INTRO
This is my first post so I will probably violate some rules… Feel free to comment below.
I don’t consider myself as a flashalcoolic. I own a simple 10USD AA LED flash light for 2 years and I’m happy with it. I received today my second flash light.
Presentation
Ultrafire WF-502B with an XM-L T6 supposedly 800lm (2.2A)
Bought on DX (sku.160509) for 12.54USD
Pros
-Feels solid
-Nice finish, doesn’t scratch easily
-Almost watertight, there is a small leak through the clip screws
-This is a flood light (I like it) but there is a good hot spot in the middle
-Switch feels really nice
Switch assembly:
Cons
-Bigger than I thought (way bigger than my AA flash light)
-DX claims memory mode but it doesn’t. It goes to high each time you switch it off. (then a slight press does High,Low,Strobe)
-DX claims 2.2A but this is not true unless the battery is full. See results below.
-Bad heat management as all P60 dropins. I ran some temp tests with the P60 dropin out of the host. the temp increased from 30°C to 80°C in 2 minutes (video here with 4.1V using a power supply). I can’t imagine the temp it reaches after 5 minutes on high. Enclosed in the host the heat can’t go away. Must do the aluminium foil trick.
-No Low voltage Warning/Cutoff. Will discharge your battery below 2.5V
Driver:
There is a 0.2ohms resistor that “regulates” the current. Efficiency has to be poor because of that.
Others
Here is the current measurements:
Low:
3.6V -> 100mA
4.2V -> 200mA
High:
3.6V -> 1.2A
4.1V -> 2.1A
Here is the stabilized temperature (dropin alone - 18°C ambiant) at low mode:
Here is how I measured temperature (you can see the thermocouple stuck on the P60 dropin):
OVERALL
I like that light except for the driver.
I got 18650 LG 2600mAh cells out of a laptop battery so for 13USD I got a great flashlight.
I will probably change the driver with a 7135 based driver with group modes.
I don’t recommend that light if you don’t want to tinker it in order to improve heat sinking.
