My review of the striking TrustFire MINIX3 Flatlight!
UV - Front light - CRI95 side light - Powerful Laser
Thanks for anothet excellent review. I really don’t need another light but I just had
to order one of these. A little disappointed that it does not have a user changeable battery
because, after several years of using my Rovyvon’s that only hold a charge for a short time now and,
since LI-PO’s are supposed to be able to handle many more charge/discharge
cycles than LI-IO, will give it a try.
If it was tap for on/off it’d be an awesome light imo.
I need a sexy light- Said no one ever
Just received it, pretty interesting light. Feels very solid in the hand, build quality is excellent and
the light output is more then well enough for normal EDC use. Like having LED, Laser and UV in
one unit. One thing I noticed though, while the manufacturer states the battery is
built in and not user changeable, there are two small screws at the base of the
unit that, once removed, would seem to let a plate that’s under the battery
be taken out which I believe would then expose the battery. Wont try it under warranty
but, as the months/years go by to the point where the built in battery no longer holds a
full charge, I will look at trying to removed this plate to see if it can in fact be changed.
Thanks again for the review.
