Note: This is the third time I write up this review, I fully lost it two times after write-up hitting the 'save' button at the time of the recent server change and its aftermath, mainly my own fault because I was too lazy to make a back-up first. So please excuse the grumpy tone now and then, but I promise that the opinions and views in the review are not affected by my mood
Recently I 'won' this headlamp from dx in a BLF thread in which they asked for reviewers for two head lamps. I am not so much the headlamp type, but was curious about how a powerfull xml-light on your fore-head would be like. I got the high,low,strobe zoom one and received the lamp two months ago, the delay writing this review nicely meets with dx-standards
(I haven't seen the other review yet btw...). I will do my review first and then report about some actual use in the 'wild' during a camping trip with friends. This is the link to the dx-site, it is sold for $34.30. I will not repeat their specs here because they messed that up wildly (it is not 800 lumens, it is far from waterproof, it does not have a tail clicky, where actually is the tail on a head lamp?, and more..).
This is the lamp, the Singfire SF-536, an XM-L lamp running on 2 parallel 18650 batteries. Ugly, isn't it? But to their credit, they did not design it, it is actually a copy of an other ugly light I found:
meet the Led Lenser H14 series.
The first thing that Singfire did wrong is choosing this massive Led Lenser to copy, it sure must be possible to design a high power XM-L head lamp that is a bit slimmer and more elegant? Next they decided to change the battery type: the Led Lenser conveniently runs on 4xAA's, safe batteries, widely available. Singfire decided to stick 2x18650 batteries to the back of your head and chose to deliver the lamp with two unbranded (though protected it seems, they better be) batteries of unknown quality, and an el cheapo wall charger that charges the batteries via a directly connected to the batteries charge port. It could work alright, who knows, but I am not going to use that charger. Last, they made the light as leaky as a possible, this is really an accomplishment: holes everywhere. In my country that is a very bad idea, rain can be expected at any day of the year.
Some pictures guiding you through the lamp:
The battery box, no clicky, just an electronic switch that can easily be fired inside your travel bag, heating the light nicely up insulated by your clothes. The only way to lock-out the lamp is to remove the batteries, but the flimsy plastic clips that close the box will not withstand too may open-close cycles.
The led housing, top view, you see where that wire goes into the pill? Guess where the rain will go. That pill is a massive block of aluminium by the way, if they just made the outer surface a bit bigger for cooling..
The obligatory zoom chart. It used to annoy me because of the great nonsense, but I grew into it and it actually makes me smile nowadays
. (Same as I love the 'caution, hot surface' sign..... Oh no, the Singfire does not have that one
As far as I have opened the light up. Notice the groove around the lid of the battery box, they could have used rubber waterproofing, but it isn't there. Would not matter much because water can come into the box via the switch, or via the hole where the wire to the led comes out, or via the charge port that actually does have a rubber, but that does not fit.
The electronics, squeezed between plastic. Note the direct connection going from the charge port to the batteries, this is very unsafe: the connection is a widely used plug-type, plug in any wall adapter giving off more than 4.2V will blow your battery. But even if you are not that stupid, do you trust the adapter that comes with the lamp?:
Looks like an ordinary 'travel charger' that charges 500mA right up to 4.2V and then keeps pushing. I guess no current lowering when close to fuly charged, and no switch off at full charge. A guy reviewing the head lamp at the dx-site said that with this charger he already managed to melt the battery-wrapping and then quickly decided to unplug the thing.
So now to the performance.
First: the head lamp wears very comfortable, you can wear it for hours (providing no one is around to see you wearing the silly thing).
Some output measurements on high:
zoomed out: 401 lumen OTF, throw 700 lux@1meter
zoomed in : 209 lumen OTF, throw 7200lux@1meter
Conclusion: I find this a bad head lamp that I certainly would not buy myself, the performance is mediocre, but worse: IMO without knowledge of what is going on inside the lamp, it is very unsafe. Even for part scavenging it is not usefull, I just may have a use for the pill somehow.
But now on a bright note: I am of course a bit of a depressed flashlight snob, so it is not surprising if a light is badly made, a review comes out as the one above
. So to give the head lamp a fair chance, I took the lamp out camping (luckily it stayed dry all weekend
) and decided to have it tested by J., a good friend of mine. He has been travelling around the world, including spending months in the African rainforests with his trusty four-led Petzl, but he is not a flashaholic (yet). And he was delighted, he did not know that such a powerful headlamp existed, he used the lamp all weekend and directly wanted to keep it. He was especially very fond of the square beam when zoomed in
. Here he is, doing his thing with the lamp on his head:
His only complaint was the battery blob on the back of his head, reading a book lying on your head is just not possible with it. I really wanted to give him the lamp, and if it had been the Led Lenser I would not have given it a second thought and gave it to him. But this very unsafe light, with Li-ions that require maintenance, no, he was not going to get it. I will give him a nice singleAA head lamp for his next birthday instead
So here's the end of the review, thanks for reading and happy camping
(but please with a different head lamp)
