What’s the emitter MCPCB size for Tank007 E09?
MCPCB is that the plate with the battery contacts, or is the plate with the LED emitter?
Emitter board.
Also do you know about how regulated the output is?
Is the output brightness/power constant?
Sure it has tons of power but how does it do over time and how long does it last with an AAA? And how long with a lion 10440?
I suppose it has some tiny boost driver?
What battery would you recommend for this flashlight if I want longer runtime?
I don’t mind sacrificing output brightness.
How does the driver work? Is it constant current boost driver?
Can it be modified adjusted?
To anybody thinking they could disassemble the head easily or without damage, forget it.
I got the last version fro FastTech, made in December 2012.
- Two pliers holding the head parts through leather.
No way. Actually scratched the head trough the leather.
Using anything else than leather means tearing it apart instantly, like a nonslip stuff etc. - Pliers with leather and a 14.5mm key, without the body, the head actually bends under the force of the key and the key would slip to next position if one continues to try unscrewing the parts.
- With the body in the head, it does not bend as much, but the head is tearing apart the leather in the pliers with the knurkling.
- I’ve also tried heating it up with a soldering iron set to 480°C, it got hot but it wouldn’t melt the glue as it does not get hot enough. Probably would have to bake it just below solder melting temperature and unscrew it while hot.
- In the end, put the pliers with almost 3mm thick leather in a vice, tightened it as much as I could and thought not to break the glass. With the body of course screwed into the head. Now used the 14.5mm key, which is normally snug fit, but as it bends under all the force it is not anymore in all positions. And hardly could unscrew the head with the key, making dents and stuff into the paint with the key as it was still bending the head a little.
- If I would try to snap it, break it, the key would jump positions I think. In the end it gave in and was not tearing apart the leather as I was maybe 3 times tightening the vice and trying to unscrew it with the key.
My advice to anybody trying to unscrew, don’t, unless you have something that can get a really really good grip on the heads knurkling and also a 6 sides 14 or 14.5mm key. And a file to modify your 14mm key to a 14.5mm. I’ve used a normal 2 sides key, not the round one with 6 sides. Really, do get a 6 sides one for this.
Tank is a really over gluing the head, it is some transparent stuff with a slight hint of green, it hardens a lot and it’s not grease like as on Kreislers picture.
A stupid superglue would have gave in long time ago, or thread lockers.
This is really some kind of nonsense they use. Glue that hardens and there was a lot of it, when I took it out quite a it of it fell on the reflector that stayed in the head.
The MCPCB is 11.5mm, and those 12mm MCPCBs from IS are the exact same thing.
XP-G is 11.5mm same as in Tank007 E09.
XM-L is 11.5mm, fits there too if you modify the reflector or change it for an XM-L reflector.
Great info, JackCY!!
Some E09 units may have a droplet more glue in the threads than others. E09 V1 didnt have glue in the threads so people like myself easily opened the heads and by doing so automatically compromised the insulation layer. E10 and E11 have even more of the nasty green hardened glue. I'd prefer Tank to install a plastic insulation spacer (thin foil) and not use any glue in E09/E10/E11, oh well *sigh* :~
Sorry for you scratching the anodization :O
I know this thread has been around for a while, but I want to thank kreisler (and everyone else) at this late date for such a thorough look at a cute budget light…
EDIT:
In the past months the DD price was 18.99$ and i waited for the regular price drop. Today they did it, and believe me this aint gonna stay for long. Maybe for 3 weeks max, until they play with the prices again. So if you ever wanted to buy the E09 from DD (because of 200 birthday Dinopoints, LOVELY discount code, or DD giftcards from previous DD orders) then this is now the time.
E09, black: 12.69$
E09, gungray: 13.99$
E09, pink: 14.39$
DD knows that the E09's are the most popular Tank007's (see left-hand panel "Hot Products"), which is the only reason why they had raised the prices to the ridiculous 18.99$. The 10% OFF code LOVELY still works. I just got rid of my gc's and dinopoints, PP paid 10.01$ for a 26.68$ cart $)
no more DD, DX, MF, KD, WB, BG, etc. for me. Whatever i need, i can get from HKE, FT, EBAY, AMZN, NKON. Now crossing fingers that DD doesnt mess up my E09 orders and that the E09 are flawless as my other copies.
ImCoolMan just posted about AuraBuy having it for $12.49 (brown color).
Very cheap… not a bad knock around light. This is about the limit of what I’d pay. The very noticeable PWM and starting on HIGH would annoy me to no end if I’d paid like $20 for this. Btw, isn’t there another Fenix LD01 clone out there that’s supposed to be nearly as good for around $25?
i haven’t done the math but you could probably get the LD01 and L01 giftset from Wallbuys for roughly the same price ($25) with the current sale code … i remember paying around $30…
edit
http://wallbuys.com/Product/Fenix-LD01-Cree-XP-G-LED-R4E01-AAA-EDC-keychain-portable-flashlight-Pack-set-5361
~$35 with discount code
^ and…. Russian is supposed to be helpful on a predominantly English speaking website? S)
You mean you have the sound turned up for these videos???
Kreisler think we have Samsung S4 phones with translation programs.
Do not know if they do Russian?
that video real? omg
so much more advanced than our primitive lamps!!
why are we still bothering with flashlights .. let's go together and begin a new hobby: smartphones and appz!!
