▶ [REVIEW] Wurkkos TS10 V3 (14500, Nichia 519A, Anduril)
Four years have passed, and now we have the third generation of this highly popular compact EDC flashlight. Throughout those four years, Wurkkos TS10 V1 (in both its aluminum and copper versions) has been my faithful companion, whether I was out on evening walks with my children or dog, searching for something on a shelf. Let’s take a look at whether this third generation is just as delightful as V1 and whether it was even worth the effort to update the original version.
Specification:
Model Name: Wurkkos TS10 V3
Body Material: Aluminum alloy, Copper
Max Brightness and Throw: 900 lumens and 125m
LED 1*Nichia 519A
Power Source: 14500 (no support of AA!)
Size and Weight: 73.9x21.8x21.8mm \ 2.90x0.85x0.85in | Al 56g/1.97oz, Cu: 96g/3.38oz
Other: Buck Driver, RGB-backlight
DESIGN
Do you remember those simple white-and-yellow boxes that Wurkkos started out with? TS1 V1 came in one of those, but now we get a nice white box with high-quality printing, on par with brands that cost significantly more.
upd.
Oh, I just remembered that there was a plain box at the very beginning, and the TS10 might well have been one of the first flashlights to get an upgraded, high-quality box.
Kit includes:
  • TS10 V3
  • 900mah 14500 battery with built in-USB port
  • Pocket Clip
  • Lanyard
  • O-Rings
  • Type-C Charging Cable
  • User Manual
Hm, i certainly remember that kit of Gen1 included a silicon diffusor.
The silhouette of the third generation remains the same as its predecessor’s, it is still that same slender, compact little light. The size, have barely changed as well; the flashlight is only marginally longer and remains somewhere in between 14500 and 18650 batteries
The knurling, however, has been updated and, in my view, for the better. Instead of a smooth body, we now see a honeycomb-style pattern. Judging by the discussion thread about work on TS10V3, this is a divisive design choice. Well, that is matter of taste, hourses the courses; I personally liked this honeycomb pattern back when it appeared on the T1—which is likely where it was carried over from to the TS1 v3.
As you will see below, the optics have been changed
If you would like to compare weight with both version of 1st gen , here they are.
I won’t waste time here describing its appearance, everything is already perfectly clear and most of readers may already have V1. I’ll just say that I like new design; size and weight make Wurkkos TS10 v3 an excellent choice for anyone looking for an ultra-compact EDC light with high-quality illumination and versatile controls.
Actually, wait.I do have something to add. I`ve got the aluminum version for review, but a limited-edition copper version was released just yesterday. I own both versions from the first generation, and - let’s be honest - the copper one feels much better in the hand. Like many others, I’m also looking forward for the release of a titanium version with a copper head; I’ve always wanted one as it looks incredibly cool.
In general, I think Wurkkos could experiment with the knurling and release limited-edition versions featuring thematic patterns. I’m certain they would sell out. For instance, designs incorporating national motifs, or themes centered around major sporting events like the FIFA World Cup, Ice Hockey World Championship, or the Olympic Games.
I did couple of quick examples
The flashlight is comfortable to hold. It can be completely concealed within the palm or held using a “cigar grip.” A reverse grip, given TS10 V3 size, would be useless.
The included clip has a very tight fit and immediately scratched the anodizing. I brought this to the manufacturer’s attention, and as far as I understand, you will receive a different clip. It is quite possible that my review unit came with a clip intended for a different model, one with a slightly smaller body diameter.
As with the two previous generations, operation is controlled via a single flat tail-button (the tail cap is not removable!). In addition to the main body, an extra contact tube has been press-fitted inside to carry the signal.
I did not notice any obvious flaws in the machining.
There is a spring at the tail end, while at the head end there is a contact pad. Everything is just as it was before.
The main change concerns the optics and the LED. While the first generation featured three LEDs, this version uses just one—the popular and widely-loved Nichia 519A. I got my hands on the 5000K color temperature version, which suits my personal taste perfectly. I suspect that Wurkkos might also release a 4000K version, or perhaps even a variant with a long-range (throw-oriented) LED, as they have done in the past.
The last thing I want to mention is the battery. There’s nothing new here, it’s a standard 14500 battery with a built-in charging port. If you own another compact Wurkkos flashlight, it likely uses the exact same battery.
UI
I see no point in wasting your and mine time, explaining user interface here. A full breakdown of how Anduril works would be extremely long. Here is a scheme; if you aren’t familiar with this UI yet, you can easily find a guide online. That said, I’m confident that most people reading this review are already well-acquainted with it.
