Today I am looking at the BLF LT1 Mini made by Sofirn. This has been in the works for several years over on the BLF forums. It’s a miniaturized version of the larger LT1 model, while still maintaining most of the same features thanks to it’s Anduril 2 firmware. Thanks to Sofirn for sending me this one to review. They are available currently and I have a discount below in the description of the Youtube Video.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
Follow me on TikTok: liquidretro1 (@liquidretro1) | TikTok
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
*Find all my social media at *liquidretro | Twitter, Instagram, Facebook, TikTok | Linktree
See my Amazon Store with my gear recommendations Liquidretro Reviews's Amazon Page
Packaging & Accessories
Packaging is Sofirns standard thin basic cardboard box. Inside the light is protected with bubble wrap. The diffuser is also protected with a layer of plastic to prevent scratches. The lantern comes with an optional 5000mAh 21700 Sofirn battery which I have. Other accessories include extra Orings, Lanyard, and USB-A to C cable. My light didn’t come with a manual but the batches shipping how should have one.
Construction & Design
The exterior design here is basically the LT1 but scaled down so that the body tube fits a 21700 instead of 4x 18650 like the LT1. There are some differences like the ¼ 20 mounting holes on the light. You still have the hanger wire at the top, still the same button with the T a throwback to the original LT1 manufacturer. Branding is minimal and Sofirn is instead of BLF. The battery tube is reversible but it is marked with a battery polarity marking so I will leave it as is. The tail cap is flat on the bottom, slightly flared for stability, and has an inner ring cut to allow you to attach the lanyard.
While the LT1 Mini is only available in black anodized aluminum right now, Sofirn has said it will be offered in the same colors as the LT1 is now so keep an eye out for that. Interestingly mine doesn’t seem to have a serial number on it.
The light is fairly open to modification. The diffuser unscrews fairly easily and it opens up to easily expose the LEDs. Getting the board out looks more difficult and I didn’t try that here. Their programming pads are exposed on the PCB on the bottom of the head but spaced very closely to the spring, so flashing firmware is possible just a little tricky. Inside the tail cap, there is a large spring, and this can be lifted up to fit a magnet in which I have done, It’s not quite strong enough to hold the light up on the side of a painted surface but more than enough to hold it upside down. I may order something else that’s stronger eventually.
Retention
In the hand it feels good, my thumb easily finds the button. To me, it feels like a normal 21700 flashlight. There is the wire hanger at the top which is useful for hanging the light from a string or branch. At the bottom, there is a place to attach the included lanyard, and as I mentioned I put a magnet in the tail cap that works decently well.
Size & Weight
I measured the length at 154mm, the diameter of the body at 26mm, and the diameter of the head at 45mm. I measured the weight at 6.48oz with the battery, and my magnet was installed.No water rating is given but it stands up to a shower just fine, it’s IPX8 rated like most flashlights from Sofirn. Here are some comparison shots with other similar lights I own.
LED & Beam
The light is using 4x Samsung LH351D LEDs that are mounted on the bottom of the dome only. They are in a square configuration. There are 2 tints of LEDs being used here, 2x 2700k and 2x 5000k LEDs both high CRI. My Opple meter measured them through the diffuser at 2893k and 4776 respectively both at 96Ra (CRI). The beam pattern is even and nicely diffused. With the tint ramping and the steps, this makes for a combination where you can adjust the light output to exactly what brightness and tint you want.
Output Measurements
I didn’t put this one in my lumen tube, because I couldn’t concentrate the majority of the light in the tube. Sofirn lists the max output as 310 lumens and a beam distance of 12M. While that’s not nearly as much as the LT1’s 800+ lumens I found it to be more than enough for close range and medium-range tasks.
Runtime & Heat
I ran 3 comparison tests, with each emitter tint comparing percent of relative output between the different tints. Not surprisingly Neutral white when all the LED’s are on had slightly less runtime of the other… Runtime wise they are all quite similar producing very usable light out to the 3:40:00 mark, and they keep producing out to nearly 6 hours, although much less output. The heat here is very controlled the light doesn’t really get very warm, and where it does it’s on the body since there are no emitters in the head.
UI
The light is using the Anduril 2 firmware which we have seen before on the updated version of the LT1 that a reviewed recently. I won’t give you a comprehensive guide here on Anduril 2, but I will say it has a lot of flexibility in tint and output, either ramping or stepped. You also have the special modes which I think work well here in a lantern-like lighting and candle modes. Yes the button is configurable too. Anduril 2 isn’t the easiest firmware to hand to an average joe but it’s super powerful and configurable once you get a chance to learn it.
Recharging
Recharging here is accomplished via USB-C. The light is C to C and PD compatible. The total charging time of the included 5000mAh battery was 3:51:00 with a charge rate of just over 1.6A. LVP was measured at 2.738v. The orange button LED when charging will blink blue when charging and go solid blue when charged.
The light is designed to work with a flat top unprotected 21700, but button tops work too, protected 21700’s are likely too long. 18650’s will work here too with little to no rattle. I tested the battery capacity at 4836mAh.
The light can be used as a powerbank to charge your USB-C devices from it’s 5000mAh battery. This is a nice feature to have, one I probably won’t use often but it was easy to include and could really be useful if you needed to top up your phone in an emergency situation.
Final Thoughts
I took the light around my 4th of July festivities and it passed through the hands of many, using it to find fireworks, find fuses, and as a light saber by my nephew who loved it.
This design is more prone to tipping over than the LT1 or LT1s, but not much more than most 21700 flashlights that are stood on their tail. I think Sofirn could have easily mitigated this by including a magnet in the tail cap. This could be an easy accessory they could sell on the side if they wanted and hopefully, they do this soon.
I think the LT1 Mini is going to be a size and weight that works for a lot of people, whereas the LT1 was just too big or heavy, and the LT1s is too large of diameter and it lacks the Anduril 2 firmware so many enthusiasts love. The LT1 is still the king when it comes to output and runtime but the LT1 Mini comes in a close second place while saving size and weight. It’s a sold recommendation for me.
