Nextorch kindly sent me their TA30D Max tactical torch to review. It’s a very nicely-built 21700 tactical torch, if that sounds like something that would interest you, please see the full review here
Please note that I am very new to both reviews and websites, so any constructive tips will be welcome.
Damn, sorry. Is it asking you to log in to see it? I’ve tried opening it in an incognito window in Brave and it worked. It seems to be set to be public.
thanx
if you are new to reviewing, this is certainly a good start.
this UTB Ultra Thermal Buffer sounds really interested. if the are not lying. thought i`m not sure what is any use of it here.
This type of thermal interface is used in laptops, for instance, to ensure tight contact between a heatsink and a “hot spot.”
However, in this case, the housing already contains an excess of metal, and I don’t see how this new solution could be any better than standard thermal paste - provided, of course, that the paste was applied correctly to the LED substrate.
I suspect there’s more marketing here than actual, tangible benefit. Furthermore, I find the gap between 550 and 4000 lumens to be unjustifiably large. If the “turbo” mode eventually drops down to 1000 lumens anyway, why not just make that a dedicated mode? In many situations, 4000 lumens is too much, while 550 is too little - leaving you in a position where you have to activate the 4000-lumen mode and then wait for the brightness to drop to the 1000-lumen level you actually need.
