Today I have on my Review table the new Olight M1T Raider. This is a tactical style EDC light with 2 modes, a rear tail switch and upto 500 lumens out of a CR123 battery. In looks it is similar to the Olight I3T I reviewed last month. Thanks to Olight for sending this to me to take a look at.
Full Image Gallery: Olight - M1T Raider - Album on Imgur
YouTube Version of this Review:
Packaging
Packaging is the familiar white cardboard box that Olight has had on several of their recent releases. On the outside is a large picture of the light, and details are all on the back. The box has a pull tap on the top and you slide out the white tray that contains the light and accessories. In the package you get the light with the removable pocket clip preinstalled, a CR123A Olight branded battery (With plastic insulator that must be removed before use), a lanyard, and an instruction manual that in this case is only in english. I suspect that’s due to this light being released a bit earlier elsewhere in the world a little earlier this summer.
Construction
The M1T is made of aircraft grade aluminum and is hard anodized a semi gloss black. The design is pretty similar to the Olight i3T but with some changes. Starting with the tail switch the top is a grippy rubber with a dimpled pattern. The side walls of the button are plastic, this means you need to actuate it more straight up and down not roll onto it from the side. I like this and think it helps prevent accidental activation. The tail cap has very fine knurling on it that seems to attract dust and dirt easily. The there very back there is a place for the small diameter lanyard to fit. Inside the tail cap instead of a spring, it has a spring loaded brass button.
The body of the light has a helix style spiral like the i3T had but this time it has some straight knurling pressed in, I like the look of this and like the additional grip it provides.
The head is rather simple, no additional heat sink or knurling on the body. The front Olight blue bezel has returned and this time with a DNA catcher of sorts on it. It’s not smooth but not sharp enough to damage you pocket. All branding and marking are on the head. The lens is recessed and a TIR style optic. You can see a few of the wires underneath the TIR optic which is uncustomary.
The pocket clip is a scaled up version of what’s been on the M2T, and i3T to fit the size and proportions of the M1T. This is a good clip in my opinion. It sits reasonably deep, can fit onto a hat
Sizes, Weight, and Comparisons
Overall length 91mm, diameter 21mm. Weight is 65g with the included battery and clip. The light is IPX8 rated.
LED/Runtime
This light uses a Luminus STT40 LED in cool white. The tint isn’t super cool, and more on the neutral side of things. As mentioned previously a TIR style optic sits on top.
!https://i.imgur.com/IAAHwUn.jpg Beamshot!
Runtimes
For my runtime tests I used an Olight branded 650mAh 16340 battery. The light ships with a Olight branded CR123A. Total runtime on the 650mAh battery was 70 minutes. Turbo lasted about 5 minutes and what was notable is that there really was not much sag in light output during this stage. The stop down was sharp and put output at about 55% relative output for the remainder of the 65 minute runtime. Runtime at the end was an abrupt shut off.
!https://i.imgur.com/V5HsbwQ.jpg !
This light doesn’t have Low Voltage Protection which is disappointing. The manual specifically says to use protected batteries (RCR1234 or 16340) if using rechargeables which to me means that it doesn’t have LVP. This is disappointing to me for a light in this price range and from a premium brand. However with this family of lights it does seem to be what Olight is doing.
UI
The UI of this light is a simple 2 mode only. It’s similar to Streamlight’s protac tactical series lights. The switch on the rear of the light works in momentary with a half press then can lock on in either of the two modes with a full press. By default the light comes on in high mode. To get to low from off you need to do a very fast double click. I find it easiest to do this in momentary then lock on if needed. It takes a little bit of practice to get right but once you do it’s easy to repeat.
High modes is 500 lumens, and low is 5 lumens. Part of me wishes there was a medium mode of maybe 150 lumens which I find would be nice for EDC uses but it would complicate the UI a little for a tactical light.
!https://i.imgur.com/6vDXS5J.jpg !
Pro
- For a CR123A light it’s pretty slim, but it could be shorter. Either way I find it carries well in the pocket.
- The Olight blue bezel is back!
- I like the new clip, it’s 2 way and carries well
Con
- No LVP
- Low mode takes practice to access
- Cool White only
Conclusion
If you want a tactical (High mode first) EDC light this is a pretty nice option. In essence this is a scaled up version of the Olight i3T. They use the same LED, same style lens and rear button, have a similar clip and exterior design. To me the most disappointing thing to me is the lack of Low Voltage Protection on a light of this price and from a premium manufacturer. Lack of LVP only matters if you are using it with rechargeable batteries but that’s what I do for EDC because it’s a lower cost of operation.
As an EDC this carries nice, and is fairly deep in the pocket. It’s minimal diameter and it’s length isn’t too long. I like TIR style optics on EDC lights because I find the beam patterns to be useful. A good mix of flood and light throw. The UI on this light is good when you remember it’s tactical. While it starts on high it does have low but it takes a little practice to get to easily. Overall this is a nice tactical EDC option available from Olight.
