Spark ST6 460 NW
Summary:
| Battery: | 18650/ 2x16340,2xcr123a |
| Switch: | Digital push button |
| Modes: | lo mid1 mid2 hi turbo(double click) |
| LED Type: | Neutral XML T5 |
| Lens: | glass with diffuser included |
| Tailstands: | side stands |
| Price Payed: | $80 |
| Date Ordered: | 12/2 |
Pros:
Aggressive knurling on end caps
Cooling fins by head
Natural grey finish HAIII
Unpolarized battery insertion
Nice fully adjustable headstrap
Cons:
Dry threads on lens cap
Lo not low enough for me, more personal preference
Runtime:
Super: 460lm/1.4hours * Max: 300lm/2.5hours * Med1: 140lm/8hours * Med2: 45lm/28hours * Low: 8lm/8days
I purchased this headlight after the black friday sales from several online stores. I had emailed Jason from SBflashlights about getting this light and the latest Xtar Wp2II model. Ordered it on friday and arrived by monday via priority mail. It came in a nice black box with ample padding. It included the usual orings,headstrap,diffuser and Jason was nice enough to include the newly available stainless pocket clip. I believe they are $2.99 at his store.
Knurling on the endcap was grippy and threads came well lubed except where the lens cap is where it was dry. The battery can be inserted + or - first. either way does'nt matter. Both ends have springs and found that even shorter 18500s work no problem. Turning the cap quarter turn loose lock out the light. Pushing the button cycles thru the 4 modes and releasing it keeps it on that mode with memory of last used mode. Double clicking the button from any mode turns on turbo or super mode for 5 minutes then drops down to high. The button is recessed to prevent accidentally turning on the light. This is my first neutral white light and the first time i turned it on, it looked really yellow to me. The light manages heat quite well and does not get very hot.
ST6 on left and SC600 right both on mid on yellow wall maybe not the best background color. I have been using the xeno eo3 xml as my headlight for work and just was'nt happy with the short runtime on 14500s. The headstrap is fully adjustable and stays on comfortably. The neutral color does bring out the natural colors of the surrounding outside.
Really close resemblance to the ZL sc600. Are they related? Overall im happy with this light and will get much use this winter as darkness starts around 4pm in the midwest. The diffuser works nicely at evenly spreading the light coming out the front. The reflector which has a light orange peel surface, can also be taken out for even beam with no hotspot.
