XTAR MP1S multi size li-ion charger USB
Rating: Excellent
This is the latest incarnation of the popular XTAR MP1 charger. This sample was provided free of charge althrough i paid for all others MP1 i had. Reviewed here long time ago. Anyway, new version so what's new? In short, spacers. Yep, a better packaging (text) a nicer manual and 3 usefull spacers to facilitate charging of varous sizes such as: 10440, 14500, 14650, 17670, 18650, 18700. I t woudl probably charge anything li-ion based if 4.2V is the voltage max range and has a capacity of at least 500mA. Well since charging current is around 450mA i would strongly suggest to not charge batteries with a lower capacity than 600mAh with this one. Most 14500 and 16340 will do fine enough. I would just rather not try 10440 form factor as the current provided is above the max safe for this type of cell. Concerns about using flat top cells are nonexistant it does accept them easily even the slightly longer 18650/18700 with ease.
Being a unit rated CC/CV for charging algorythm this one appears to not follow it correctly 100%. It does it pretty close anyway so this is a non issue.
What makes this little charger so appealing?
PROS:
- Small size
- USB powered
- Good charging capabilities with wide batter size options
- Terminates at 4,21V or 4,22V depending on battery quality or calibration of the unit itself so charget to the rated max safe voltage
- Is able to revive batteries whose protective PCB was tripped hard and not reset (open circuit votage did not raise above the protection PCB treshold) (usefull if you have a microswitch flashlight like UF-H3D whose switch can drain your battery a litle below the PCB protection scheme)
- Very inexpensive for the quality provided
- Well built, both internally and externally.
CONS:
- Does not follow exactly the CC/CV charging algorythm
- If you plan to use it on mains an (inexpensive) adaptor mains/usb or car/usb host adapter must be purchased along (often already bundled by many online retailers)
Pictures:
For 16340 4 spacers should be used. I got only 3 and found with a little playing with them charging a 16340 can be done. 4 spacers is better and looks more decent. :)
Althrough the unit is very lightweight the added rubber pads below keep the unit in place rather well.
Termination voltage on test candidates:
Trustfire "flame" 14500 wPCB -4.22V
Trustfire "flame" 16340 wPCB - 4.21V
XTAR 18650 3100 mAh wPCB - 4.22V
XTAR 18700 2600 mAh wPCB - 4.22V
Sony 16850 flattop unprotected (scavenged from HP laptop battery and 3y+ old) - 4.21V
Due to the lack of resolution from my DMM and the declared tolerances from the unit all batteries probably terminate pretty close to each other. I will probably need a lab DMM with many samples to make it 100% accurate but it's beyond the actual needs we have.
I cannot stress it enough, this is one of the best (for me it is still the best) budget charger available in the market. I liked it before and i still do. Spacers are the real novelty here and are quite handy. At the price asked (usually around 9usd online by random retailers) is an excellent deal. I'm using MP1's for over a year and found them very reliable (20+ units) and safe. It is very reckless i know but i left batteries (forgot) in this charger for over a day with no rise on voltage on them. It's verstility to power a battery on a laptop pc or car (with suitable adapter) is also a nice feature i have used a few times. This unit has a place on my PC case and i use USB ports on my pc to charge batteries 95% of the time. Build quality is much higher than any budget offering i have seen. Make no mistake tho... this is a budget offering but i believe it can compete easily in the higher (out of budget segment) price range.
Yes i got it for free as some like to point a finger to those who cannot be objective recieving something for free or keep it quiet if they do. My verdict has not changed in more than 1 year. It is still an excellent unit. Highly reccomended to anyone looking for a single bay charger. Worth checking out also for the WP2 version 2 of the charger. It's supposedly even better, with emergency charging usb devices and featuring dual independent charging bay.
It's a short review i know, but there is not much more to say that hasn't be said already before or it is common knowledge already.
