Hello,
Tmart sent me a YiHUA 8786D Hot air and soldering station for review. My first video is just a quick summary. I will do at least two more videos on the use of the unit and a tear down of it.
www.youtube.com/embed/wNIhRPZILRI
OK, all three videos are up now. The unit is grounded. All 110/120v is grounded.
New Video on my first try at reflow
Thanks to Tmart for supplying this unit for review.
It looks like there is a replacement soldering iron at Tmart.
http://www.tmart.com/Atten-Soldring-Station-Iron-Handle-907-For-AT938-938D_p170452.html
Also, the "Prokit" tips look to be the same. I did not see heater elements there for the hot air or soldering guns, so that might be a negative. Probably hard to get.
EDIT: I wanted to add something here. I did some testing with both the hot air gun and the soldering iron. I wanted to try reflowing a led on a star. I normally use my cheapo soldering gun and never have a problem.
I had a big problem with this unit. Turned up all the way, neither the soldering gun, or the hot air gun, would get the copper hot enough to melt regular solder. NO, I did not have solder paste, but as far as I am concerned, if that soldering gun will not heat enough to melt 60/40, the heck with it. I won't use it.
I will try to use solder paste when it comes in, and I know it would work with tiny parts, but for bigger stuff, it's just now powerful enough to do much. After all, it's a unit designed for "SMD", which denotes small electronics, sp it's not designed for what I want.
