Review of Review Charger Xtar WP2s
Charger Xtar WP2s
Xtar makes many good chargers and does also sometimes updates their models. This is an update to the WP2 II, the update includes more selectable charge currents and more power on the usb output. The charger has two channels, i.e. it can do two cells independently of each other.
It comes in a cardboard box with a view to the charger and specifications on the back.
I got the charger, a manual, a warranty card and a car adaptor, but Xtar forgot to add a power supply.
Normally the power adapter is included and the car adaptor may be included.
This version of the WP2 has a cover over the batteries. This is an advantage when using it as an usb power supply/charger, because it is easier to put in a bag or pocket while loaded with batteries.
The control panel has 6 leds and one button:
3 Leds to show selected current (0.25A, 0.5A or 1A).
1 Led to show that usb output is activated.
2 leds to show charge status for the batteries (red=charging, green=done or no batteries, not used when usb output is activated).
The button will select charge current, when power is connected and a long press will activate usb output when power is disconnected.
The power input is a 12 volt DC connector, it can either be powered from the car adapter or the mains adapter.
The usb output must be activated with the button and will stay on until deactivated or the batteries are empty.
Xtar has a special label on, that makes it possible to check for counterfeit chargers.
The charger can handle both button top and flat top batteries, from 30mm to above 70 mm. The slider works well.
The charger can handle 70 mm long batteries, including flat top cells. (See my 18650 LiIon comparison for length of different brands).
It is possible to charge one 26650 in the charger, but it might be necessary to use some tinfoil at the minus pole.
Measurements charger
  • Will discharge battery with about 4mA when not connected to power.
  • Will discharge battery with about 0.25mA when connected to power.
  • Will restart charging at 3.9 volt
  • Will restart charging when battery is reinserted or power is cycled.
  • Below 1 volt the charger will show a green light and charge with 2.5mA.
  • Between 1 and 2 volt the charge will show a blinking red light and charge with 2mA.
  • Between 2 and 2.9 volt the charge will show a red light and charge with 50mA to 65mA.
  • Above 2.9 volt it will apply selected charge current.
  • The channels on the charger are independent, i.e. there are small differences between them.
This charger has a very good CC/CV curve, this is an improvement from the old WP2 model that simulated it. The charge time is just below 4 hours.
With smaller capacity the charge time is slightly shorter.
The second channel works the same.
With 0.5A on a 3100mAh cell the charge time is considerable longer. The termination current is lower at the 0.5A settings, this is very good.
The lower current is for smaller cells.
0.25A requires a lot of patience (nearly 12 hours) with a 3100mAh cell.
My old 16340 cell charges perfectly on this charger.
Even at 1A the charger can handle it.
The charger is using a slow ramp up of the current in all modes.
USB output
The WP2s can power the usb output with one or two batteries. The cells are not directly in parallel (I had to use 5 DMM's to log it).
  • USB output is coded as Apple 2.1A
  • USB output will stay on when load is removed, on/off is only controlled with the button.
  • USB output will always be off when charge power is connected.
Doing a load sweep with two batteries, showed that the current limit is at 2.4A, this is very good for a 2.1A supply.
A test with 2A current, shows a rather short runtime and also that the two batteries is loaded differently.
The termination voltage is rather high for this load (That is the reason for the short runtime).
Reducing the load to 0.5A works better, this gives 3 hours runtime with a single 18650 cell.
And four hours runtime on the other battery. This is strange behavior.
This is the same with other cells.
There is not much noise in the output, even at full current (10 mV).
At 0.5A the noise is down to 4.5 mV.
Conclusion
This charger does a good CC/CV charging and with 3 current settings it can handle a wide variety of cell sizes.
The usb output has very low noise in it and the ability to supply 2A, makes it useful for a lot of usb equipment, but due to the Apple coding on the connector, some equipment will not charge at full speed. The difference between the two batteries is silly and will hopefully be fixed soon, but the only downside is shorter runtime.
The charger has a rather high current drain on the batteries, this is absolutely no problem for the charging part, but it will not be a good idea to keep batteries in the charger for weeks. There is no battery power status indication for the usb output.
The charger is a very good LiIon battery charger and a acceptable usb charger.
Notes
The charger was supplied by XTAR for a review.
All the tests were done with my own 12 volt 1A supply.
Read more about how I test USB power supplies and chargers
Thank you for the review, HKJ!
