Meote is a new flashlight brand on the market a collaboration between Banggood and one of it’s affiliate marketers. It’s first light is the FM1 and it features quad LED, available in multiple tints, multi color auxiliary LED, an attractive exposed copper and black body and running an 18650 battery. Thanks to Banggood for sending me this light for review. Let’s see if their first light is a dazzler or a dud.
Watch this review on YouTube:
*Follow me on Instagram: *https://www.instagram.com/liquidretro/
Join the Facebook Page: Liquidretro Gear & Reviews
Packaging and Accessories
The packaging here is pretty nice. It’s a black retail hanging box that looks pretty sharp with a picture of the light on the fron. Inside the light is shipped with foam surrounding the light. Accessories that come with the light a nylon holster that’s branded with Meote’s logo, It clips on to your belt with a clip, and doesn’t have a d-ring. Other accessories include 2 o’rings and a simple manual. The print is very small and I would suggest just going to ToyKeepers website to get a larger copy of the Anduril manual.
Construction & Build
There are 2 versions of this light. First is the version I have here with the LH351D LED (Other LED’s are available), coated copper head and Andruil firmware. There is then the aluminum alloy version with anodized accents (Blue and Green), with NarsilM firmware. The version I have here is available with the black anodizing, blue or sand.
This light is built a little differently than other lights, it takes design elements from the FW3A but puts it’s own larger spin on them. Starting at the tail the mechanical switch has a metal button with the Meote logo etched in. It’s a loud button, probably the loudest I have. Inside it features a dual spring but they are rather weak which causes the light to shut off if bumped moderately when on. Inside the body section there is an inner tube that’s not secured one either end. Threads are square cut, raw and a bit rough.
Body section has some basic grooves cut into it. The body section doesn’t split where you think it should when lining up with the head, instead it’s just behind the copper part of the light. The head itself has a large outer copper sleeve with fins milled in. They are coated to prevent oxidation. On mine it seems to be missing an oring but there is a place milled for it. Inside there is an anodized aluminum large retaining ring holding the pill in. The bezel is aluminum and crenulated holding in the quad optic.
It’s worth noting here that at least with my flat top, unprotected high drain VT6 battery, it’s very easy to bump the light and have it turn off. A stronger/longer tail sprint would fix this.
Size & Weight
I measured the length at 110mm, minimum diameter on the body at 21.4mm, and maximum diameter on the head at 30mm. I measured the weight with a Sony VTC6 battery at 185.5g. It’s not a light flashlight.
Retention
The light does feature a reasonably deep pocket clip with large cap screws with a 3/32 hex head. Not typical of other flashlights. My clip was originally bent out from the body of the light and didn’t make contact. I was able to bend it back fairly easily as it’s soft steel. It also comes with a nylon case that’s decent. It has a clip on the rear instead of D-Ring.
LED & Beamshots
The FM1 is available with a number of LED’s, the one I have here is running Samsung LH351D at 5000k. I think it’s a bit warmer then that in my eyes and when compared with other lights. SST20 at 4000k and XPL-Hi at 6500k are also available. Meote claims the light produces 4980 lumens and that number is probably with the XPL-Hi LED’s but testing on BLF has said otherwise. I don’t have a current method I trust to accurately make a lumen claim myself.
Beam pattern has a decent amount of artifacts that you notice on the edges of the spill. I think it’s the crenulations that are causing most of this. Out of my D4 and FW4A it’s what I would consider the most undesirable beam shape. It’s mostly a floodly light and at a distance you don’t really notice a hot spot.
There have been several reports of the driver on this light flickering during high output uses. My example doesn’t have that problem at least when I am running a Sony VTC6 battery. It’s worth noting here that at least with my flat top, unprotected high drain VT6 battery, it’s very easy to bump the front or back of the light and have it turn off. A stronger/longer tail sprint would fix this.
Heat and Runtime
No big surprises here in the heat and runtime category. It’s a quad LED light without a ton of thermal mass so Turbo output starts stepping down almost immediately and at 30 seconds it’s 3.5 times less light then when it started turbo. It does have active thermal regulation so we saw it step up and down slowly during the total 2 hour and 40 minute run time. Most of this was spent between 25–40 relative output. FL1 was at 2 hrs and 32 minutes. Maximum heat I saw was 47C at the 12 minute mark. LVP came in at 3.02V.
UI
The Meote FM1 is using the Andril firmware we have gone over before with several other lights I have reviewed like the Lumintop FW3a, FW4a, FireFlies E07 and others so I will be brief. It provides the ability to run in a nice ramping mode, stepped mode, and has tons of extra features. Do seriously check out the diagram and practice with it so you use the light to the full potential if you decide to get one. I would also recommend doing a thermal config if you plan to use the light seriously.
One thing some of the other lights I have reviewed have not had are the RGB auxiliary LED’s that this one does. You can adjust the brightness to low, high, or in a blinking color mode by 7 quick clicks when the main led are off. You can also adjust the color of the LED, with 7 click then hold from off. It can do static colors R, Y, G, C, B, V, W, rainbow which I have it in here, and volts mode which gives you a quick flash of the previous color then fades to the next.
Pro’s
- Use of the Samsung LH351D LED’s is nice
- Exposed copper even though it’s coated
- Auxiliary LED’s
Con’s
- Internal Build quality
- Beam Pattern
- Easy to bump and have the light turn off
- Clip is easily bent
Conclusion
On paper I wanted to like ths light, It’s a little bigger than I typically want to EDC in the summer but I just liked the look of the exposed copper, it had a pretty good deep carry clip, high CRI LH351D led’s that are warmer, and aux LED’s are always fun too. So this had the potential to be a good light, but when I got my hands on it turned out to be a light I just didn’t enjoy very much.
I have a hard time recommending this light. There are better options like the Lumintop FWXA series and Emmisar D4V2 for lights that do similar things. These don’t have the issues like this FM1 has, like a bump shuts the light off, the interior build quality, a flickering power issue some people on BLF have reported, a clip that’s not touching the body, and an undesirable beam shape.
To me it feels more like a prototype than a finished product. A lot of these issues should have been caught during the development process and worked out before bringing it to market. Instead we are left with a light that just isn’t as good as it should have been.
