Skilhunt M300 V2 144A Review – High CRI with Magnetic Charging
Awesome review! I like the beam produced by the H300
The shortcut to cycle between S1, S2, S3 could be changed to “hold press” instead of “2 clicks” so that the shortcut is consistent with other groups. But it’s nice to see Skilhunt use the same UI consistently across their current lineup.
It is definitely nice that they are using the same UI across their whole product line. That makes remembering the UI much easier if it’s the same on a few of your lights.
I can understand why they chose 2C to cycle the strobe mode instead of 1H. It’s difficult to tell when the change has happened if the light is blinking erratically, unlike changing the brightness in a normal mode which is immediately obvious.
Strange boost driver …No stabilization on T1 mode at all and early 3+V destabilization on all modes. Skilhunt makes great design repairable flashlight hosts but usually shortcuts on electronics.