Can the cover be easily removed do you think?
Looks like a decent update to an already great charger. Thanks for the time you took with this review. Not enough reason for me to upgrade, but it will make an excellent Li-ion charger for those who need one. I’m glad you included the “hidden” bonus that gives you the ability to charge 26650s. When I found out about this on the WPII Mark 2 I was stoked that I didn’t have to buy another/ more expensive charger.
Thanks for the review!
That depends on what you call easily. You have to remove the 6 screws behind the feet, then the cover can be removed without any problems.
But why remove the cover? If you need it for usb power the cover is very practical.
Thanks for the review. Any recommendations on a good place to buy it from?
No recommendations from me, I got it directly from Xtar.
Well with the cover closed whilst charging it may affect air circulation, and visibility of charging LEDs might be hindered depending on position.
“Xtar WP2s” currently listed by several eBay vendors, some US-based.
Prices range between $30.00 - $45.00
Cheers,
__philippe
Thanks for the review, great job as always!! :)
The charger, i am not impressed. :)
I was charging my iPad Air with this charger. I plugged it in at 49% while the WP2s had 2 Sanyo UR18650FM. When the iPad was at 72%, I smelled burning. The charger melted. The cells measure 3.66v each after being removed.
Yikes!
WOW. Ugly. Maybe these chargers need a small fan to cool them down?
According to Xtar:
“The WP2s USB power output maximum current is 2.1 A. Do not connect USB equipment requiring current greater than 2.1 A; otherwise, the WP2s will reduce the output voltage or shut off the USB power output, even the charger may be damaged.”
http://xtarlight.com/05-chanpin/p-001-1.asp?styleid=280&style=Charger Series
I checked the iPad power supply output and note that it is labeled to provide 2.4 A, in which case the Xtar WP2s should not be used as a charger for those devices. I do own a Samsung Galaxy Tablet, and that power supply is rated at 2 A. However, my Samsung USB charging cable is supplied with a wall adapter to accept the USB cable, and I have not used a computer USB port to charge the tablet.
I don’t own an iPad, I was just looking at the “OEM” charger at:
http://www.ebay.com/itm/NEW-Original-Genuine-Apple-Ipad-3-4-5-AIR-12W-USB-Power-Adapter-For-Wall-Charger-/171407568329?pt=US_Tablet_eReader_Chargers_Sync_Cables&hash=item27e8afedc9
Hi, i just newly bought a WP2s and a pair of Xtar 18650 2600mAh batteries.
I tested my WP2s charger usb output (using 2x2600mAh) to my almost empty 1300mAh Nokia Lumia battery (good condition),
but the charger’s blue LED is turned off at 70-80% charging status.
I try to switch the batteries position 1 to bay 2, and bay 2 to 1st bay, it’s charging again but the blue LED off again after 10-15seconds.
that should give me about 5200mAh, is that correct? but 2cells of Xtar18650 won’t full charging a 1300mAH battery, is my wp2s defective?
I do not know why it turns off, maybe because the phone pauses charging?
Do not expect to get 5200mAh, only about 60% to 70% of that (Due to the voltage boost). This is more then enough to charge the phone.
The one you linked to was not a meltdown (A chip that releases the smoke is not a meltdown).
Never had a problem with an Xtar charger before, and I have 7. Very disturbing news. That being said, all electronic devices need protection against user misuse. Agreed?
All electronic fails, look at Apple phones, there has been many much more drastic meltdowns and we have never seen a recall.
It is not that I say that failures are acceptable, but they are unavoidable, both in a $10 charger and a $3000 camera.
Not sure if people are aware of this but it’s a really bad idea to charge a power hungry device like an iPad from a powerbank that only has 1 or 2 cells.
Taking in account efficiency losses and voltage differences, to put out 2A the input should be around 3A and even more when the voltage drops or the cell comes near depletion. That’s a lot of current for the boost circuito to handle specially for a device like Xtar chargers which were not designed to use as dedicated powerbanks in the first place, it’s more like an auxiliary function I guess. IMO the current output from these Xtar charger should be limited to 0.5A.
I have several VP2 and VC2 and never used the Usb output function, in fact I don’t even bother use a powerbank with less than 85% total efficiency. (Battery wh/ output wh). But if you really feel the need to use 18650 to charge a device I would get a miller ML-102 or build a DIY powerbank using a high quality boost converter with synchronous rectification.