I will just mention that you can opt for a simple configuration with a standard set of modes, which is handy if you decide to hand the flashlight over to an average user. Or you can choose the advanced configuration if you want access to more customization and lighting options. Personally, though, I’ve never actually used those advanced features.
Wurkkos TS10 V3 in action
As for the light quality, TS10 V3 got Nichia 519A, a LED adored by many for excellent quality of light.. As I`ve mentioned, I got 5000K version, though other color temperatures and may be LED might become available later.
The first generation used 3*LatticePower CSP2323 LEDs with a total output of 1400 lumens. The brightness has now decreased significantly to 900 lumens. I don’t see this as a problem at all; in a flashlight this compact, extremely high brightness severely limits runtime, reducing “turbo” mode to a brief and almost impractical burst. 900 lumens is actually quite a lot, as you’ll see in the photos below, it’s a very respectable level of brightness, not all that different from the original. More importantly, the flashlight can now sustain this output for much, much longer than the first generation could maintain its turbo mode.
One more significant change is the driver. The popular FET+1 configuration has been replaced by a buck driver, which allows for fully regulated, stable brightness! And, to my great impression, this holds true even at the “H7” level (I’ve labeled the “H8” setting as “Turbo” here).
there is no fan cooling line, because i dont think that fan cooling can make any effect on turbo mode to the flashlight with size like this. And the rest of modes already performs flawlessly.
Now, let’s take a look at the light output. What do we see? It’s plenty bright for everyday tasks, such as illuminating the path ahead while out for a walk , and it’s more than sufficient for lighting up a room.
To give you a better idea, I’ve demonstrated how both versions of this flashlight perform. Enjoy the most interesting part of the Wurkkos TS10 V3 review!
I’d estimate the maximum effective range to be about 50 meters; the flashlight won’t be of much use at longer distances.
Overall impression
I’ve been using Wurkkos TS10 V1 for four years now, that should tell you how I feel about this flashlight. Like many others, I was looking forward for an update to V3, and after receiving and testing it , I’m quite pleased.
The design has become more attractive, thanks to the honeycomb-patterned knurling. The user interface remains just as flexible as before. The maximum brightness has decreased (which doesn’t bother me), but in exchange, the runtime in “turbo” mode has improved. And (YEAH!) the output is now fully regulated.
The only thing I could complain about is the stiff pocket clip, though that might just be an issue with my specific unit; it seems Wurkkos might be shipping the flashlight with a different clip now.
I’d like to thank everyone involved in the development of this flashlight. From the engineers who designed the driver, to the person behind the design, and, of course, Toy Keeper for Anduril firmware. You’ve created a delightful little gadget that I’m sure will earn a permanent spot in my pocket as it did 1st gen. Duōxiè
I suppose I ought to find something to complain about so this review doesn’t look too sweet, but honestly, I haven’t found any real grounds for criticism at this point. I must admit that may be (i hope that not), if i use it for a longer time, something will occur. But this didnt happen in case of TS10 V1. So, if I had to ask for one thing, it would be some slots for tritium vials at least in the tail cap, which I believe is thick enough to accommodate them.
12 Thanks
Great review and photos! Thanks!
How do you like the moonlight mode (the lowest brightness setting)? Is there any visible flicker? And how much brighter is it compared to the original TS10?
Appears to be a great review with pics, but I stopped reading after I saw it has no support for AA cells.
Nice pictures, good charts.
Thanks for the review.
thanx for pointing at it, as somehow i didnt pay attention to moonlight level here.
yeah, it is brighter then the one of TS10 V1 by default. not really much though. nevertheless, look like to have to refresh my knowledges about Anduril and try to set moonlight at lower level.
btw, about light distribution. turning them both altogether in moonlight let me clearly see difference in light distribution - V1 has wider and way more diffused hotspot. so may be that`s why moonlight of V3 seems to be brighter.
about flickering - i cannot find my Opple, that`s why i dont include data from it here in review. so the only way to check flickering is usual pen test. TS10 V3 passed it, no trace of cr@ppy PWM-shimmering.
The level 1/150 is brighter because of the new driver.
Wurkkos uses single “gear” buck drivers which have less dynamic range (higher lows) than enthusiasts drivers with multiple gears like the Lume line.
Interesting observation about the light distribution though.
oh, so that is already 1\150…you`ve just saved my time. thanx. no need to re-read manual
