This is a review of the XTAR PB2 power bank and charger. This is a 2-slot 18650 charger with a digital readout that also doubles as a rapid USB power bank for smart phone charging and other devices.
There is a video review of the charger I put up on Youtube, here:
The charger and specs can be found here:
It is presently on sale for $12.99 until June 30th. After that, you can use discount code “ad8cd9” to bring the price to $13.69.
The charger was provided by Banggood for review purposes. I receive no other form of compensation.
Overview:
The Xtar PB2 is a nice little charger that serves as both a dual 18650 charger, as well as a powerbank for charging your other USB devices. It incorporates a LED display that shows the remaining percentage capacity of the device, as well as provides error information (such as if you install a battery in backwards).
The unit is very light, but it feels well built. A magnetic cover gives easy access to remove or install ICR/INR/IMR lithium-ion 18650 cells, and the magnets are strong enough to prevent any accidental removal of the cover.
It has a sleek look, and is also very functional.
Interface:
The Xtar PB2 is very easy to use, and is fully plug & play. Remove the magnetic cover to install one or two 18650 cells. Use a USB cable (one is provided) to connect the micro USB port on the Xtar to a USB charging outlet. The Xtar will charge your batteries until full, while displaying the progress on its LED display.
The power bank function is just as easy. With batteries installed, connect the cable to the full-sized USB port on the Xtar, and the other end to your smart phone. Your smart phone will immediately begin to charge, and the device will show the remaining capacity of your batteries.
There is a button on the side of the Xtar that will temporarily activate the LED display to show you the remaining capacity. You only need to press it if the Xtar is not connected to anything. When the device is being used, the display will always be lit.
18650 Charging Function:
As a charger, the Xtar PB2 can charge either 1 or 2 cells at a time. They must be standard lithium-ion 18650 cells. Due to the small size of the battery compartment, only unprotected flat-top cells will fit. Button-top cells might fit, but they would have to be not much longer than 65mm. Protected cells are too long.
Just install your cell(s), and plug a USB cable (or the one provided) into the micro USB port on the Xtar. Plug the other end into any USB wall charger (or port on a computer). The Xtar will immediately begin charging your batteries. It will display a progress readout on its LED panel, showing the percentage of charge your batteries have.
When charging, the digits of the LED display will slowly flash, indicating it is charging. When complete, the flashing will stop and the readout will show 100%. Disconnect the charger, and either remove your charged batteries or leave them in it to use it as a power bank.
If you install 2 cells, they will each charge at 1 amp. If you install 1 cell, it will charge at 2 amps. This assumes you connect the charger to a 2.1A USB outlet, otherwise it will charge at a slower rate (whatever is available from your USB outlet).
If you install 2 cells, they do not have to be at the same voltage, nor be similar in capacity. If voltages are different, the device will show the average capacity in its LED display. When charging is complete, both cells will be at 4.2 volts.
The charger provides a full charge of your cells, terminating at 4.20v. It uses a standard CC/CV algorithm for charging.
It also provides for 0 volt activation of cells to bring severely discharged cells back to life. Though, in my opinion, you should probably just recycle cells that have been discharged completely.
USB Power Bank Function:
The Xtar PB2 can operate as a USB power bank with either 1 or 2 cells installed. If 2 cells are installed, it will provide a 5v 2.1A USB output to charge your other gadgets. If only 1 cell is installed, it will provide a 5v 1A USB output.
Just connect the included micro-USB cable into the full-sized USB port on the Xtar, and the other end to your smart phone or other gadget. Your phone will begin to charge, and the Xtar will display the remaining percentage of its batteries.
The charging efficiency is up to 92%, and you can fully charge your phone from the Xtar, with plenty of capacity remaining.
Acceptable Batteries:
The Xtar PB2 does not come with batteries, so you must provide your own. It can take either one or two 18650 lithium-ion cells. The cells must be the standard kind that take a charge to 4.2 volts. They must also be unprotected flat-top cells, as the battery compartment is limited in length.
Batteries do not have to be the same brand, capacity, or have the same voltage when installed. So, basically, anything goes.
If using just 1 cell in the Xtar, I recommend it be a high-drain cell like a Samsung 30Q or similar. This is because the charger will use a 2A charge with only 1 cell installed in it. This would be hard on a low-drain cell. So, if using low-drain cells, you should probably install 2 of them, which will cause them to be charged at a slower 1A rate.
Specifications:
Construction: Plastic casing, with rubberized coating. Magnetic cover. It is not waterproof, so don’t get it wet.
Size: 110mm x 50mm x 25mm
Weight: 55g (without batteries)
Input: micro USB, 5V up to 2.1A
Output: standard USB, 5V 2.1A
Protection: reverse polarity protection, short, over-voltage, low-voltage.
Heat: The unit does not get hot either being charged or charging something else.
Package contents: Charger, USB cable, manual, box.
My impressions:
Pros:
- Sturdy, grippy surface.
- It is a fairly efficient USB power bank.
- 2.1 amp power bank is rapid for most devices.
- Fast charging of 18650 cells.
- Good termination for full charge of 18650 cells.
Cons:
- Will only fit unprotected flat-top 18650 cells.
Summary:
This is a great little charger for both charging your 18650 cells, and using the powerbank function to charge your smart phone or other micro-USB devices. If you use good batteries in it, it functions as a very respectable 7000mAh powerbank for travel or emergency purposes.
That’s all for now. Thank you for reading.
