It was a PITA to read through this thread when I was looking for modifying info. It was some info on that page, and some on another page…
Instead of adding more modifying stuff in between all kind of talk about this light I made another thread about my light (from wallbuys). Thread here.
It does not have the typical driver.Here is one of the pictures of it.
After your post I ended up ordering the manafont driver. In the pics on the website it looks identical to the TF driver to which the resistor mod is done earlier in this topic. So I ordered it hoping to replace the driver in my TR-3T6 (which I now suspect might be fake) as my driver doesn’t have an R5 (not used) and R7 position, but an R2 and R5 position which are both used.
Imagine my surprise when the driver arrived and it was identical to the one I already have, so you don’t get the one pictured on manafont! Now what? Not happy obviously…
Well, I was a bit skeptical about how that driver would look and perform stock…
Its a reason (several actually) why I considered a driver from IO a month ago, and why I ordered one yesterday… (not that one I looked at that would fit nicely in the light)
Only bad thing is that the IO drivers just had a little price bump…
apt323, have you checked if you had the same driver as I got on my wallbuys light? I remember you had the same tailcap readings… I would say that was a good driver, and dont really see why there should be a reason to change it out for the manafont driver…
Personally, if I had not desired the features on the IO driver I ordered I would have just bought the LD-29 for 5.59$ (before discount) if I never had plans of using 3 cells. You would have to remove the 21mm board and modify it to your current 26mm board though… Should be easy…
Maybe Werner can help out if he gets some pictures if the 2 cell manafont driver… It seems most boards can be modified with a resistor mod. How well it works, how reliable it is, and how efficient the driver will be after the mod is another story. But that is some of the fun with modding.
As you can read in this thread, mine went through a lot. Had it not been for the unlucky short circuit it would have lived today after lots of abuse.
No big loss for me though. I had a fun project, and now got the reasson I needed to buy a driver from IO… … Should be a win, win project if the IO driver lives up to its paper specs…
Will try and get pics. Size wise looks identical to the one in this topic to which the resistor mod has been done (so its 2-piece). The difference I can see is the location were the new resistor is placed (R5) is labelled R2 on mine. There doesn’t seem to be an R7 (unless its behind the coil). Mine does have R5 as well but, in the original pic it has no resistor in place, where on the boards I have there is a resistor in that position already.
So recap; mine has R2 and R5 both with resistors.
The one is see the mod done to has R5 and R7 with no resistor I place in R5 (before mod).
RaceR86 - wanted to have a backup just incase something like what happened yours happened to mine when I went to mod it. Those little bitty components are small for my old eyes…. More of a backup then a swap out.
Here are the images regarding the manafont driver.
The 1st picure is the driver manafont sent me (I found there is an R7 position as well, it was hidden behind the coil; so that makes R2,R5 and R7 all with resistors)
The 2nd picture is what they show on their website (only R5 and R7, with R5 empty) <-what I wanted (and expected!) to receive…
R7 has an R100 resistor.
See The problem is I just wanted to do a simple mod that others have done before me.
First my flashlight didn’t have the driver I thought, so I ordered this one (which was the same as the one in my light already). I don’t know what the output is and I don’t have a multimeter. As I normally don’t do these kind of things, I’m not gonna buy a multimeter just for this as I might as well buy a new (more powerful) flashlight then…
