to get to 150/150 in advanced we must first manually Ramp to ceiling (if we double clic to ceiling, there is no double clic to Turbo). After Ramping to ceiling a double clic goes to Turbo.
That behavior can be changed in the ramp extras config menu.
good suggestion
Turbo style can be changed from Anduril 2 default (2C = ceiling), to use Anduril 1 Turbo style (2C = 150/150)
fwiw, I think the 120/150 ceiling in Advanced is actually more useful than changing the ceiling to 150/150…
I avoid turbo, and prefer to use lower outputs for better battery life and less heat
Unheard:double clicking on max ramp does nothing. Should be 150/150 then?
I know. That’s why I wrote ‘double clicking [should have been: when] on max ramp’.
Even if I’m wrong: I’m convinced my light was on ceiling=150 :weary:
I agree, and Im convinced you were in simple mode… lol :person_facepalming: :innocent: :partying_face:
Let’s have a look at the config:
#define RAMP_SMOOTH_CEIL 150
#define RAMP_DISCRETE_CEIL RAMP_SMOOTH_CEIL
#define SIMPLE_UI_CEIL 150
All ceilings are set to 150/150 by default. At least for the SP10 Pro.
Now let’s guess which firmware is used for the SC31 Pro. Probably the SP36 config that is used on most Sofirn flashlights. Here it is:
#define RAMP_SMOOTH_CEIL 120
Advanced UI has 120/150 while simple UI has the full 150/150.
aha! so unheard Was on the Simple Ceiling of SC31 Pro… :student:
much appreciate the help
