For technical details of the flashlight: https://flashlight.nitecore.com/product/p35i
To purchase from the official website: https://www.nitecorestore.com/Nitecore-P35i-Rechargeable-LEP-Flashlight-p/fl-nite-p35i.htm
The multilingual manual: https://flashlight.nitecore.com/Uploads/FLASHLIGHTS/download/p35i.pdf
MAIN FEATURES:
• Ultra long distance dual beam LEP flashlight
• Equipped with the spotlight and floodlight with a dual-lens system to provide a max output of 3,000 lumens
• The spotlight uses a Class 1 LEP light with a max output of 410 lumens
• The floodlight uses 6 x CREE XP-G3 LEDs with a max output of 3,000 lumens
• Max peak beam intensity of 678,000cd and max throw of 1,650 meters
• Powered by a 21700 i Series Battery while compatible with CR123 batteries, to provide a runtime up to 60 hours
• Multifunctional OLED real-time display for brightness, throw distance, battery voltage, runtime, etc.
• Intelligent Li-ion battery charging circuit with a USB-C charging port
• Highly efficient constant current circuit
• Incorporated Advanced Temperature Regulation (ATR) module (Patent No. ZL201510534543.6)
• NITECORE 21700i Li-ion battery (NL2150HPi 5,000mAh) and Remote Switch RSW2i (Cable Part) included
• Optical lenses with double-sided scratch resistant coating
• Constructed from aero grade aluminum alloy
• HA III military grade hard-anodized finish
• Rating in accordance with IP68 (2 meters submersible)
• 1 meter impact resistance
Specifications
Length: 186.9mm (7.36")
Head Diameter: 65mm (2.56")
Tube Diameter: 25.4mm (1")
Tail Diameter: 28mm (1.10")
Weight: 296.6g (10.46 oz)
Accessories
NITECORE 21700i Rechargeable Li-ion Battery (NL2150HPi
5,000mAh), Remote Switch RSW2i (Cable Part), USB-C Charging
Cable, CR123 Battery Magazine, Spare O-ring, Holster
Note: All NITECORE® products are guaranteed for quality, any DOA / defective product can be replaced through a local distributor / retailer within 15 days of purchase. After that, NITECORE® products can be repaired free of charge within 60 months from the date of purchase.
User Modes and Levels:
Note: Data shown is measured in accordance with ANSI / PLATO FL1-2019 International Flashlight Test Standards, using a 21700 Li-ion battery (5,000mAh) under laboratory conditions. * TURBO running time is tested without temperature adjustment. * TURBO availability: TURBO level of 3,000 lumens is only accessible when using a 21700 i series battery with an output greater than 15A. The TURBO levels and HIGH level of the Mix mode are not accessible when using CR123 / RCR123 batteries.
In these days NITECORE presented the new torch of the “i Generation” series for hunting and research; the Nitecore P35i. The new and powerful Nitecore updates the previous P30i by adding laser technology LEP (Laser Excited Phosphor) to which it associates 6 CREE XP-G3 LEDs with which it reaches a maximum brightness of 3000 lumens with an intensity of 678,000cd.
Nitecore P35i has compact dimensions and covers the maximum distance of 1650 meters with the beam. The construction materials and all the technology adopted for this new Nitecore are remarkable.
Nitecore P35i is powered by a 5000mAh "i" series 21700 battery, has 3 modes of use (Flood Mode, Spot Mode and Mix Mode) to cover every lighting need, and has up to 13 light levels with a maximum autonomy of 60 hours.
P35i has a multifunctional OLED display in real time (for brightness, projection distance, battery voltage, autonomy, etc.) and 2 switches, one in the queue and one on the side for managing the levels or the way of use. Nitecore P35i has memory of the last level used.
Nitecore P35i has IP68 certification (2m submersible) with an impact resistance of 1 meter and is supplied with a practical and resistant holster.
P35i is an ideal companion for night outings in particular for research, hunting, use in industry and law enforcement.
THE PACKAGING
NITECORE P35i comes in a “premium” rigid cardboard box, protected by a shaped foam.
On the box, in addition to the photo, there are technical details of the new Nitecore and serial number.
Inside the package we find the Nitecore P35i inside the rigid holster, with inside the NITECORE 21700i battery (NL2150HPi 5.000 mAh), a USB-C charging cable, the RSW2i Remote Control, CR123 / RCR123 battery adapter, an O-ring of parts, the user manual (multilingual) and the warranty.
The glass and the OLED display of the Nitecore P35i come with a protective film.
Among the accessories supplied, the rigid holster, with hook and loop closure and a D-ring, essential for carrying the P35i safely on a belt or backpack, is of excellent workmanship.
