This is the ThruNite Archer 2A V3 (Upgraded model of the 2A V2) This light was sent in return for my review , with no other compensation other than keeping the light. I will say again , as always I try to do my best to give my honest opinion on any light I review , purchased or free.
I will start by saying the little Archer lives up to the build quality that is usually associated with the ThruNite name. This is a well built little light and performs well for the small form factor and AA / NiMH cells. I mentioned in the video (and also pointed it out) that there are some marks on the bezel of this light. They WERE NOT there when I received this light , I made the marks being that I was determined to get the light opened. The anodizing , fit and finish were all very well done when I took this light out of the box. The tail threads were lubed well and they are some nice little square cut threads. The tailcap has the “thumb” cut out for easier access to the small switch also and this particular light tail stands reasonably well on a smooth surface.
I may try later to open the rest of the light with a different method , but it is sealed with RED Loctite so it may or may not come apart. If I succeed I will post any updates at that time.
I did get a few comparisons (not calling brand names) but for those who have the PF04 and the A6 , there are some side by side still shots for size comparison in the slide portion of the video as well as a few beamshots (starting at 4:21) and then there is also some live footage of the Archer compared with the PF04 and the TG06 (all using NiMH cells) and showing beam intensity , in the live outside footage portion of the video. (starting at 6:51)
Overall I feel this is another really nice little light from ThruNite and they DO offer it in both Cool and Neutral tints.
The one complaint I had with it is the clip being in the middle of the light when positioned for “head down” carry , instead of closer to the tail end , other than that I really have no other cons personally.
Again I want to mention that the still shots in the slide portion of the video , show much more true to life what my eyes see , than my cheap video camera does.
Amazon link here……. Amazon.com
Video followed by the listed specs and Links for direct ThruNite site and for different countries (All links Non Affiliated)
Amazon US: https://www.amazon.com/dp/B01FCTD9PG/
Amazon CA.: http://amazon.ca/shops/A1BNV2EQ2FFXQR
Amazon UK.: http://amazon.co.uk/shops/A2DUUB2J3TY3X1
Product Description
•Upgraded version of the Archer 2A V2 with more user-friendly UI.
•Five modes: firefly, low, medium, high and strobe.
•Momentary “forward clicky” tactical switch.
•Strike bezel for defense and emergency applications.
•Wide working voltage enables two normal AA batteries.
•Reversed polarity protection system prevents damage to the light.
•Orange peel reflector for a high quality beam.
•Ultra clear tempered glass lens with anti-reflective coating.
•Aircraft grade aluminum body structure with tactical knurling for firm grip.
•Premium type III hard anodized anti-abrasive finish.
•U shape groove at the tail for easy ACTIVATION as well as preventing accidentally activation.
•Reversible and removable pocket clip with titanium coating for durability.
•Memory function to set any mode(except for strobe) for immediate use.
Specifications
•LED: CREE XP-L V6 LED with a lifespan of 20+ years of run time.
•Modes & Run-time:
-Firefly: 0.2lumen(28days);
-Low: 17lumen(4days);
-Medium: 75lumen(11hours)
-High: 500lumen(96minutes);
-Strobe: 500lumen(140minutes).
•Max output: 500lumens using two AA batteries.
•Max run time: 28days (Firefly mode)
•Working voltage: 0.9v to 5.0v.
•Battery: 2 x AA batteries (not included).
•Max beam distance: 108 meters.
•Peak beam intensity: 2912cd.
•Impact resistant: 1.5 meters.
•Waterproof to IPX-8 Standard (1.5meters)
•Weight: 48g without battery
•Dimensions: 155mm in length, 22mm bezel diameter.
•Accessories: Pocket clip x1, Spare O-ring x1, Lanyard x1.
Operation
•To turn on/off the light:
Press the tail cap halfway to momentarily ACTIVATE the light. Click the tail switch to turn the light on and off.
•To change modes:
Five modes in total: firefly, low, medium, high, and strobe.
When the light is on, single press the side switch to rotate among firefly, low, medium and high.
Long press to get strobe and then single press to end it.
Memory function: The light will turn on in the last mode accessed, except for strobe.
•Battery replacement:
Take off the tail cap, insert the battery with positive polarity toward the LED assembly(head of the light)
INSTALL the tail cap and tighten all the way to operate the light