:D
I just recieved a DUD from Alexipress. Emitter is way off center, and it flickered a fiew seconds after turning it on, then died. no longer turns on at all…
what's your serial number?
your sample has got a compromised insulation layer, see my review for details and fixing.
in any case, get a partial refund or reshipment :)
noted the serial number in the other topic to your reply there.
Such a sexy review that I get a hard on each time I see it…
Gotta re-read it with all the updates. Saved in my dropbox folder just in case
Thanks again kreis!
See below, the repeated C9000 tests (steps: s#01-s#06, s#08, s#10, s#13) prove that C9000 is very consistent at showing that the 4 cells have the following properties
- AA#1 and AA#2 have about the same capacity. pretty much equal!
- AA#8 has about the same capacity as AA#1&AA#2 too, or it is slightly higher.
- AA#4 has definitely the highest capacity of all 4 cells.
- All 4 cells are on the same level of capacities. for a chosen test, the average difference between AA#4 and the rest is typically not more than 15mAh
After each test step i left the 4 cells for many hours in the C9000 (in order to get a stationary condition in the cells) and then i put them altogether in a single 1S4P battery holder (in order to get a equalized voltage in the cells). Here again, i left the 4 cells for many hours in the battery holder, so that they would have the identical voltage before starting the next test step. "Many hours" was anything between 4-8hrs, for example over night.
Refresh&Analyze @1000mA/-500mA, Discharge @-500mAc9000 program | notes | slot1 | slot2 | slot3 | slot4 | more notes ;-) |
my 8 Eneloop Glitter had 2037mAh when brand-new |
i picked the 4 cells with similar capacity |
Eneloop AA#1 | Eneloop AA#2 | Eneloop AA#4 | Eneloop AA#8 | i've been using the other 4 cells (AA#3,#5,#6,#7) for XP4 tests hehe |
s#01: Refresh&Analyze | did several R&A's before but i am counting this one as "s#01" |
1989mAh | 1989mAh | 1991mAh | 1994mAh | See? they are indeed very similar |
s#02: Refresh&Analyze | between s#01 and #02 i did several other tests, so i had to do this new R&A |
1954mAh |
1960mAh |
1966mAh |
1961mAh |
cells are still on the same level, just a lower level |
s#03: Discharge |
after each step, i leave the 4 cells in the C9000 for hours and then equalize them for hours |
1912mAh |
1913mAh |
1918mAh |
1916mAh |
perfect result because they show same level and similar "tendency" |
s#04: Refresh&Analyze |
another R&A to get the cells back charged! |
1990mAh |
1990mAh |
1997mAh |
1990mAh |
wow, even nicer result! let's note the tendency, it is AA#1 ≈ #2 ≤ #8 < #4 |
s#05: Discharge |
for data integrity let's discharge them again |
1898mAh |
1881mAh |
1917mAh |
1905mAh |
not bad result. about similar level and tendency. it's okay. |
s#06: Refresh&Analyze |
before we can start nc2500 discharge tests we must recharge again of course lol |
1960mAh |
1963mAh |
1970mAh |
1961mAh |
not bad result. same level and similar tendency, AA#4 > #8 ≈ #1 ≈ #2 |
s#07: Discharge from 4×1.4434V |
1st nc2500 test: discharging AA#1,#2,#8! "mAh" is c9000 LCD, "nCh" is nc2500 LCD. |
1990nCh |
1980nCh |
1913mAh |
1970nCh |
wrong tendency, nor have AA#1,#2,#8 a similar level. that's bad! |
s#08: Refresh&Analyze |
let's reset the 4 cells before we repeat the tests. this way they get charged too lol |
1949mAh |
1954mAh |
1963mAh |
1961mAh |
good result because same level and correct tendency AA#1 ≈ #2 ≤ #8 < #4 |
s#09: Discharge from 4×1.4467V |
2nd nc2500 test: discharging AA#1,#2! they should be equal, and lower than AA#4 |
1994nCh |
1987nCh |
1904mAh |
1918mAh |
AA#1≈#2 okay, but level is wrong. too high. much higher than AA#4 |
s#10: Refresh&Analyze |
for the next test we must charge first lol |
1953mAh |
1956mAh |
1966mAh |
1965mAh |
tendency perfect, level the same. great result! |
s#11: Discharge from 4×1.4600V |
3rd nc2500 test: discharging AA#1,#8! |
2018nCh |
1898mAh |
1929mAh |
2000nCh |
AA#1 is ~118mAh higher than what c9000 would have measured. tendency wrong too! |
s#12: Charge in xp4 to stationary voltage |
4th nc2500 test: discharging AA#2,#4! |
1.4855V 1955mAh |
1.4866V 2047nCh |
1.4856V 2025nCh |
1.4885V 1956mAh |
AA#1 ≈ #8 as expected but AA#2,#4 are on too high level and wrong tendency |
s#13: Refresh&Analyze |
checking cells before declaring this test series as finished |
1969mAh |
1966mAh |
1976mAh |
1965mAh |
perfect result. same level, correct tendency! |
Summary:
See above, the four NC2500 discharge tests leave no room for data interpretation other than this: The NC2500 shows too high discharge capacities compared to the C9000. On average, for a particular cell (Eneloop AA, nominal 2000mAh) the NC2500 would measure a ~80-120mAh higher discharge capacity than the C9000 would display as final result in the LCD. In addition, NC2500 doesn't get the tendency right either!
C9000 discharge capacity measurements seem very consistent and accurate.
NC2500 discharge capacity measurements seem inconsistent and inaccurate and certainly do not match the C9000 results.
