[Review] Wurkkos TS26S – 4x Nichia 519A and boost driver!
Great review as usual. Thx . Great refreshing light from Wurkkos. They really get better and better over time.
A version with and without Anduril: a really good idea.
Do you know when Anduril version will be released? It also will be boost version? @Wurkkos_Terry
Great review. Can you confirm that there is a powerbank feature in TS26S? There is no mention of it anywhere else.
Yes, it can be used as a powerbank. At least the USB port outputs 5V.
FC11C is now being offered with 5000K or 4000K 519a…
You’re going to love it here, macomako!
What could be the maximum power draw of this light?
Would the Vapcell F60 be a good battery for it?
Glad get your voice my man. The boost Anduril firmware still have few bugs should to be fixed now. We are already looking for more help to make it happen.
If test is correct, about 8.5A, so most of 21700 cells will be enough
At least that’s the input current with the full battery. I haven’t checked lower voltages to see when it reaches its input current limit. But most quality 21700 batteries should be good enough. Batteries with high IR / low CDR will experience a voltage drop and the driver will drop out of regulation (and step down).
Comparison between original and dedomed. More throw, lower CCT and duv:
11 Thanks
Thanks for the review!
I hope they sort out your suggestions for the Arduino version: button, sharp edges, clip and propper tailstand with lanyard.
if the clip was reversible they could also offer a ring for just attaching a lanyard by the tailcap.
Did it actually hit 3100 lumens? I heard it only made 1800 lumens
