 seconds). Tho light also has Strobe but it can only be accessed from Eco Mode by double clicking to reach strobe. I like that strobe isn’t a part of the main group but this is a little awkward.
Lockout mode is also available. When the light is off long press for 4 seconds and the light will flash to enter lockout. To unlock requires unscrewing the tail cap. That’s certainly a different way to unlock and it’s not my favorite. Unscrewing the tail cap to mechanically lock it out seems more intuitive to me.
The light has low voltage reminder by flashing the LED under the button. This is a little hard to see if you don’t notice it. It comes on under 3V.
Compared to the Thrunite TC20
Size wise this is pretty similar to my Thrunite TC20 I reviewed. Both are floods with similar beam patterns. The Thrunite is a bit more expensive but it includes a 26650 battery, has onboard charging and is available with a Neutral white LED. Size wise they are very similar, I would give a slight advantage in build feel to the Lumintop. For me the Thrunite wins by a hair due to the neutral white LED which I prefer. Brightness wise to the eyes they are very similar.
Conclusion
This is a nicely built handheld flood. I like the 26650 format. It fits nicely in the hand while providing a large amount of light for whatever task you need. This makes a great handheld hiking/camping light with it’s long runtime or around the house work light/emergency light too. It’s not something most people will EDC in a pocket due to its size but it would work on the included holster for this. The XHP 70.2 LED in this is largely free of artifacts and color abnormalities I have seen with other similar lights.
For me lack of onboard charging isn’t a big deal because I have a few chargers that can accomodate 26650 cells. I would prefer the light to be slightly longer and use springs on both ends so that it doesn’t dent a protected battery that’s are a little longer. I would also like to see polarity markings. None of these are deal breakers nor do they detract much from a nice light. I do like that the 26650 battery format is starting to gain wider use in more and more lights.
Thanks to Banggod for sending this light for me to review. They have offered me some coupons if if you are interested in this light be sure to check them out.
Get $13 off the Lumintop ODF30 with coupon code: b3131d at https://goo.gl/cN2WBH
Get $2 off the KeepPower 26650 battery with coupon code: 6e5463 at https://goo.gl/rsf2Wx
8% off universal coupon for flashlight @ Banggood using code: Forolinternas
