[Review] Wurkkos HD02 Pro - Best allround Wurkkos yet?
Wurkkos HD02 Pro
Introduction
I never had the original HD02 in hand, though I did have the HD05 – and I actually really like that one. So when Wurkkos offered me the HD02 Pro, I agreed pretty quickly. Beforehand, I had already read about a few issues, on the one hand with the adhesive on the wing light covers, and on the other hand with the charging function, so I was curious to see whether my sample would also be affected or if Wurkkos had possibly already resolved these issues.
All my reviews can be found on my website.
Disclaimer: Wurkkos provided this light to me free of charge. This has had no influence on the review.
Specs by Wurkkos
The HD02 Pro is currently only available in one version – blue, as shown here. Wurkkos regularly releases new colors, so checking Wurkkos.com is always worth it.
Package Contents and Impressions
Typical for Wurkkos, the light comes in a white box with a picture of the flashlight on the front and all the key specs on the other sides of the box. Inside the box, the light sits in a plastic bag inside a plastic tray, with the accessories underneath. Included alongside the light with the battery already installed are two spare O-rings, a lanyard, a USB-C to USB-C cable, and a manual.
My first impression of the light was very good, though I was surprised that it actually feels noticeably larger than the HD05. To be fair, the light is still reasonably compact and by no means huge, but the second wing simply takes up space.
In terms of build quality, the HD02 Pro makes a good impression. The anodizing is nearly flawless, with only one tiny spot on the bezel where it is not completely uniform. Of course I also tested whether the diffuser panels over the side lights lift up on my unit. The first time I ran the side lights on high while the flashlight was cold, looking closely I got the impression that the diffusers were lifting slightly. I pressed them back down, and the issue has not happened again since. I also could not reproduce it by leaving the light outside for a while at temperatures around 0°C and then running the wings on the highest level.
Printed underneath the wings is a brief set of operating instructions for the side lights. This nicely demonstrates that the laser etching is of a high standard. Even the tiny arrows are super crisp.
Just like on the HD05, the detent balls used to lock the wings leave marks in the anodizing. However, this is unavoidable with this type of locking mechanism and has not gotten any worse on my HD05 despite heavy use.
That was more criticism than the light actually deserves, as the overall fit and finish are at a high level. The tailcap, finished in black as a contrast to the blue body, features a tripod thread. An O-ring seals the battery tube. The integrated magnet pulls the battery out with it. I always find that quite convenient when swapping cells.
The wings are noticeably stiffer than on my HD05. Especially right out of the box, when the light was very cold, it took a surprising amount of force to move them. After a few uses, they break in to a tension that is still firm, yet comfortable.
Unlike on the HD02, the wings can also rotate and can be adjusted flexibly and independently into virtually any orientation – however, rotation only works in one direction, namely toward the switch.
On the back of the light sits a USB-C port covered by a rubber flap. The cutout is large enough that most cables should fit. Only very thick plugs might cause issues, though even my thickest cable (from a laptop docking station) fits.
On top of the light is the combination of a rotary selector switch and push button, a setup already familiar from several other lights by now. The rotary switch clicks cleanly and positively into each position and will only turn accidentally under awkward pressure. The push button has a pleasant tactile feel and actuates at 800g of force. Just like the tailcap, the ring around the switch is finished in black, while the button itself is blue again.
In the center of the button sits the charging and battery level indicator. It has four stages and is easily readable even in daylight.
On the head/the area in front of the switch there are two cooling fins, followed by the black bezel, which ties in nicely with the color scheme and finishes off the front of the light. At the front of the light is an AR-coated glass lens. Underneath sit an SFT-70 Gen 2 for the white light, a 660nm red LED, a UV LED, and a green laser.
The light is certainly neither small nor lightweight, yet it feels great in the hand – in my case even a bit better than the HD05. The cutouts on the wings provide good grip for the fingers, while the bevels at the tail end rest comfortably against the heel of the palm.
Size
Wuben X4, Wurkkos HD05, Wurkkos HD02 Pro, Sofirn ST2, Acebeam UC3A
The light weighs 255g with the battery installed. It measures 126.5mm in length and 41mm in width. Thickness without the clip is 26.5mm, and 34.3mm at the thickest point measured across the clip and switch.
Carrying Options
Lanyard: A basic lanyard is included. It holds the light securely and offers enough room even for larger hands. It can only be attached to the clip. If you are not using the magnet in the tailcap, you can also thread a D-ring screw in there and attach the lanyard to it.
Clip: The HD02 Pro is probably a light that very few people will carry in a pants pocket. It is therefore nice that the clip is large, wide, and sturdy. The opening is wide enough even for thicker fabrics and webbing, and the tension is dialed in so that you can still easily clip it on one-handed, yet the light will not come loose unless excessive force hits it at an awkward angle. The clip is mounted so that the head faces up and extends quite a bit past the clip. This makes it easy to clip the light onto a backpack strap or chest strap and aim the wings down to light up the ground in front of your feet.
Magnet: A light in the size class of the HD02 Pro is always a challenge for a tail magnet. Wurkkos uses a suitably strong one that securely holds the light in any position without any issues.
Pocket carry: For a pants pocket, the HD02 Pro is too large for me, whereas in a jacket pocket or inside / attached to a backpack, its size and weight are easily manageable. Thanks to its well-thought-out ergonomics, the light carries more compactly in a pocket than it looks.
