This light was kindly loaned to me for review by Ezarc.
To the light arrived in a very sturdy brown box which was built like a safe compared to the white boxes we normally receive lights in.
Inside the box was a nice thick foam protective pillow. This is the best packaging by far I have received any light in.
The included accessories were packaged under the light further providing protection for the light itself not that I think with the box it would ever need it. The Holster, Lanyard and o'rings were of first class quality and could not be faulted.
The TN12 size wise with its bigger brother the LYNX.
And up against a more common light the SolarForce L2M.
The light is operated by two switches. The forward switch operates the modes and the tailcap switch is on and off. I believe that the front switch is electronic and to prevent the batteries going flat the power is turned of with the tailcap. l'm a fan of this sort of setup if the driver has an electronic switch even though it does add to the overall length of the the light. The current light I'm building will have this same set up (its ok as I'm not the one wiring it up). Both switches have a smooth firm push to them. Accidental turn on would be almost impossible. The tailcap switch can also be used as a momentary switch if its not pushed all the way in to turn the light on.
The spring on the switch in the tailcap for battery contact is reasonably soft. At the current the light is operated on it will be fine.
The reflector is flawless and the lens has a nice blue AR coating on it. The XML-2 is perfectly centered. Please excuse the foreign material on all my pictures. It does detract from the quality of this light.
All threads were amazingly square and o'rings a perfect fit. The pocket clip was sturdy and will fit thick belts without an issue.
The driver spring is only short being about 5mm in length. with the spring setup and the design of the light the light should accommodate the longest protected batteries to the shortest non protected batteries. Modes are simple with 5 light output modes and a hidden flashy mode that is simply accessed by pressing the forward switch for about 1.5 seconds with the light turned on in any mode.
The battery used for testing was supplied by Thrunite as well. It is rated at 2600mAh.
The run times and temps is as per below. The output measurements were simply a ceiling bounce. Temperature at the time was 15 degrees celsius. Battery protection on the driver kicked in at 1.09 hours with the light stepping down in output and quickly flashing twice with a pause, before it would flash again.
Night shots. The distance to the windmill is approximately 16 meters. Only max, high and med shots were taken as low and lower low did not take a picture. There is not a lot of difference between max and high visually. Tailcap measurements were, max 2.63 amps, high 2.13, med .6, low .07 and really low .03 amps.
The pictures in series maximum, high and medium.
To sum up this is the best light by a country mile l have had the good fortune to review. To say I'm a fan of this light would be an understatement. From the near perfect machine work, quality of the combined parts anodising and the simplicity of operation,it is simply hard for me to fault. If I had to find fault it would be the modes but this is purely subjective. I have no hesitation in recommending this light to anyone in the market for a light like this.
