A few words for ThruNite Neutron 2C :
The Neutron 2C V3 micro-USB chargeable flashlight adopts a latest CREE XP-L V6 LED to make output up to 1100 lumens with the combination of an interesting ramping UI .
Overview/Specifications :
- LED: XP-L V6 with a lifespan of 20+ years of run time.
- Compatible with: 18650 x 1, 18350 x 1, CR123A x 2, 16340 x 1, 16340 x 2
- Working Voltage: 2.7 - 9.0 V.
- Output mode/Runtime:
Strobe(650 lumens /5 hrs)
Turbo(1100 lumens /2.2 hrs)
Infinity High(650 lumens /2.7 hrs)
Infinity Low(12 lumens /130 hrs)
Firefly(0.5 lumens /49 days). - Peak Beam Intensity: 14399cd (max).
- Max beam distance: 240m (max).
- Impact resistant: 1 meter.
- Waterproof to IPX-8 Standard (2meters).
- Weight: 86g without battery.
- Dimensions: 125 mm in length x 25.4 mm in body diameter.
- Accessories: Holster x1, Spare O-rings x2, Lanyard x1, Pocket Clip x1, 18650 3400mAh Battery x1, USB Charging Cord x1
First Look :
Flashlight in it’s box , the classic brown Thrunite box , which i have to admit that i really like :
Package Contains :
- Flashlight
- Holster
- User manual
- “Thank you” card
- Lanyard
- 2x O-rings
- Pocket Clip
- E-switch rubber “sealing”
- 2x extra charging port rubber sealings
- Thrunite 18650 3400mAh battery (inside the light)
A closer look :
Here we have latest Thrunite flashlight , the Neutron 2C . Another all-in-one solution , like the tc12 v2 but i would dare to say with a better UI (that we will discuss later) :
What’s special about this light ? A battery tube that accepts a lot of different battery combinations with the use of a removable extension tube :
Light with the small tube
And now length is only ~94mm :
Let’s get in the details now !
Flashlight’s head has a nice minimal design , with the metal e-switch and the charging port on the back side .
Through the e-switch you control the flashlight . Notice also the little led in the center of the switch , which works as a battery/charging indicator :
Back side , with the USB charging port :
Flashlight has a SMO reflector and AR coated lens :
Reflector is deep ! In the center you can see the nice cree xp-l :
The pocket clip which is also removable :
Tube has kind of aggressive knurling , but i think it adds a lot of grip :
The end of the tube is flat , and has a small hole on the side that accepts a lanyard :
Nice , “square” & anodized threads :
Here is a photo of the positive terminal that the battery makes contact :
Flashlight’s Holster :
Holster is designed for Neutron 2C , it’s a pefect fit! :
Battery :
This is the battery that comes with the light :
It is button top , protected , but it has a high discharge rate :
Actual capacity tested : 3430 mAh
How it works (&modes) :
Turn ON/OFF :
Single click the switch to turn the light on and off.
Shortcuts from OFF :
Long press the switch to get firefly mode.
Double click the switch to get turbo mode.
To Change Modes:
When the light is on , long press the side switch to increase or decrease flashlight’s brightness , wherever you want , in the 12-640 lumens range. If the light blinks , it means you’re in the min or max setting , and it will start to ramp in the opposite direction if you don’t stop pressing the e-switch .
Double click from any mode to turbo, another double click to get strobe.
Memory Function :
The light will turn on in the last mode accessed, except firefly, turbo and strobe.
Ramping mode video or gif :
Coming soon…
Battery Indicator :
When you’re in ramping or turbo , the little led in the center of the e-switch works as a battery indicator .
| Voltage | Above 3.2V | 3-3.2V | 2.8-3V | Below 2.8V |
| Indicator Color | Blue | Flashing Red | Red | Flashlight turns off |
Usb Charging / Indicator meaning etc :
When the flashlight is being charged , RED led is on , but after being fully charged, BLUE Led will be on. It takes around 4 hours to fully charge the 3400mAh battery.
| Voltage | 2.7-4.19V (Charging) | 4.2V (Full) | Error (Ex No battery inside OR damaged battery |
| Indicator Color | Red | Blue | Purple |
Charging Current : 1.00 A (pic here )
Termination Voltage : 4.19 - 4.20 V
Measurements :
Thrunite 3400mAh battery was used in all measurements
Lumens :
- Firefly - *< 1 lumen*
- Ramping min - 12 lumens
- Ramping max - 640 lumens
- Turbo - 1072 lumens
Note : Tested flashlight’s performance with an Enercig IMR 18350 and found out that the light performs as good as with the 18650 (but with lower runtimes of course) .
Intensity : 12,7kcd
My runtime tests :
Turbo mode :
Ramping max :
Over 90% of the total output (about 580 otf lumens) for about 110 minutes .
Beamshots :
Wall @ 12m :
Control shot :
Turbo :
Ramping max :
Ramping min (a little over exposed to be seen) :
My flashlight is the cool white version but tint isn’t green , but a tiny bit rosy .
Conclusion :
Here are my thoughts about this flashlight… It is a great light , made with high quality components and a really good anodization (and it has been proven from older beaten up Thrunite lights) . It is a good all-in-one solution if i could describe it in a few words . The flexible ramping UI is very useful , letting the user select the desired brightness without the limit of the 3 or 5 modes , and great shortcuts in moon / last used mode / turbo . It accepts a lot of different batteries combination , which i find really handy … With a bit over 1000 lumens on it’s max setting , a nice tint (my CW tint is rosy without a hint of green) , a nice battery indicator and a fast usb charger inside the light i believe it is a great choice if you look a flashlight that can fulfill most of your needs .
More info can be found in my detailed review ![]()
Comment if you want me to check something on the flashlight , or tell your opinion . Thanks !
Official Website : http://www.thrunite.com
Amazon US : Amazon.com: ThruNite
ThruNite Neutron 2C : Neutron 2C V3 - ThruNite Official Store
Be sure to try coupon code JULY for 20% off until July 16th .
