3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will color the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy!
For VERY large photos: click -> on the photo page right click -> "Open image in new tab"
This flashlight was provided by Mateminco for review, thank you ^:)
Check their Aliexpress page:
https://www.aliexpress.co....69385c0f5WdSZ4
And the flashlight:
https://pl.aliexpress.com/item/4000170457613.html?spm=a2g0s.9042311.0.0.69385c0f5WdSZ4
Table of Contents:
- General parameters
- Package content
- Appearance, parameters
- UI, runtime and charging
- Waterproof
- Light pattern, tint
- Beamshots
- Usage and my experiences
- Nitpicking
- Gallery
- Summary
From flashlight page
| Product Name | Mateminco MT07 |
| Brand | MATEMINCO |
| LED | 7 * Luminus SST-20 |
| Material | Aerospace Grade Aluminum Alloy |
| Mode | Anduril Firmware |
| Switch Type | Clicky Switch |
| Switch Location | Body Side Of The Flashlight |
| Battery | 1 * 18650/21700/26650 battery (not included) |
| Max Output | 5500lm (6500k, SST-20) |
| Max Beam Distance | 415 Meters |
| Max Beam Intensity | 43000cd |
| USB Charging | 5V2A USB Type-C Charging Port |
| Color | Black, Clear-Anodizing Silver, Sand, Olive Green, Gun Gray |
| Impact Resistance | 1m |
| Waterproof | IPX7 |
| Weight | 170g |
| Size | 111mm * 44mm * 34mm(Length * Head Diameter * Body Diameter) |
Nice good quality cardboard box
What's inside:
- 2 spare o-rings
- lanyard
- manual
- two adapters to 18650 and 21700
- SHOE SACHET (that's what I'm looking for)
(this tape and a screwdriver wasn't included)
And I got a diffuser. It can only be purchased with the flashlight, so better get it - I'll explain later (read everything, don't scroll to this part!)
It looks pretty good! My silver version was a good choice. SS bezel is a bit darker, everything matches perfectly.
And it is small and lightweight flashlight. For sure not EDC, but remember there are 7 leds and a 26650 cell.
From left to right:
- SS bezel
Thread is not lubricated and makes annoying noise when screwing. They should put even a bit of lubrication here.
- AR coated glass lens
A bit coated, as you can see. Not much violet-pink color, (Google translate told me it is called "mauve". I don't know what's it, but ok then, it is not much...mauve..ish?
And thin glass, when compared to smaller S12 you can see, MT07 glass is bigger and thinner. Should be as thick as S12.
But Convoy seems to make his flashlights for some kind of apocalypse. Very tough and heavy.
- Clear TIR optics
- 7x LED in this case SST20 5000K. We'll talk about the tint later but I can tell you - it is horrible.
And a copper MCPCB. And a thermal grease. And a thermal grease. And after that more thermal grease, and there is also thermal grease hiding around the corner. And everything is broadcasted by "TGCTG - Thermal Grease Corporation of Thermal Grease". And...um, you got the point - there is just too much thermal grease.
And AUX leds - battery indicators and nice looking thing ;)
And as you can see, one led is not working. It was broken and I haven't really noticed it until I unscrewed the optics. So it is very hard to notice when everything is assembled. But it is for sure shortcoming, and I hope it is only in my sample.
- Rubber e-switch, illuminated.
and the USB-C with rubber cover
which doesn't stick out behind the housing after closing.
And some of heat dissipation helpers ;)
- From the driver side, there is a plastic cover - it is covering driver... :GLASSES:
- Battery tube with good, thick o-rings
Threads well lubricated. If you don't have lubrication on your other flashlights, get some from here. ;)
- Tailcap with a thick, double spring.
brand logo and other strange things no one really care about.
And lanyard hole - as you can see, it is...umm...it is prepared well not to cut a lanyard.
As you can see, after a little use, only for reviews basically and two more times I took it for a short walk to see how it shines, it collected some scratches. And the cover was not included ... Is it the fault of the silver version and the other colors are better, I don't know. But it's definitely worth securing it somehow and not carrying loose in a bag or backpack. So better get a big holster.
UI
Anduril
See details:
https://budgetlightforum.com/t/-/54947
And remember to calibrate temp sensor
Runtime
Turbo ~ 4100lm. Yes, a bit low compared to declared 5500lm. It was my measurements, so can be not as accurate as...you know. Not very accurate. But 1400lm lower is a lot lumens lower.
Not calibrated sensor, it quick ramps down
And then I calibrated the temperature sensor and set max temp to 55degC
And it is worse now. Before calibration, thermal sensor was showing ~ 10degC less than it should, so after calibrating, it steps down faster. But flashlight wasn't very hot when touching. Maybe there is something with temperature transfer between MCPCB and body.
First couple of minutes, lvl 5 ~ 480lm
Brightness ramps down and up, so maybe it's something wrong with heat dissipation
Now lvl 5 till the flashlight turn off
It ramps down and up again
First 10 min on 6th lvl ~ 1000lm
It is for shining when only USB powered, with no battery inside
So 815lm for a while, then 350lm and it stabilizes at about 258lm
Charging
USB-C port on the side of the head. They say charging is 2A - I managed to get just about 2A.
Is that good? Yes, assuming that a 5500mAh high-current battery sits inside and it takes about 3 hours to charge.
Red - charging
Green - charger
And you can use it without a battery inside
You can turn on the head only! :D
There is max 815lm and it takes 1.5A then. But it shines with that brightness ~ 10s, then steps down to 350lm and after a minute it stabilizes at about 258lm. And it makes very loud, high frequency noise when powered that way! It could be a good night bed light if not this noise...