To use the remote control just connect the part of the RSW2i remote cable to the USB-C port and fix the cable on the cap.
Momentary Tactical Lighting
When the flashlight is off, press and hold Button B to momentarily turn it on. Release to turn it off.
Power on and off
Switching on: With the flashlight off, briefly press button A to switch it on.
Switching off: With the flashlight on, briefly press button A to switch it off.
Selecting Levels of Brightness
When the flashlight is on, briefly press button B to cycle through the brightness levels.
STROBE READY ™
• When the flashlight is off, press and hold button A to enter STROBE mode. Release it to turn it off.
• When the flashlight is on, long press button A to enter STROBE mode. Release to return to the previous state.
P35i having the protruding tail button cannot be placed in vertical candle (tailstanding).
The design of the P35i is very beautiful with the large head with the beautiful OLED display and the numerous cooling fins in evidence.
On the head of the Nitecore P35i we find a projector that combines a Class 1 “LEP” beam with a maximum output of 410 lumens, of the throw type, together with 6 CREE XP-G3 LEDs with a maximum output of 3,000 lumens of the flood type.
These two beams can be used alone or combined together to provide 13 different light settings, for a variety of lighting solutions, with a maximum brightness of 3000 lumens and a maximum beam distance of 1,650 meters with 678,000cd.
On the head of considerable size we also find the side button and the OLED display together with deep cooling fins.
With this button we will vary the light levels as well as set the desired mode of use, manage the "Preset" level (MIX Mode) and activate the OLED screen.
The multifunctional OLED display can display, in real time, a lot of information such as lumens, level, beam type, meters, operating time, voltage and more. The screen turns off automatically if no action is taken within 30 seconds. After switching off, a short press of the MODE button can reactivate the screen.
The central body of the Nitecore P35i has a rhomboid-shaped non-slip knurling with good grip even in rainy weather
The threads of the central tube are anodized and arrive well lubricated.
At the two poles, for contact with the battery, we find a particular contact system both on the negative and on the positive where a plated spring is evident. By unscrewing the tail cap you have the mechanical lock of the P35i with the only possibility of setting, with the side button, the “preset” level of the MIX mode.
The battery supplied with the Nitecore P35i is a 21700 protected by 15A (NL2150HPi 5,000 mAh), patented by Nitecore; the P35i accepts only Nitecore proprietary batteries for the “i” (i-Generation) series with double pole both in the head and in the tail or CR123 / RCR123 batteries.
1. DO NOT attempt to use the P35i to charge CR123 / RCR123 batteries.
2. Nitecore P35i is NOT compatible with conventional 21700/18650 batteries.
3. TURBO / TOP level is inaccessible when using CR123 / RCR123 batteries.
On the tail cap we find the charging port in USB-C format and the mechanical tactical button.
The USB-C charging port, protected by a rubber flap, is IP68 certified against the infiltration of water and dust. Under the rubber flap we also find the blue power indicator.
During the charging process, the power indicator flashes slowly and the OLED screen shows the battery charge status.
When the battery is fully charged, the P35i stops the charging process and the power indicator
on the tang will remain lit constantly while the OLED screen will show that the process bar is full.
The average charging time of the 21700 Li-ion battery (5,000 mAh) is approximately 4 hours. (charged via a 5V / 2A adapter).
The mechanical switch in the queue has the task of turning the torch on or off (On-Off) and is equipped with the "momentary on" function (which can be operated with the torch off). The queue button together with the side button is also used for selecting the User Mode (click the queue switch while holding the side MODE button).
To operate the switch you have to make a fair amount of force and the click is noisy.
On the tail cap we do not find any holes to insert a lanyard.
Nitecore P35i together with other flashlights.
From left: Nitecore 21700 battery, Acebeam T27, Nitecore P35i and Speras T3R.
USER INTERFACE (UI):
The Nitecore P35i offers 13 levels of brightness plus the Strobe mode (available only with the Remote Switch RSW2i).
Power on and off
Power on: When the flashlight is off, press the tail switch until you hear a click to turn it on.
Power off: When the flashlight is on, press the tail switch until you hear a click to turn it off.
Direct access to TURBO mode
When the flashlight is on, long press the MODE button to enter TURBO directly. Briefly pressing the MODE button will return to the previous brightness level, or it will automatically return to the previous brightness level if no operations are performed within 30 seconds.
Note: From the tests carried out outdoors, the Turbo level can be recalled numerous times without changing the duration and power of the beam.
User Mode Selection
The P35i offers 3 modes of use: Flood, Spot and Mix modes.
When the flashlight is off, click the tail switch while holding the MODE button to cycle through the following modes: Spot Mode - Flood Mode - Mix Mode.
Release to select the desired user mode.