UI
Explanation 1C, 1H...
1C: short click, 2C: double click, …
1H: press and hold without letting go
2H: short click, followed by 1H
Operating this versatile Wurkkos is refreshingly straightforward. The rotary switch positions are self-explanatory. The simplest one to operate is the laser – it only has on and off. The light can be locked or unlocked with 4C in any switch position.
State of the light
Switch on White
Action Result
off 1H lowest brightness level
off 1C On – last used brightness level
Off / On 2C Highest brightness level
Off / On 3C Strobe
Strobe / SOS / Beacon 2C Strobe → SOS → Beacon
on 1C Off (except after activating the highest level with 2C, then returns to the previous level)
on 1H ramping
State of the light
Switch on UV/R
Action Result
off 1C UV, last used level
Off / On 2C Red, last used level
on 1C off
On, red 3C Beacon
on 1H UV: toggles between low and high
Red: ramping
When you fold out the wings, they turn on automatically. From there, they can be turned off and back on again with 1C. 2C puts the wings at maximum brightness, and 2H adjusts the color temperature. If the wings are on and you fold them closed, the light source selected via the selector turns on.
Beam Profile and Measurements
All measurements were done in my 30cm integrating sphere. The temperature was between 20 and 24°C. Additionally, an Opple Light Master III and a TASi TA636B lux meter were used. Please note that this is hobby equipment, so inaccuracies and deviations are possible!
Output and Beam
The beam pattern of the main front light is very clean overall. The hotspot has slight fringing around the edges, though this is only noticeable on a white wall. While the hotspot is fairly well defined and the spill is somewhat restricted by the bezel, this does not detract from the all-around usefulness of the beam. The hotspot offers good throw while still being wide enough for close-up use in front of your feet. The red light has a very similar beam profile, which makes switching between them quite pleasant! The UV light is unfiltered and rather throwy, slightly more focused than the main light.
Max. in 1st minute Lumens at 30s Max. temperature Temp. @ 30s Runtime ANSI FL1 runtimes
Wurkkos HD02 Pro main light max 3062 lm 2656 lm 53.8 °C 31.9 °C 2h 19min 2h 17min
The light’s output matches what I would expect from a 21700 flashlight of this size with an SFT70.2. Sustaining 900lm for just under two hours is a solid result. You have to keep in mind that the wings do not contribute to heat dissipation.
For the wings, there is only a relative scale, as I don’t have a good way to measure their output. Regulation is good, and there is no reason to doubt Wurkkos’s rated specs. The little wings do get quite hot during continuous operation!
I also plotted runtime graphs for the red and UV lights, and there is nothing to complain about there either. I cannot provide absolute lumen figures, but the shape of the curves should speak for itself.
I measured 25300cd, which translates to a throw of 318m.
CCT, CRI, DUV, PWM
Front Light Lowest Setting Front Light Highest Setting Side Light Cool Lowest Setting Side Light Cool Highest Setting Side Light Warm Lowest Setting Side Light Warm Highest Setting
CCT 5500 6200 6000 6000 2700 2700
CRI 65 70 100 100 95 94
DUV 0.010 0.003 -0.001 -0.001 0.000 0.000
Flicker is always in the green zone, PWM is not detectable with the eye or camera.
You can find the test results for the main light here.
Beamshots
The beam of the main light is limited by the bezel - but that is only noticeable at close range.
The laser is bright and produces a clean beam with no stray side reflections.
The 600lm from the wings provide very even flood illumination with very good color rendering.
Batteries and Charging
The charging behavior of the light is flawless. It charges using a CC-CV algorithm, and the charging curve looks completely normal. Standby current after charge termination is also well within acceptable limits.
Over-discharge protection and reverse polarity protection are built into the light.
I measured the battery capacity at 5038mAh in my Vapcell S4+.
The light does not have a power bank function.
While charging, the light remains fully operational, though the maximum output of the main front light is somewhat limited.
Summary
The HD02 Pro surprised me. I had read a lot about this light – charging issues, lifting side light diffusers, … I do not want to deny or downplay these problems, yet I can hardly factor them into my rating if my unit is unaffected. Because aside from that, there is a lot to like about the HD02 Pro.
Wurkkos has managed to build a true all-around light. It is not small, yet considering its feature set, it is quite compact. Compact enough to fit easily into jacket pockets and backpacks, though for a pants pocket it is too big for me. Honestly, though, I would not even know where Wurkkos could shave off any more size. The side panels alone, which tilt and rotate and put out great, even light, naturally take up quite a bit of space.
Red, UV, laser, and white light with a good beam pattern round out the complete package. With this setup, you should truly be well equipped for any situation. To keep all of this easy to operate, Wurkkos gave the HD02 Pro a great combination of a rotary selector switch and a push button with a well-designed UI that suits the light.
In my eyes, the HD02 Pro is the light of choice for anyone willing to make minor compromises in exchange for only needing to carry a single flashlight. Whether kept in an everyday backpack, used for camping / vanlife, or relied upon as an emergency light, this versatile Wurkkos can handle it all.
If you’re now tempted to get the Wurkkos HD02 Pro yourself, feel free to check out Wurkkos!
