Nitefox provide me the UT20 flashlight for review,no other reward than the flashlight itself.
First impression: WOW very good quality flashlight!
The box and content:
Missing : the tactical ring and the holster.
Comparison with Zanflare F1:
and two el cheapo:
Specification:
LED: CREE XM-L2 with 50 000 hours life span
Battery: One 18650 Li-Ion battery.
Reflector: aluminum alloy smooth reflector.
Lens: Anti-reflection coating tempered optical lens.
Body: Aerospace grade aluminum alloy.
Mode: Outdoor mode 4 output levels(moon-low-medium-high-strobe), tactical mode 2 output levels(High-Strobe-low)
Circuit: High efficient constant current circuit, constant output, more brightness and longer run time.
Reverse polarity protection to prevent damage from improper battery installation.
Waterproof: IPX8 waterproof, works in rain or shallow water
Size: 139 mm (length) *25mm (body diameter)
Net weight: 93 gram.
Charging:
Beam:
Alone and along F1(left how you look))
Operating:
Has two group modes: outdoor and tactical mode.
The outdoor has four brightness levels (moon,low, medium, high) with memory, while tactical has three ( high, strobe,low) and always starts in high mode.
To switch from one group mode to another, long press the side switch for about 3 seconds when the flashlight is turned on. After the LED blinking, it’s a sign that we have successfully switch modes.
Conclusions:
Pro:
1.Good looking
2.Very good quality machining
3.Rechargeable
4.Good output (1080lm)
5.Easy and nice UI
Cons:
1.Not really big problem but I think get hot too fast on high
2.Maybe price considering that F1 has 1200lm for same or less money
Thanks Nitefox ,very good job, keep the light on!