And it works with a power bank, but just for a while, and then a power bank shuts off.
So...I haven't tested it in my fish tank. I was sure it has IPX6 rating, but now I see it has IPX7... What I can tell - it is for sure waterproof for quick submerges. There are o-rings everywhere, USB-C cover fits tight. So if you throw it into water by an accident, and get it after 10s, don't be afraid.
The dot in the center is the center of the beam (approx.), each line at an interval of 15cm. The light is more focused, because the optics is clear. But good flood to, to illuminate your path when walking.
I mean ... it would be good if it wasn't that GREEN GREEN GREEN GREEN. The light is green like spring grass in the morning, like leaves on a tree, like the Panasonic NCR18650B, like the lid on this jar
Awful. Generally awful. And I bet the 4000K version is not in a good bin, but slightly green in the lowest modes. But this one is terrible. It's good that they don't sell the 5000K version anymore ...
Within the maximum brightness, the tint becomes neutral, with a pleasant neutral white color. But only on very bright modes that immediately overheat the flashlight. The minus green filters can help. I even made a thread to ask how to fix this tint:
https://budgetlightforum.com/t/-/59097
If I remember correctly, such filters take 7% of the light (I can be wrong) so the flashlight heats up faster, and shines darker, and at maximum brightness the light is not so neutral, but pinkish.
ISO200, t2s, f/3,5 WB: sunlight
Let's light up the forest!
So I tested only the High mode, and two click Turbo
There is so much light, it has great flood and throw as well
Great
And you can see lvl 4 - it is good to illuminate path. My backpack (this lovely red thing) is about 5m away...or maybe it was 6...
I've promised to tell more about the diffuser - so here you go, the Lantern of Mightiness. You know...because my BLF name, "Mocarny" can be (quite accurate), translated to "Mighty"
Die, darkness!
On a camping (yes, forever alone camping with no friends and equipment warming my hands by a flashlight...but I enjoyed it :THUMBS-UP: )
It is very bright so brught after turning the light off - great GITD diffuser.
And I though: "So maybe I should try this light painting?"
My very first try
It looks like poo
But I didn't give up
AND THEN!
It still looks like a poo
Uch maybe I should try something different, maybe light...typing?
I'm really proud of myself. And it was only half a four of trying :D
With a watermark
This is MINE!
Ahem...
I took it for a walk several times. In practice, it works well, it is not unpleasantly heavy or large, and there is a lot of light. Let's skip it being GREEN. You can comfortably shine at a path near you but also shine at a distance. It scratched a little, so it's definitely worth finding a holster. With the diffuser it can be used as a camping lamp, e.g. hang on a tree. The diffuser fits tightly and sits stably, there is no fear that it will fall. And it really shines brightly in the dark.
Because of this GREEN tint, you should consider getting 4000K option, or even get XP-L (more expensive and in 3B, greenish bin too)
In my opinion, the diffuser is a necessary addition to the flashlights with Anduril, we have a candle mode, we can paint with light, we also have a thunderstorm mode.
So everything about all the flaws.
GREEEN!!!! Nooooo. Very green light. But it is not the flashlight's fault but the choice of LEDs. They may not have 5000K at all to choose from (well, now they don't have). In addition, if they chose cheap bins, then the 4000K and 6500K versions will be greenish too. Definitely not THAT much though. You can buy a more expensive version with XP-L HI 5000K, it will solve the problems, but it is more expensive, and it also has a slightly greenish 3B bin.
The bezel is not lubricated and makes an unpleasant sound when unscrewed. The TIR optics do not go completely as deep as it should and when the bezel is tightened, the glass presses on optics creating this marks on the surface.
So I was afraid to screw it harder, the more I was screwing, the more marks were showing.
"There is definitely too much thermal grease under the MCPCB" - that's what my "ThermalGrease" radio station told me today.
Mateminco MT07 is a budget flashlight with 7 * SST20 or XP-L HI. It is small, lightweight and handy, and at the same time very bright. And very GREEN for the SST20 5000K version. The other versions are also probably not in the best bins, so you shoul expect greenish tint (less, but still). The price encourages to buy, because it's cheap and a budget flashlight. The more expensive version with XP-L HI will definitely make it a practical flashlight, and fanatics of non-greenish tint can buy a slightly minus green filter.
Despite some shortcomings, this flashlight is an interesting proposition for something with many leds, powered by a 26650 battery.
Do i recommend it? If the flaws like a marks on the glass or a non-working AUX led are just in my sample, and the other versions of the leds are not so GREEN, then yes.
Pros:
+ Lightweight
+ Anduril
+ Integrated charger
+ Cheap
Cons:
- GREEEEEN LIIIGHT
- There are marks on the glass - see "Nitpicking"
- One of my AUX leds is not working
- My measurements say there is 4100lm. Maybe there is more, but I doubt 5500.
About host - threads, knurling o-rings and so on
Rating: 7.5/10
About light - UI, tint and so on
Rating: 7/10
1 - very bad flashlight hurts to look at, terrible quality, not worth any (even very low) price
5 - average flashlight, at a reasonable price and for occasional (in its category) use - for the average person "great". Or better flashlight, but overpriced
10 - flashlight meets all my expectations in a given category (e.g EDC, headlamp, thrower), it's durable and neatly made, perfect light tint, worth its (even slightly inflated) price - just pure perfect, so I doubt any light can get a 10 from me
