@ alex21: You really need to read through some of the many threads about these Sipik clones. You will see that none of them are 'the same' as any of the others, at least, not in any reliable, repeatable way.
Alex, I didn't mean it in a critical way. If you really like these lights and you're serious about learning the pitfalls, here are a few threads to start you off. If you read through them you'll see what I was getting at, and why so many of us are pi$$ed off with the whole Sipik saga.. :\
EDIT @ hank: They're not exactly mythical, many of us own them (got three myself). Just that there's no guarantee, or even any real likelihood, that you'll get the same model (or quality) twice running from the same seller/s
I purchased a 3 pack of these a month or so ago from Meritline and they are quite sweet for the money. But I have noticed that it is hard to activate the switch with my thumb due to how far down it is. Not a big issue, and may not be noticed by every user, but I think about it every time I use it.
I stuck a “standard” 3 mode 15-16 MM driver in my sipik after the original one broke, (I dropped it one or two (hundred) too many times and the boost coil broke off.) It doesn’t sit in the pill like the original but the driver is pinched between the pill and the body. It was finicky until I stuck a dob of solder on the negative ring so it made good contact with the body. I’ll get pictures later.
I’ve got one from Manafont (since November 2011), and the LED started burning, when zoomed into throw mode, it was noticeable that some parts of the LED were dead (near the wire). So I opened it and the led didn’t have any thermal paste, but ALSO it doesn’t even touch the pill in the base of the star!
Current all this time was around 1.6Amps with LiIon, and a very very bad contact between star and pill!
Now I modded it with a spare XP-G that I had, with FUJIK thermal paste, stock driver and turnigy cables. It improved a lot.
I got 5 of these . The 2 from TOMTOP with no name brank on is have crappy quality . Very cheap switch/ tail cap thread bad .
The 3 silver ones from another seller have great quality ( ultraok brand)
Can someone tell me how i dissasemble the tailcap? I didn’t find that anywhere… Is the clicky (and spring) just press fitted and I just have to push on it really hard? The Tailcap in question had its rubber clicky-booth came loose… (And I am thinking about baking it as well.)
It is press-fit. Just remove the tailcap and push the switch inward hard, you should be able to feel it loosen/move. Continue pressing until the inner switch is removed.
I know that probably my question has been asked and answered somewhere at BLF already, but is there a better 1xAA thrower out there than SK68 and its various incarnations?
They are a little harder to push BUT they go smoothly. If you lube, even better.
I would say they are probably better option to prevent some splash water getting in.
I just assume this, since my kids have these (with O-rings) and when you press it fast from spot -> FLOOD, they can even pop their tailcap rubber out :D
So, I guess there has to be at least some water tightness...
