[Review] Nightwatch NS14R SFS72 - 5000K 14 LED high output thrower with a copious amount of flood!
Impressive in some ways, what are your thoughts?
These are cutting edge, True power.
I don’t think I’ve ever seen a light step down to 10lumens… But those first 30 seconds will be bright!
There must be an endurance joke hidden somewhere…
What batteries did you use to test this?
Thanks for the review!
I used the optional Nightwatch cells. Not sure who makes them.
The head is so small for 15000 lumens!
Those cells are the Lishen high performance cells
Did yours have the round die leds? I have the Ns14r with the domed LEDs for testing. They look like xhp50.3 HD. The other version has the round die 5050 size leds.
These domed ones are properly bright even with the batteries at storage voltage. It came with Nightwatch branded ‘60A’ batteries with soldered on button tops. Can’t wait to test it!
AKA the Lishen LR2170LH
Ads show 2000mAh, seller states 3800mAh but they are in fact 3000mAh?
I charged mine up from 3.5 volts and they came out with beteeen 3001 and 2890 mAh added. I’m thinking they’re 3 Ah each.
They are 3000mAh, officially rated to a CDR of 30A but in real life testing far outperform that rating. The discharging capacity is around 3100mAh but that was at the low current of 300mA, IIRC they’re rated to 3000mAh at 5A or so.
Thanks for another great review.
Quick question, I see the SQ55.2 emitters are 5700k, the SFS72 are 5000K so,
what is the rating of the SQ55.4 emitters?
Thanks again