Note: The P35i is equipped with a memory function. When it is reactivated, it automatically enters the previously stored brightness level.
Flood Mode / Spot Mode
When the light is on, short press the MODE button to cycle through the following brightness levels: ULTRA LIGHT - LOW - MEDIUM - HIGH - TURBO.
Mix Mode
When the light is on, short press the MODE button to cycle through the following brightness levels: LOW - MEDIUM - HIGH - PRESET.
PRESET level setting
When the flashlight is off, long press the MODE button for 5 seconds to access the PRESET level setting mode (see manual for further details
OLED display
The multifunctional OLED display can display lumens, meters, voltage, operating time and more in real time. The screen turns off automatically if no action is taken within 30 seconds. After switching off, a short press of the MODE button can reactivate the screen.
ATR (Advanced Temperature Adjustment)
The integrated ATR technology adjusts the power of the P35i according to the working conditions and the surrounding environment for
maintain optimum performance.
Nitecore P35i reaches 3000 lumens in Turbo mode. The new Nitecore has a concentrated beam (SPOT) with LEP technology to illuminate at long distances, recommended in particular for hunting and research, and an alluvial beam (FLOOD) to have lateral lighting useful for illuminating short and long distances. medium distances. The choice does not end there, because the two types of lighting can be used together in the MIX mode. This possibility is fantastic and allows the Nitecore P35i to cover almost any lighting need.
The depth throw beam, with LEP technology, has a very bright and concentrated white hotspot. In my specimen there is a side lighting that disturbs the beam even if it is not particularly noticeable when lighting in the distance.
The distance reached by the beam is considerable and is also appreciable in the MIX mode with the additional side lighting brought by the 6 CREE XP-G3 LEDs with cold shades.
With the OPPLE Light Master I took some values of CCT (color temperature in degrees Kelvin) and of Ra or CRI (color rendering index) with the two types of beam, spot and flood.
Note: With a higher CRI value (maximum 100) you have a better color rendering.
In my tests the SPOT beam has an average CCT value of 6900 while the Ra or CRI has an average value of 65.
Turning to FLOOD alluvial beam, the average CCT value is 6300 while the average Ra value is 75.
I don't see any PWMs in any of the levels.
With a FLIR thermal imaging camera I detected the temperature in the brightest mode (3000 lumens) after: 1min30sec, 5min and 30min from switching on. The temperature never reaches critical values thanks certainly to the good regulation of the P35i and the good heat dissipation.
With the Luxmeter LX1330B I measured outside, at a distance of 10 meters, the (peak) value in candela of some levels in the various available modes. The values obtained in the tests are close to those declared by the parent company, except for the value of the LEP beam which in my case is lower.
SPOT1 - Ultralow 25 lumens = 37440cd = 387 meters
SPOT2 - Low 65 lumens = 96480cd = 621 meters
SPOT3 - Mid 130 lumens = 192600cd = 878 meters
SPOT4 - High 200 lumens = 310320cd = 1114 meters
SPOT5 - Turbo 410 lumens = 609480cd = 1561 meters
FLOOD4 - High 1000 lumens = 3600cd = 120 meters
FLOOD5 - Turbo 3000 lumens = 12900cd = 227 meters
MIX2 - Mid 420 lumens = 192960cd = 878 meters
MIX3 - High 3000 lumens = 598320cd = 1547 meters
The Runtimes were done outdoors, with medium ventilation and a temperature of about 15 °C, using the supplied battery, a 21700 protected by 5000 mAh, fully charged.
Nitecore's built-in ATR technology adjusts the P35i's output to suit working conditions and environment, to maintain optimum performance.
I would like to clarify that the values expressed by the graphs must be evaluated above all as a reference because they are made with means and conditions different from those used in the laboratory.
In the runtime tests, performed in FLOOD, SPOT and MIX modes, the values indicated by the parent company regarding the working times were reached in almost all the tests and in some cases exceeded.
Let's see below the discharge curves in the various modes.
VIDEO Unboxing, Uso e Beam.
https://www.youtube.com/embed/0WibfuhAQfQ
CONCLUSIONS:
Nitecore P35i updates the previous P30i successfully. P35i is a complete flashlight of 2 types of beam, flood and depth with LEP technology, which combined together make the vision very rewarding.
I really liked the packaging with the great hard holster and the included remote control.
There are many positive sides of the P30i which offers a very valid experience for use with hunting thanks to the powerful and concentrated beam with laser technology, but the lens system must be perfected.
The Nitecore P35i has a solid and quality construction with which we are able to optimally illuminate the walk or, if necessary, at long distances. The levels are well spaced and the regolation is excellent. Recommended.
Thank you for reading the review.
