Hi All, Nitecore sent me their new and updated penlight the MT06MD!This light features a brand new 4 lumen LOW mode and a new High CRI LED, Nichia 219B.
I'm a father of 3 and the family medic, so I've been looking for a good penlight to add to my kit and this fits the bill! Many penlights don't really have low mode but if they do, most are 1 lumen. The new 4 lumen mode works great of checking the kids eyes and can get a response in normal interior lighting. The addition of the CRI definitely helps and I can feel that my eyes are less strained.
Sound up your alley? Then say hello to the new MT06MD!
QUICK SPECS
Here is the specs from Nitecore’s website.
OUTPUT & RUNTIME
Very bright for about 45 min. Overall, it took 4 hours to completely drain the batteries starting on the high mode.
| Max Output | 180 lumens |
| Max Beam Distance | 58 m |
| Max Beam Intensity | 860 cd |
| Max Run time | 35 h 0 m / 1.46 d |
| LED | Nichia 219B LED |
| Reflector | SMO |
| Battery | 2 × AAA |
| Beam color | High CRI (~5000K per packaging) |
| Length | 128 mm / 5.04 in |
| Head Size | 14 mm / 0.55 in |
| Weight | 22 g / 0.78 oz |
LED SPECS
One of the homeruns on this light is the Nichia 219B LED with CRI= 90 and is photo-biologically safe rated at RG0 (risk-free group). As many know already, CRI is a color render index which rates how well colors look under the subject light, where high CRI means better color rendering, and having good colors helps medical professionals a lot.
It’s sort of assumed for most flashlight LEDs, but the other part I didn’t realize, that the Nichia 219B LED is rated perfectly safe to be shined in someones eyes, and that there is no hidden radiation being emitted, which many doctors and their lawyers will like to hear. Here is an info sheet from Underwriters Laboratories on the subject: ul-lighting-sheet-fotobiologico-v2
OTHER FEATURES
- Starts in low mode
- Constant current (ie no PWM)
- Can be sterilized after use
- Uses 2xAA batteries
- IPX8 water proof (2 meter submersible)
- Impact resistant to 1.5 meters
- Areospace grade aluminum
- HAIII hard anodising
VIDEO OVERVIEW
www.youtube.com/embed/g4ksTV41BE4
LOOK & FEEL
The light appears identical to its predecessor MT06 with a black smooth body witha stainless steel clip and clicky switch. There is a very slight machined texture which at first feels like a cost cutting measure but it may have be done on purpose to try to add a bit of grip without cutting knurling which may have made it more difficult to clean.
BEAM PROFILE
The beam angle is not advertised but using a printed protractor I measured the main spot to have a total angle of about 25° and a total spill angle of about 80°.
Nitecore R40 w/CREE XP-L HI (left), Nitecore MT06MD w/Nichia 219B (right)
USER INTERFACE
The light uses a single button interface and has only three output levels; so I’d say this is one of the simpler UIs out there. You do a full press to click the light on, then you can either do quick half presses or full double clicks to cycle to the levels. Alternatively, you can also quickly loosen and tighten the head and it will cycle as well. You can lock out the light by loosening the head. Easy-peasy. I did notice that when holding the half press for a certain amount of time between high and low, when the light switches to low, there is a very quick bright flash before dimming to low; I’ve found that you can avoid this easily by more quickly half pressing to cycle the light.
BATTERY
The light takes 2xAAA which makes for a very slim and light form-factor. I’ve typically been against the use of AAA lights but since this has such a small form factor, it is very much worth it.
WARRANTY
Nitecore provides a 5-year warranty! Make sure you buy from an authorized dealer or you will waive your rights to the warranty. Also, take care to store your light properly, as the warranty does not cover damages caused by batter leakage. Check out their full terms of service.
PROS
- Great color rendering! Really helps in observing patients or checking electrical wiring.
- Optimal 4 lumen low mode PERFECT (imo) for checking pupil dilation; many pen lights don’t even have such a low level, and if they do, they tend to be only 1 lumen.
- Very slim and light weight, fits great in pockets, and can be held between the lips if needed
- Very professional look with stainless steel accents
- Wonderfully smooth transisition between beam spot and spill
- Has physical lock out for preserving battery
- AAA batteries are very easy to replace and, for professionals, I’m sure most employers will provide these
- IPX8 water proof and can be washed in the sink or sanitized
- Hard anodizing will help prevent scratches and keep the light looking very professional
- I like that you can half press the switch to cycle the modes and reduce clicky sounds when observing patients
- Has constant current (no PWM) and great runtime; if left in the high mode it takes 4 hours to be fully drained!
OBSERVATIONS
- Pocket clip not as resilient, but you can fix it if it bends too far; wish the clip was titanium plated even if it didn’t look as professional
- Clicky switch cover feels a little wobbly so I packed it with some tissue for a little more stability
- Very, very, slight machined texture on the body
- Would have like a little traditional knurling near the switch end for increased grip
- The light gets a little warm, but not really hot, if left on for extended amount of time, which is unlikely for a penlight
IN-USE
Even with all the promotion for use in the medical field, I still don’t think you wanted to see in my throat, or any other body part or that matter, so I figured I’d stick with some outdoor beam shots.
Pull box markings (high mode)
Steel plate covers on asphalt (high mode)
Tree tops (high mode)
Glove box (low mode)
Checking the CRI on our toddler art (mid mode)
PRICE
Currently the penlight is around $30 USD on amazon. If you appreciated my review and would like to support my work, I’ve provided an Amazon affiliate link to the featured product.
Nitecore MT06MD 180 Lumen Nichia LED Medical Penlight Flashlight For Doctors, Nurses and EMTs with 2x AAA (affiliate) (non-affiliate)
THANKS FOR READING!
DISCLAIMERS:
- CivilGear received this product for testing and honest review.
- CivilGear is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com
