Hello to everyone. Here is a new review I uploaded to my YouTube channel. Head over and check it out. While you’re there be sure to like and subscribe ifnyou haven’t done so already!
Leave a comment and let me know what you think about the new UE (Ultimate Edition) version of the already awesome TK20R that’s been around for a bit.
The Fenix TK20R UE does not appear to have low voltage protection built into the torch.
The battery appears to have low voltage protection. And the torch does give visual low voltage warnings. But I wouldn’t recommend using an unprotected battery.
I tested low voltage protection by connecting the head and tail of the torch to a bench power supply and then by lowering the voltage from 4.20V to 2.0V. Bypassing the tail resulted in the torch entering Turbo so I put the bench power supply between the head and tail with heaps of wires.
The LED turned off at 2.53V but the current remained at 0.15A. As I decreased the voltage, the LED came back on, started flickering, struggled to remain on, and switched off again. The current remained at around 0.1A.
Here are some measurements of the current for each mode while connected to a bench power supply:
Mode
Amps at start
Low
0.09 A
Med
0.68 A
High
1.34 A
Turbo
2.87 A
This is just a quick test of dad’s torch. Build quality looks great.
