Youtube review link: https://youtu.be/0yp0YZR7MxU
Hello guys, good afternoon
I bought a UGREEN charger and a USB cable several days ago, and today I got them, so I decide to make a video, I will test the performance and see if it can match the technical parameters. Before we open it, we can have a look at this two products.
Charger first. From the front side, we can the brand “UGREEN”, charger icon, and three protection function: over current protection/short circuit protection/over temperature protection.
On the back of the package we can see more details, one USB-A port, it can provide 5V/2.4A output, and the other port is USB-C output, it has PD quick charge function and it can provide 5V/3A or 9V/2A output. The total power of two ports are 30W.
By the way, according to the purchasing note of the charger, the USB-C port which supported PD 18W quick charge can only be used to charge iPhone 8 above, for iPad Pro, it can only support 11inch/12.9inch iPad Pro.
Here is the cable, it is a USB-C to lightning PD fast charging cable, it can support 3A max current.
There is one more thing I need to tell you, not every USB-C to lightning cable can support PD quick charge mode, you need to buy a cable with MFI certification.
A cable without MFI certification may cause damage to your devices and when you insert it into your iPhone, you will get a warning “this cable or accessory is not certified and may not work reliably with this iPhone ”The seller says this charger is as good as the original charger, and it is made for iPhone quick charge, under PD quick charge mode, it can charge 50% in 30 minutes, we use iPhone as an example, the capacity is 2700mAh, energy is 10.35Wh, so it can be realized with 18W quick charge.
When the battery is empty, it will use PD mode to charge the iPhone, and if the battery is fully charged, the power will reduce to ensure that the battery is fully charged but will not be over charged.
OK I have introduced the technical parameter and later we will test the charger.
First open the package
We can see that there is a charger and a warranty card (inside the box)
Now we measure the actual value according to the target parameters. We are using the iPhone X as the charging object:
We use UM25C to measure the voltage and current of the USB-A port (5V/2.4A) charging mobile phone:
The result is 4.93V/2.15A.
Then we use TC66C to measure the charging current of type c port:
This should be its nominal 9V/2A charging mode with a small current value.
Next, I will test the protocol supported by the TYPE-C port. The TC66C has the function of measuring the port to support the fast charge protocol, and switch to the quick charge protocol detection interface for detection. The result is red indicating that the charger does not support the protocol, and the green indicates that the charger supports Fast charge agreement
From the figure we can see that this green charger supports QC2.0: 5V/9V/12V, QC3.0, TYPE-C PD fast charge and Huawei FCP 9V fast charge
By the way, it can be measured whether the simultaneous output of the dual port can reach the said 30W output:
total power of the two ports is 27W, which is not much different from the 30W marked.
Next, check the charging rate to see if you can use the 9V/2A quick charge mode to fill 50% of the electricity in 30 minutes, but we found a problem during the test. The charger can't use 18W fast charge. Charge the phone, the power is about 12W, a difference of 1/3 of the power, we have to find out what is the reason.
We test with 2 chargers and 2 wires.
they are UGREEN charger, shunsi 9V/3A charger, xiaomi 9V/3A charger, UGREEN 3A USB cable, iPhone original USB-C to lightning cable.
here is the result:
The charging power does not exceed 12W, which can eliminate the quality problem of the line and the charging head. It should be that this mobile phone does not support 18W fast charging.
Next we measure the heat in full working conditions.
On the left is a 24W charging head. We make a comparison. The result is not accurate because the green is 30W output, both of which are stable at full power for 10 minutes, and the initial temperature is 35 ° C and 47 ° C.
The final temperature is as shown in the figure, 44 ° C and 66 ° C
24W charger increases 9℃ and UGREEN charger increases 20℃
Summary: The charging effect of the green charger is definitely above, but the heat dissipation capacity needs to be improved.
